| 0014242 | ParaView | (No Category) | public | 2013-08-23 15:04 | 2016-08-12 09:59 | ||||
| Assigned To | Alvaro Sanchez | ||||||||
| Status | closed | Resolution | moved | ||||||
| Product Version | 4.0 | ||||||||
| Target Version | 5.1 | Fixed in Version | |||||||
| Summary | 0014242: Cannot volume rendering using vectors | ||||||||
| Description | Load attached dataset. One cannot seem to volume render it using the vector array "uxvywz". As a work around, one can apply the calculator to extract one of the components (or compute magnitude) and then volume render it. | ||||||||
| Project | Sandia | ||||||||
| Topic Name | |||||||||
| Attached Files | |||||||||
| Relationships | |||||||||||
| Relationships |
| Notes | |
(0034275) Alan Scott (manager) 2015-02-23 16:27 |
This keeps coming up again and again. Lets get it fixed. |
(0034276) Utkarsh Ayachit (administrator) 2015-02-23 16:45 |
This will be/is already fixed in OpenGL2 mapper implementations. |
(0035717) Alan Scott (manager) 2016-02-11 21:35 |
This is not working. I did the following: * 5.0.0, Linux, local server. * Load disk_out_ref.exo, all vars on, apply. * Paint by V. Volume render. * Now, do it manually. Calculator, mag(V). Volume render. They are very different. This isn't working. |
(0035824) Utkarsh Ayachit (administrator) 2016-03-07 10:53 |
I verified that for image data/structured datasets, volume rendering now supports vectors e.g. * Wavelet -> Random Vector -> Volume Render by "BrownianVectors" works as expected. The issue is with vtkOpenGLProjectedTetrahedraMapper that is used for unstructured grids. |
(0036040) Cory Quammen (developer) 2016-06-01 18:10 |
I don't think image data works either when rendering by a vector. See the uploaded state file. |
(0038438) Kitware Robot (administrator) 2016-08-12 09:59 |
| Notes |
| Issue History | |||
| 2013-08-23 15:04 | Utkarsh Ayachit | New Issue | |
| 2014-04-11 10:38 | Utkarsh Ayachit | Relationship added | duplicate of 0009443 |
| 2015-02-23 16:25 | Alan Scott | Relationship added | duplicate of 0015340 |
| 2015-02-23 16:27 | Alan Scott | Note Added: 0034275 | |
| 2015-02-23 16:27 | Alan Scott | Target Version | => 4.4 |
| 2015-02-23 16:45 | Utkarsh Ayachit | Note Added: 0034276 | |
| 2015-09-11 16:43 | Utkarsh Ayachit | Target Version | 4.4 => 5.1 |
| 2016-02-11 21:35 | Alan Scott | Note Added: 0035717 | |
| 2016-03-07 10:53 | Utkarsh Ayachit | Note Added: 0035824 | |
| 2016-06-01 18:09 | Cory Quammen | File Added: WaveletVolumeRendering.pvsm | |
| 2016-06-01 18:10 | Cory Quammen | Note Added: 0036040 | |
| 2016-07-12 11:41 | Utkarsh Ayachit | Assigned To | => Alvaro Sanchez |
| 2016-08-12 09:59 | Kitware Robot | Note Added: 0038438 | |
| 2016-08-12 09:59 | Kitware Robot | Status | backlog => closed |
| 2016-08-12 09:59 | Kitware Robot | Resolution | open => moved |
| Issue History |
