0004504 | ParaView | (No Category) | public | 2007-02-26 16:58 | 2007-08-21 11:56 | ||||
Reporter | Clinton Stimpson | ||||||||
Summary | 0004504: problems with multiview test pvsm file | ||||||||
Description | open LoadStateMultiView.pvsm in ParaViewData/Data. Interact with some views and you'll get errors "ERROR: In /home/cjstimp/paraview/ParaView3/VTK/Rendering/vtkInteractorStyle.cxx, line 379 vtkInteractorStyleJoystickCamera (0x2230f10): Timer start failed" | ||||||||
(0006591) Clinton Stimpson (developer) 2007-02-28 16:08 |
See bug# 4143. |
(0006899) Utkarsh Ayachit (administrator) 2007-03-22 09:49 |
reiterating Clint so that the bug link is clickable: See bug 0004143 |
(0008437) Berk Geveci (administrator) 2007-08-13 16:25 |
Is this a state file coming from 2? If yes, we should close this bug if no we should fix the compatibility layer. |
(0008527) Utkarsh Ayachit (administrator) 2007-08-20 15:50 |
Yes, this is a 2.9.10 version state file (only the version number has been changed to 3.0.2 to avoid error messages). |
2007-08-13 16:25 | Berk Geveci | Note Added: 0008437 | |
2007-08-13 16:25 | Berk Geveci | Priority | normal => high |
2007-08-20 15:50 | Utkarsh Ayachit | Status | tabled => @80@ |
2007-08-20 15:50 | Utkarsh Ayachit | Resolution | open => no change required |
2007-08-20 15:50 | Utkarsh Ayachit | Note Added: 0008527 | |
2007-08-21 11:56 | Ken Moreland | Status | @80@ => closed |
