0015312 | ParaView | (No Category) | public | 2015-02-09 11:02 | 2015-02-19 08:33 | ||||
Reporter | Casey B Goodlett | ||||||||
Summary | 0015312: Programmable filter support for multiple inputs only one of which is time-varying | ||||||||
Description | I would like to be able to write a programmable filter that has two inputs. One of which is time-varying and the other is static. The use case for this is the time-varying dataset is transformed by information in the static dataset (after matching timestamps). This works if the time-varying dataset is the first input to the programmable filter. However, there is no way to control via the GUI which is the first input. A workaround to set the order exists by using the "Change input" dialog where the order of selection becomes the order of input. | ||||||||
Project | TBD | ||||||||
Type | feature | ||||||||
(0034260) Utkarsh Ayachit (administrator) 2015-02-19 08:33 |
It's no longer needed by the reporter. |
2015-02-09 11:02 | Casey B Goodlett | New Issue | |
2015-02-09 11:02 | Casey B Goodlett | Assigned To | => Utkarsh Ayachit |
2015-02-19 08:33 | Utkarsh Ayachit | Note Added: 0034260 | |
2015-02-19 08:33 | Utkarsh Ayachit | Status | backlog => closed |
2015-02-19 08:33 | Utkarsh Ayachit | Resolution | open => won't fix |
