0004153 | ParaView | (No Category) | public | 2006-12-06 17:48 | 2007-02-05 16:04 | ||||
Summary | 0004153: Geometry caching | ||||||||
Description | When running an animation, the geometry should be (usually) cached. As in ParaView 2, there needs to be an option to turn off geometry caching. We have also had a lot of problems in the past with geometry caching. When writing a large animation, the cache often exceeds memory and causes the program to crash. Perhaps there could be another option of geometry cache threshold where the cache will automatically be turned off when the size of the geometry x the number of timesteps exceeds this threshold. | ||||||||
(0006215) Utkarsh Ayachit (administrator) 2007-01-17 11:24 |
Adding Cache check box. /cvsroot/ParaView3/ParaView3/Servers/ServerManager/vtkSMAnimationCueProxy.cxx,v <-- vtkSMAnimationCueProxy.cxx new revision: 1.16; previous revision: 1.15 /cvsroot/ParaView3/ParaView3/Servers/ServerManager/vtkSMAnimationSceneProxy.cxx,v <-- vtkSMAnimationSceneProxy.cxx new revision: 1.35; previous revision: 1.34 /cvsroot/ParaView3/ParaView3/Servers/ServerManager/vtkSMProxyProperty.cxx,v <-- vtkSMProxyProperty.cxx new revision: 1.40; previous revision: 1.39 /cvsroot/ParaView3/ParaView3/Qt/Components/pqAnimationPanel.cxx,v <-- pqAnimationPanel.cxx new revision: 1.5; previous revision: 1.4 /cvsroot/ParaView3/ParaView3/Qt/Components/Resources/UI/pqAnimationPanel.ui,v <-- pqAnimationPanel.ui new revision: 1.4; previous revision: 1.3 |
(0006254) Utkarsh Ayachit (administrator) 2007-01-24 15:24 |
Added mechanism to keep track of memory used by update suppressor caches. Every render module has a cache limit, when the cache size goes beyond that limit, the cache is not longer maintained for any new frames generated. However all previous generated cache is kept and used for playing. Limit can be chaged from View|Settings dialog. /cvsroot/ParaView3/ParaView3/Servers/Common/CMakeLists.txt,v <-- CMakeLists.txt new revision: 1.52; previous revision: 1.51 /cvsroot/ParaView3/ParaView3/Servers/Common/vtkCacheSizeKeeper.cxx,v <-- vtkCacheSizeKeeper.cxxinitial revision: 1.1 /cvsroot/ParaView3/ParaView3/Servers/Common/vtkCacheSizeKeeper.h,v <-- vtkCacheSizeKeeper.h initial revision: 1.1 /cvsroot/ParaView3/ParaView3/Servers/Common/vtkPVCacheSizeInformation.cxx,v <-- vtkPVCacheSizeInformation.cxx initial revision: 1.1 /cvsroot/ParaView3/ParaView3/Servers/Common/vtkPVCacheSizeInformation.h,v <-- vtkPVCacheSizeInformation.h initial revision: 1.1 /cvsroot/ParaView3/ParaView3/Servers/Common/vtkProcessModule.cxx,v <-- vtkProcessModule.cxx new revision: 1.66; previous revision: 1.65 /cvsroot/ParaView3/ParaView3/Servers/Common/vtkProcessModule.h,v <-- vtkProcessModule.h new revision: 1.53; previous revision: 1.52 /cvsroot/ParaView3/ParaView3/Servers/Filters/vtkPVUpdateSuppressor.cxx,v <-- vtkPVUpdateSuppressor.cxx new revision: 1.42; previous revision: 1.41 /cvsroot/ParaView3/ParaView3/Servers/Filters/vtkPVUpdateSuppressor.h,v <-- vtkPVUpdateSuppressor.h new revision: 1.19; previous revision: 1.18 /cvsroot/ParaView3/ParaView3/Servers/ServerManager/vtkSMRenderModuleProxy.cxx,v <-- vtkSMRenderModuleProxy.cxx new revision: 1.61; previous revision: 1.60 /cvsroot/ParaView3/ParaView3/Servers/ServerManager/vtkSMRenderModuleProxy.h,v <-- vtkSMRenderModuleProxy.h new revision: 1.28; previous revision: 1.27 /cvsroot/ParaView3/ParaView3/Servers/ServerManager/Resources/filters.xml,v <-- filters.xml new revision: 1.167; previous revision: 1.166 /cvsroot/ParaView3/ParaView3/Servers/ServerManager/Resources/rendering.xml,v <-- rendering.xml new revision: 1.123; previous revision: 1.122 /cvsroot/ParaView3/ParaView3/Qt/Components/pq3DViewPropertiesWidget.cxx,v <-- pq3DViewPropertiesWidget.cxx new revision: 1.14; previous revision: 1.13 /cvsroot/ParaView3/ParaView3/Qt/Components/Resources/UI/pq3DViewPropertiesWidget.ui,v <-- pq3DViewPropertiesWidget.ui new revision: 1.11; previous revision: 1.10 /cvsroot/ParaView3/ParaView3/Qt/Core/pqRenderViewModule.cxx,v <-- pqRenderViewModule.cxx new revision: 1.19; previous revision: 1.18 |
