0015016 | ParaView | (No Category) | public | 2014-09-29 16:20 | 2016-08-12 09:59 | ||||
Reporter | Ben Boeckel (Kitware) | ||||||||
Assigned To | Ben Boeckel (Kitware) | ||||||||
Summary | 0015016: Crashes with data label format string mismatches with input data | ||||||||
Description | Fun stuff with integer input with a %s format string (at a minimum). | ||||||||
Project | TBD | ||||||||
Type | crash | ||||||||
Relationships | ||||||
(0033380) Ben Boeckel (Kitware) (developer) 2014-09-29 16:32 |
Basically, sprintf is a bad idea with user input for both the input data and the format string. Boost.Format may be one solution. Unfortunately, the code is in Rendering/Label, so pushing Qt down that low isn't an option. |
(0038665) Kitware Robot (administrator) 2016-08-12 09:59 |
2014-09-29 16:20 | Ben Boeckel (Kitware) | New Issue | |
2014-09-29 16:20 | Ben Boeckel (Kitware) | Assigned To | => Ben Boeckel (Kitware) |
2014-09-29 16:26 | Ben Boeckel (Kitware) | Relationship added | related to 0015015 |
2014-09-29 16:32 | Ben Boeckel (Kitware) | Note Added: 0033380 | |
2016-08-12 09:59 | Kitware Robot | Note Added: 0038665 | |
