0003875 | ParaView | (No Category) | public | 2006-10-06 17:51 | 2007-10-17 17:09 | ||||
Summary | 0003875: Camera rotation point | ||||||||
Description | I cannot change the rotation point of the camera. ParaView 2 has several toolbar buttons to set the center of rotation (as well as showing axes there) which we need to replicate. | ||||||||
(0006032) Ken Moreland (manager) 2006-12-20 16:38 |
You can now set the center of rotation to the center of the geometry. However, the ability to pick or specify coordinates of the center of rotation is still missing. |
(0006468) Utkarsh Ayachit (administrator) 2007-02-20 09:10 |
If I remember correctly, we decided to defer the picking of center of rotation. |
(0006520) Ken Moreland (manager) 2007-02-21 17:12 |
That sounds about right to me, too. I'll lower the priority of this bug so that it is readdressed for PV 3.2. |
(0008486) Berk Geveci (administrator) 2007-08-16 14:35 |
We should support picking center of rotation in 3.2. |
(0008879) Dave DeMarle (administrator) 2007-09-07 09:42 |
Almost fixed. Pick in parallel gets wrong Z value, actually it does in 2.6 as well. But other than that this change fixes it. /cvsroot/ParaView3/ParaView3/Qt/Components/Resources/Icons/pqEnterCenter24.png,v <-- pqEnterCenter24.png initial revision: 1.1 /cvsroot/ParaView3/ParaView3/Qt/Components/Resources/Icons/pqPickCenter24.png,v <-- pqPickCenter24.png initial revision: 1.1 /cvsroot/ParaView3/ParaView3/Qt/Core/pqPickHelper.h,v <-- pqPickHelper.h initial revision: 1.1 /cvsroot/ParaView3/ParaView3/Qt/Core/pqPickHelper.cxx,v <-- pqPickHelper.cxx initial revision: 1.1 /cvsroot/ParaView3/ParaView3/Qt/Core/CMakeLists.txt,v <-- CMakeLists.txt new revision: 1.87; previous revision: 1.86 /cvsroot/ParaView3/ParaView3/Applications/Client/MainWindow.cxx,v <-- MainWindow.cxx new revision: 1.128; previous revision: 1.127 /cvsroot/ParaView3/ParaView3/Applications/Client/MainWindow.ui,v <-- MainWindow.ui new revision: 1.88; previous revision: 1.87 /cvsroot/ParaView3/ParaView3/Qt/Components/pqMainWindowCore.cxx,v <-- pqMainWindowCore.cxx new revision: 1.214; previous revision: 1.213 /cvsroot/ParaView3/ParaView3/Qt/Components/pqMainWindowCore.h,v <-- pqMainWindowCore.h new revision: 1.76; previous revision: 1.75 /cvsroot/ParaView3/ParaView3/Qt/Components/Resources/pqComponents.qrc,v <-- pqComponents.qrc new revision: 1.27; previous revision: 1.26 |
(0009485) Utkarsh Ayachit (administrator) 2007-10-15 16:26 |
ENH: Added API to get z buffer at a point. /cvsroot/ParaView3/ParaView3/VTK/Rendering/vtkRenderWindow.h,v <-- vtkRenderWindow.h new revision: 1.155; previous revision: 1.154 |
(0009490) Utkarsh Ayachit (administrator) 2007-10-16 10:11 |
ZBuffer value can now be queried in client-server mode with/wihtout IceT. In client-server w/o parallel, vtkPVDesktopDeliveryServer can capure the Z buffer data which can be queried using GetZBufferValue. When using IceT, the same is true with vtkIceTRenderManager which works in collaboration with vtkIceTRender to get Z buffer from IceT. /cvsroot/ParaView3/ParaView3/Qt/Components/pqMainWindowCore.cxx,v <-- pqMainWindowCore.cxx new revision: 1.235; previous revision: 1.234 /cvsroot/ParaView3/ParaView3/Qt/Components/pqMainWindowCore.h,v <-- pqMainWindowCore.h new revision: 1.81; previous revision: 1.80 /cvsroot/ParaView3/ParaView3/Qt/Core/pqPickHelper.cxx,v <-- pqPickHelper.cxx new revision: 1.2; previous revision: 1.1 /cvsroot/ParaView3/ParaView3/Qt/Core/pqPickHelper.h,v <-- pqPickHelper.h new revision: 1.2; previous revision: 1.1 /cvsroot/ParaView3/ParaView3/Applications/Client/MainWindow.cxx,v <-- MainWindow.cxx new revision: 1.132; previous revision: 1.131 /cvsroot/ParaView3/ParaView3/Applications/Client/MainWindow.ui,v <-- MainWindow.ui new revision: 1.94; previous revision: 1.93 /cvsroot/ParaView3/ParaView3/Servers/Filters/vtkIceTRenderManager.cxx,v <-- vtkIceTRenderManager.cxx new revision: 1.42; previous revision: 1.41 /cvsroot/ParaView3/ParaView3/Servers/Filters/vtkIceTRenderManager.h,v <-- vtkIceTRenderManager.h new revision: 1.22; previous revision: 1.21 /cvsroot/ParaView3/ParaView3/Servers/Filters/vtkIceTRenderer.cxx,v <-- vtkIceTRenderer.cxx new revision: 1.26; previous revision: 1.25 /cvsroot/ParaView3/ParaView3/Servers/Filters/vtkIceTRenderer.h,v <-- vtkIceTRenderer.h new revision: 1.10; previous revision: 1.9 /cvsroot/ParaView3/ParaView3/Servers/Filters/vtkPVDesktopDeliveryServer.cxx,v <-- vtkPVDesktopDeliveryServer.cxx new revision: 1.10; previous revision: 1.9 /cvsroot/ParaView3/ParaView3/Servers/Filters/vtkPVDesktopDeliveryServer.h,v <-- vtkPVDesktopDeliveryServer.h new revision: 1.7; previous revision: 1.6 /cvsroot/ParaView3/ParaView3/Servers/ServerManager/vtkSMClientServerRenderViewProxy.cxx,v <-- vtkSMClientServerRenderViewProxy.cxx new revision: 1.9; previous revision: 1.8 /cvsroot/ParaView3/ParaView3/Servers/ServerManager/vtkSMClientServerRenderViewProxy.h,v <-- vtkSMClientServerRenderViewProxy.h new revision: 1.8; previous revision: 1.7 /cvsroot/ParaView3/ParaView3/Servers/ServerManager/vtkSMIceTDesktopRenderViewProxy.cxx,v <-- vtkSMIceTDesktopRenderViewProxy.cxx new revision: 1.14; previous revision: 1.13 /cvsroot/ParaView3/ParaView3/Servers/ServerManager/vtkSMIceTDesktopRenderViewProxy.h,v <-- vtkSMIceTDesktopRenderViewProxy.h new revision: 1.8; previous revision: 1.7 /cvsroot/ParaView3/ParaView3/Servers/ServerManager/vtkSMRenderViewProxy.cxx,v <-- vtkSMRenderViewProxy.cxx new revision: 1.51; previous revision: 1.50 |
(0009503) Alan Scott (manager) 2007-10-17 17:09 |
Blackrose is down, verified in XP local mode. |
2007-08-13 15:13 | Berk Geveci | Priority | normal => high |
2007-08-13 15:14 | Berk Geveci | Assigned To | Utkarsh Ayachit => Dave DeMarle |
2007-08-16 14:35 | Berk Geveci | Note Added: 0008486 | |
2007-09-07 09:42 | Dave DeMarle | Note Added: 0008879 | |
2007-10-15 16:26 | Utkarsh Ayachit | Note Added: 0009485 | |
2007-10-16 10:11 | Utkarsh Ayachit | Status | tabled => @80@ |
2007-10-16 10:11 | Utkarsh Ayachit | Resolution | open => fixed |
2007-10-16 10:11 | Utkarsh Ayachit | Note Added: 0009490 | |
2007-10-16 10:19 | Utkarsh Ayachit | Assigned To | Dave DeMarle => Utkarsh Ayachit |
2007-10-16 10:19 | Utkarsh Ayachit | Status | @80@ => @20@ |
2007-10-16 10:19 | Utkarsh Ayachit | Resolution | fixed => reopened |
2007-10-16 10:19 | Utkarsh Ayachit | Status | @20@ => @80@ |
2007-10-16 10:19 | Utkarsh Ayachit | Resolution | reopened => fixed |
2007-10-17 17:09 | Alan Scott | Status | @80@ => closed |
2007-10-17 17:09 | Alan Scott | Note Added: 0009503 | |
