0005142 | ParaView | (No Category) | public | 2007-06-07 11:53 | 2007-08-29 12:50 | ||||
Reporter | Berk Geveci | ||||||||
Summary | 0005142: Better location(s) for default_servers.pvsc | ||||||||
Description | There should be a better location(s) default_servers.pvsc. These may be: /usr/lib/paraview-3.x /usr/share/paraview-3.x somewhere in home.... There should be system specific and user specific versions of the default servers file. | ||||||||
Relationships | ||||||
(0007828) Clinton Stimpson (developer) 2007-06-07 12:17 |
Do we load all of those files that are found? Somewhere in home is $HOME/default_servers.pvsc or $HOME/.paraview/default_servers.pvsc ? Or some environment variable? |
(0008417) Clinton Stimpson (developer) 2007-08-13 12:17 |
/cvsroot/ParaView3/ParaView3/Qt/Core/pqApplicationCore.cxx,v <-- pqApplicationCore.cxx new revision: 1.72; previous revision: 1.71 |
(0008418) Clinton Stimpson (developer) 2007-08-13 12:21 |
Also update Wiki page. |
(0008449) Ken Moreland (manager) 2007-08-14 09:25 |
Is there a reason to have the default_servers.pvsc in a different location than all the other configuration files ($HOME/.config/Kitware)? Let's talk about this at the Tuesday meeting. |
(0008459) Clinton Stimpson (developer) 2007-08-14 14:25 |
I agree something needs to change. Currently, user's servers are read and saved with QSettings, found in $HOME/.config/Kitware/, but not in XML format. I suggest not using QSettings, but have plain XML files. |
(0008466) Ken Moreland (manager) 2007-08-14 19:43 |
I agree. I would also suggest that the XML either go in a subdirectory of $HOME/.config/Kitware, or be called something other than simply default_servers.pvsc. The path should indicate that the configuration file is specific to ParaView. Is there a way to get the location where QSettings reads and writes files? |
(0008493) Clinton Stimpson (developer) 2007-08-16 18:51 |
Now reads user settings from Windows: %APPDATA%\Kitware\servers.pvsc Unix: $HOME/.config/Kitware/servers.pvsc Also made changes that will help in fixing bug 0005487. Still need to read from /usr/share/... or something. /cvsroot/ParaView3/ParaView3/Qt/Components/pqEditServerStartupDialog.cxx,v <-- pqEditServerStartupDialog.cxx new revision: 1.8; previous revision: 1.7 /cvsroot/ParaView3/ParaView3/Qt/Components/pqServerBrowser.cxx,v <-- pqServerBrowser.cxx new revision: 1.15; previous revision: 1.14 /cvsroot/ParaView3/ParaView3/Qt/Components/pqSimpleServerStartup.cxx,v <-- pqSimpleServerStartup.cxx new revision: 1.23; previous revision: 1.22 /cvsroot/ParaView3/ParaView3/Qt/Core/CMakeLists.txt,v <-- CMakeLists.txt new revision: 1.85; previous revision: 1.84 /cvsroot/ParaView3/ParaView3/Qt/Core/pqApplicationCore.cxx,v <-- pqApplicationCore.cxx new revision: 1.74; previous revision: 1.73 /cvsroot/ParaView3/ParaView3/Qt/Core/pqCommandServerStartup.cxx,v <-- pqCommandServerStartup.cxx new revision: 1.12; previous revision: 1.11 /cvsroot/ParaView3/ParaView3/Qt/Core/pqCommandServerStartup.h,v <-- pqCommandServerStartup.h new revision: 1.8; previous revision: 1.7 /cvsroot/ParaView3/ParaView3/Qt/Core/pqManualServerStartup.cxx,v <-- pqManualServerStartup.cxx new revision: 1.7; previous revision: 1.6 /cvsroot/ParaView3/ParaView3/Qt/Core/pqManualServerStartup.h,v <-- pqManualServerStartup.h new revision: 1.7; previous revision: 1.6 /cvsroot/ParaView3/ParaView3/Qt/Core/pqServerStartup.h,v <-- pqServerStartup.h new revision: 1.7; previous revision: 1.6 /cvsroot/ParaView3/ParaView3/Qt/Core/pqServerStartups.cxx,v <-- pqServerStartups.cxx new revision: 1.11; previous revision: 1.10 /cvsroot/ParaView3/ParaView3/Qt/Core/pqServerStartups.h,v <-- pqServerStartups.h new revision: 1.6; previous revision: 1.5 |
(0008664) Clinton Stimpson (developer) 2007-08-24 19:15 |
Also read from /usr/share/ParaView3.1/servers.pvsc %COMMON_APPDATA%\ParaView3.1\servers.pvsc /cvsroot/ParaView3/ParaView3/Qt/Core/pqServerStartups.cxx,v <-- pqServerStartups.cxx new revision: 1.12; previous revision: 1.11 |
(0008682) Ken Moreland (manager) 2007-08-27 17:38 |
This is bit of a nitpick, but should the file located in $HOME/.config/Kitware or %APPDATA%\Kitware be called servers.pvsc. The file itself is specific to ParaView, but there is nothing in the path to suggest that. Should the file be put in a ParaView subdirectory? Should it be called paraview_servers.pvsc in that directory? Should I just shut up? |
(0008717) Clinton Stimpson (developer) 2007-08-28 14:01 |
On Linux, it is now $HOME/.config/ParaView3.1/... /cvsroot/ParaView3/ParaView3/Qt/Core/pqApplicationCore.cxx,v <-- pqApplicationCore.cxx new revision: 1.75; previous revision: 1.74 /cvsroot/ParaView3/ParaView3/Qt/Core/pqServerStartups.cxx,v <-- pqServerStartups.cxx new revision: 1.13; previous revision: 1.12 /cvsroot/ParaView3/ParaView3/Qt/Core/pqServerStartups.h,v <-- pqServerStartups.h new revision: 1.7; previous revision: 1.6 |
(0008718) Clinton Stimpson (developer) 2007-08-28 14:10 |
I don't the version number being in the directory name. |
(0008719) Clinton Stimpson (developer) 2007-08-28 14:11 |
Now its $HOME/.config/ParaView/... /cvsroot/ParaView3/ParaView3/Applications/Client/ProcessModuleGUIHelper.cxx,v <-- ProcessModuleGUIHelper.cxx new revision: 1.11; previous revision: 1.10 /cvsroot/ParaView3/ParaView3/Qt/Core/pqApplicationCore.cxx,v <-- pqApplicationCore.cxx new revision: 1.76; previous revision: 1.75 /cvsroot/ParaView3/ParaView3/Qt/Core/pqServerStartups.cxx,v <-- pqServerStartups.cxx new revision: 1.14; previous revision: 1.13 |
2007-08-13 12:17 | Clinton Stimpson | Note Added: 0008417 | |
2007-08-13 12:21 | Clinton Stimpson | Status | tabled => @80@ |
2007-08-13 12:21 | Clinton Stimpson | Resolution | open => fixed |
2007-08-13 12:21 | Clinton Stimpson | Note Added: 0008418 | |
2007-08-14 09:25 | Ken Moreland | Status | @80@ => @20@ |
2007-08-14 09:25 | Ken Moreland | Resolution | fixed => reopened |
2007-08-14 09:25 | Ken Moreland | Note Added: 0008449 | |
2007-08-14 14:25 | Clinton Stimpson | Note Added: 0008459 | |
2007-08-14 14:26 | Clinton Stimpson | Relationship added | related to 0005487 |
2007-08-14 19:43 | Ken Moreland | Note Added: 0008466 | |
2007-08-16 18:51 | Clinton Stimpson | Note Added: 0008493 | |
2007-08-23 10:32 | Berk Geveci | Priority | normal => high |
2007-08-24 19:15 | Clinton Stimpson | Status | @20@ => @80@ |
2007-08-24 19:15 | Clinton Stimpson | Resolution | reopened => fixed |
2007-08-24 19:15 | Clinton Stimpson | Note Added: 0008664 | |
2007-08-27 17:38 | Ken Moreland | Note Added: 0008682 | |
2007-08-28 13:09 | Ken Moreland | Status | @80@ => @20@ |
2007-08-28 13:09 | Ken Moreland | Resolution | fixed => reopened |
2007-08-28 14:01 | Clinton Stimpson | Status | @20@ => @80@ |
2007-08-28 14:01 | Clinton Stimpson | Resolution | reopened => fixed |
2007-08-28 14:01 | Clinton Stimpson | Note Added: 0008717 | |
2007-08-28 14:10 | Clinton Stimpson | Note Added: 0008718 | |
2007-08-28 14:10 | Clinton Stimpson | Status | @80@ => tabled |
2007-08-28 14:11 | Clinton Stimpson | Status | tabled => @80@ |
2007-08-28 14:11 | Clinton Stimpson | Note Added: 0008719 | |
2007-08-29 12:50 | Ken Moreland | Status | @80@ => closed |
