0005239 | ParaView | (No Category) | public | 2007-06-26 10:47 | 2007-09-05 17:03 | ||||
Summary | 0005239: Extract Selection Cell not getting selection | ||||||||
Description | When you select a group of cells and then add the Extract Selection (Cell) filter, the indices in the object inspector are supposed to be set to the selected cells. Instead, no indices are shown. | ||||||||
Relationships | ||||||
(0007940) Berk Geveci (administrator) 2007-06-26 11:00 |
Yup, known bug :-) Due to display-representation transition. We will address this before 3.2. |
(0007944) Utkarsh Ayachit (administrator) 2007-06-26 11:46 |
Partial fix for BUG# 5239. Cell ids now show up correctly. Need to fix for global ids. /cvsroot/ParaView3/ParaView3/Qt/Components/pqSelectionManager.cxx,v <-- pqSelectionManager.cxx new revision: 1.50; previous revision: 1.49 |
(0008790) Utkarsh Ayachit (administrator) 2007-08-31 11:45 |
This bug is no longer relevant since the extract selection mechanism changed. The new "Extract Selections" filter copies the cells correctly. The part related to issues with global ids is captured in bug 0005565. |
2007-08-31 11:44 | Utkarsh Ayachit | Relationship added | related to 0005565 |
2007-08-31 11:45 | Utkarsh Ayachit | Status | tabled => @80@ |
2007-08-31 11:45 | Utkarsh Ayachit | Resolution | open => no change required |
2007-08-31 11:45 | Utkarsh Ayachit | Note Added: 0008790 | |
2007-09-05 17:03 | Ken Moreland | Status | @80@ => closed |
