0003742 | ParaView | (No Category) | public | 2006-09-11 16:57 | 2006-11-30 22:24 | ||||
Reporter | Berk Geveci | ||||||||
Summary | 0003742: Cut slices are not removed when deleted from the GUI | ||||||||
Description | * Create a cut filter * Create 10 slices * Accept * Delete all slices and create 1 slice * Accept There are still bunch of slices hanging around. | ||||||||
(0005339) Berk Geveci (administrator) 2006-10-11 14:20 |
Also, the range is wrong. |
(0005615) Clinton Stimpson (developer) 2006-10-30 18:57 |
Unlike other domains, vtkSMBoundsDomain::Update only gets bounds from the *unchecked* values of the vtkSMProxyProperty. Since we don't do that in PV3, the domain fails to initialize with bounds, and the range is wrong in the GUI panel. |
(0005717) Clinton Stimpson (developer) 2006-11-14 15:07 |
/cvsroot/ParaView3/ParaView3/Qt/Components/pqSampleScalarWidget.cxx,v <-- pqSampleScalarWidget.cxx new revision: 1.6; previous revision: 1.5 /cvsroot/ParaView3/ParaView3/Servers/ServerManager/vtkSMBoundsDomain.cxx,v <-- vtkSMBoundsDomain.cxx new revision: 1.8; previous revision: 1.7 vtkSMBoundsDomain::Update falls back to proxies, in case there are no unchecked proxies. pqSampleScalarWidget checks for a bounds domain as well as scalar range domain. |
(0005725) Kent Eschenberg (reporter) 2006-11-16 11:37 |
This looks like bug 0002099 reported 8/4/2005. |
