0015340ParaView(No Category)public2015-02-23 16:212016-08-12 09:59
ReporterAlan Scott
Assigned ToAlvaro Sanchez
StatusclosedResolutionmoved
PlatformOSOS Version
Product Versiongit-master
Summary0015340: Volume rendering vectors doesn't work correctly.
DescriptionVolume rendering vectors doesn't work correctly. Please fix it.
* Master, Linux, local server.
* Open disk_out_ref.exo. All vars on. Apply.
* Just to show what this should look like, run a calculator filter. Formula is mag(V). Apply. +X. Now, color by Result, and volume render. This is correct.
* Turn visibility off for the Calculator, turn visibility on for disk_out_ref.exo.
* Color by V, Magnitude. Volume render. This is a bug.
* Click on +Z. Now, start coloring by the different components of V - i.e., X, Y and Z. X and Y look the same, but I am fairly sure should be different. This is a bug.
TagsNo tags attached.
ProjectSandia
Topic Name
Typeincorrect functionality
 Relationships
related to 0015339closedKitware Robot Map Scalars doesn't work with volume rendering
has duplicate 0014242closedAlvaro Sanchez Cannot volume rendering using vectors
  Notes
(0038778)
Kitware Robot (administrator)
2016-08-12 09:59
Resolving issue as `moved`.
 Issue History
2015-02-23 16:21 Alan Scott New Issue
2015-02-23 16:21 Alan Scott Relationship added related to 0015339
2015-02-23 16:25 Alan Scott Relationship added has duplicate 0014242
2016-07-12 11:41 Utkarsh Ayachit Assigned To => Alvaro Sanchez
2016-08-12 09:59 Kitware Robot Note Added: 0038778
2016-08-12 09:59 Kitware Robot Status backlog => closed
2016-08-12 09:59 Kitware Robot Resolution open => moved
