0003932 | ParaView | (No Category) | public | 2006-10-12 08:15 | 2006-12-18 19:01 | ||||
Priority | urgent | Severity | feature | Reproducibility | always | ||||
Summary | 0003932: Add LightKit support | ||||||||
Description | To be ParaView 2 compliant, we need light kit support. I wrote a widget in vtkSNL that controls vtkLightKit, if that helps. | ||||||||
(0005771) Clinton Stimpson (developer) 2006-11-22 18:15 |
/cvsroot/ParaView3/ParaView3/Qt/Components/pq3DViewPropertiesWidget.cxx,v <-- pq3DViewPropertiesWidget.cxx new revision: 1.6; previous revision: 1.5 /cvsroot/ParaView3/ParaView3/Qt/Components/pq3DViewPropertiesWidget.h,v <-- pq3DViewPropertiesWidget.h new revision: 1.3; previous revision: 1.2 /cvsroot/ParaView3/ParaView3/Qt/Components/pqNamedWidgets.cxx,v <-- pqNamedWidgets.cxx new revision: 1.11; previous revision: 1.10 /cvsroot/ParaView3/ParaView3/Qt/Components/Resources/UI/pq3DViewPropertiesWidget.ui,v <-- pq3DViewPropertiesWidget.ui new revision: 1.2; previous revision: 1.1 /cvsroot/ParaView3/ParaView3/Qt/Core/pqGenericViewModule.h,v <-- pqGenericViewModule.h new revision: 1.4; previous revision: 1.3 /cvsroot/ParaView3/ParaView3/Qt/Core/pqRenderViewModule.cxx,v <-- pqRenderViewModule.cxx new revision: 1.2; previous revision: 1.1 |
(0005772) Clinton Stimpson (developer) 2006-11-22 18:35 |
/cvsroot/ParaView3/ParaView3/Qt/Components/pqSettingsDialog.cxx,v <-- pqSettingsDialog.cxx new revision: 1.5; previous revision: 1.4 |
(0005808) Ken Moreland (manager) 2006-11-27 13:11 |
This is almost working. There are some minor issues, though. 1: The label "Key Light Parameters" should read "Light Kit Parameters". 2: The spacing in the GUI is excessive. Compare it to the GUI controls in ParaView 2. 3: There is no way to turn off the "default light." Thus, the rendered image is often excessively bright. Although somewhat tangential to this feature request, we also need a "Default Light Control" to turn the default light on and off. Again, see the ParaView 2 GUI for an example. |
(0005811) Clinton Stimpson (developer) 2006-11-27 14:20 |
/cvsroot/ParaView3/ParaView3/Qt/Components/Resources/UI/pq3DViewPropertiesWidget.ui,v <-- pq3DViewPropertiesWidget.ui new revision: 1.3; previous revision: 1.2 Fixed label and spacing. I accidentally left a minimum size in that made spacing look bad. I'll add the default light control sometime soon. |
(0005856) Clinton Stimpson (developer) 2006-12-01 17:30 |
/cvsroot/ParaView3/ParaView3/Applications/Client/Testing/XML/ViewSettingsDialog.xml,v <-- ViewSettingsDialog.xml new revision: 1.5; previous revision: 1.4 /cvsroot/ParaView3/ParaView3/Qt/Components/CMakeLists.txt,v <-- CMakeLists.txt new revision: 1.32; previous revision: 1.31 /cvsroot/ParaView3/ParaView3/Qt/Components/pq3DViewPropertiesWidget.cxx,v <-- pq3DViewPropertiesWidget.cxx new revision: 1.7; previous revision: 1.6 /cvsroot/ParaView3/ParaView3/Qt/Components/pqPipelineBrowserContextMenu.cxx,v <-- pqPipelineBrowserContextMenu.cxx new revision: 1.15; previous revision: 1.14 /cvsroot/ParaView3/ParaView3/Qt/Components/pqPipelineBrowserContextMenu.h,v <-- pqPipelineBrowserContextMenu.h new revision: 1.4; previous revision: 1.3 /cvsroot/ParaView3/ParaView3/Qt/Components/pqRenderViewEditor.cxx,v <-- pqRenderViewEditor.cxx new revision: delete; previous revision: 1.2 /cvsroot/ParaView3/ParaView3/Qt/Components/pqRenderViewEditor.h,v <-- pqRenderViewEditor.h new revision: delete; previous revision: 1.2 /cvsroot/ParaView3/ParaView3/Qt/Components/Resources/UI/pq3DViewPropertiesWidget.ui,v <-- pq3DViewPropertiesWidget.ui new revision: 1.4; previous revision: 1.3 /cvsroot/ParaView3/ParaView3/Qt/Components/Resources/UI/pqRenderViewEditor.ui,v <-- pqRenderViewEditor.ui new revision: delete; previous revision: 1.1 |
(0005900) Ken Moreland (manager) 2006-12-06 19:10 |
I just realized that the light parameters are not saved to the settings file. That should be pretty easy to fix. |
(0005910) Clinton Stimpson (developer) 2006-12-07 17:26 |
Save settings /cvsroot/ParaView3/ParaView3/Qt/Components/pq3DViewPropertiesWidget.cxx,v <-- pq3DViewPropertiesWidget.cxx new revision: 1.9; previous revision: 1.8 /cvsroot/ParaView3/ParaView3/Qt/Core/pqRenderViewModule.cxx,v <-- pqRenderViewModule.cxx new revision: 1.6; previous revision: 1.5 /cvsroot/ParaView3/ParaView3/Qt/Core/pqRenderViewModule.h,v <-- pqRenderViewModule.h new revision: 1.4; previous revision: 1.3 |
(0005920) Clinton Stimpson (developer) 2006-12-08 11:10 |
Reset button added for lights, but probably won't be implemented until the new defaults mechanism is extended to include the render module. I'll make that a separate bug so it can get its own "assigned to" and "priority" if necessary. |
(0005995) Ken Moreland (manager) 2006-12-18 19:01 |
The "reset light" option bug item is 0004184. |
