0005569 | ParaView | (No Category) | public | 2007-08-24 10:11 | 2007-09-12 20:03 | ||||
Priority | high | Severity | feature | Reproducibility | N/A | ||||
Summary | 0005569: Separate Active View and Application settings | ||||||||
Description | We need to separate active view and application settings. From the current 3D view settings, we need to make only the following options view specific: * General Tab (Background color and parallel projection) * Lights Tab (all) * Annotation Tab (all). All other settings become application wide settings. Also need to make the 3D view options dialog similar to the chart options dialog. | ||||||||
Attached Files | pq3DViewOptionsWidget.ui [^] (54,915 bytes) 2007-08-24 10:12 | ||||||||
Relationships | |||||||||||
(0008712) Clinton Stimpson (developer) 2007-08-28 12:56 |
The settings dialog is also inconsistent. If I have a spreadsheet view active, I cannot open it. If I have a bar chart view active, I cannot access application wide settings. |
(0008841) Clinton Stimpson (developer) 2007-09-05 14:19 |
And how is this supposed to work with QSettings? All settings get saved? Or just the application settings? If its all settings, then whichever view was last modified gets its settings saved? |
(0008848) Ken Moreland (manager) 2007-09-05 17:16 |
The QSettings issues should be resolved by having default values for active view settings where appropriate. The Applications Settings dialog could have tabs for 3D View Defaults, X-Y Plot View Defaults, etc. If it is easier, these tabs could just be a replication of the options for each type of view, although it would probably also make sense to strip out some options. All the options for 3D views could probably stand to have savable default values, but there are several options for X-Y plots that should probably always remain the same, such as blank labels for title and axes. |
(0008856) Clinton Stimpson (developer) 2007-09-06 13:23 |
Whew! That was a lot of work. Now the settings dialogs all have the same look and feel. The application settings dialog has room to add settings for other view types. /cvsroot/ParaView3/ParaView3/Applications/Client/MainWindow.cxx,v <-- MainWindow.cxx new revision: 1.127; previous revision: 1.126 /cvsroot/ParaView3/ParaView3/Applications/Client/MainWindow.ui,v <-- MainWindow.ui new revision: 1.87; previous revision: 1.86 /cvsroot/ParaView3/ParaView3/Applications/Client/Testing/XML/OrientationAxis.xml,v <-- OrientationAxis.xml new revision: 1.3; previous revision: 1.2 /cvsroot/ParaView3/ParaView3/Applications/Client/Testing/XML/UndoRedo6.xml,v <-- UndoRedo6.xml new revision: 1.6; previous revision: 1.5 /cvsroot/ParaView3/ParaView3/Applications/Client/Testing/XML/ViewSettingsDialog.xml,v <-- ViewSettingsDialog.xml new revision: 1.10; previous revision: 1.9 /cvsroot/ParaView3/ParaView3/Qt/Components/CMakeLists.txt,v <-- CMakeLists.txt new revision: 1.120; previous revision: 1.119 /cvsroot/ParaView3/ParaView3/Qt/Components/pq3DViewPropertiesWidget.cxx,v <-- pq3DViewPropertiesWidget.cxx new revision: delete; previous revision: 1.25 /cvsroot/ParaView3/ParaView3/Qt/Components/pq3DViewPropertiesWidget.h,v <-- pq3DViewPropertiesWidget.h new revision: delete; previous revision: 1.8 /cvsroot/ParaView3/ParaView3/Qt/Components/pqActiveRenderViewOptions.cxx,v <-- pqActiveRenderViewOptions.cxx new revision: 1.2; previous revision: 1.1 /cvsroot/ParaView3/ParaView3/Qt/Components/pqActiveRenderViewOptions.h,v <-- pqActiveRenderViewOptions.h new revision: 1.3; previous revision: 1.2 /cvsroot/ParaView3/ParaView3/Qt/Components/pqActiveViewOptionsManager.cxx,v <-- pqActiveViewOptionsManager.cxx new revision: 1.2; previous revision: 1.1 /cvsroot/ParaView3/ParaView3/Qt/Components/pqActiveViewOptionsManager.h,v <-- pqActiveViewOptionsManager.h new revision: 1.3; previous revision: 1.2 /cvsroot/ParaView3/ParaView3/Qt/Components/pqApplicationOptions.cxx,v <-- pqApplicationOptions.cxx initial revision: 1.1 /cvsroot/ParaView3/ParaView3/Qt/Components/pqApplicationOptions.h,v <-- pqApplicationOptions.h initial revision: 1.1 /cvsroot/ParaView3/ParaView3/Qt/Components/pqApplicationOptionsDialog.cxx,v <-- pqApplicationOptionsDialog.cxx initial revision: 1.1 /cvsroot/ParaView3/ParaView3/Qt/Components/pqApplicationOptionsDialog.h,v <-- pqApplicationOptionsDialog.h initial revision: 1.1 /cvsroot/ParaView3/ParaView3/Qt/Components/pqApplicationSettingsWidget.cxx,v <-- pqApplicationSettingsWidget.cxx new revision: delete; previous revision: 1.2 /cvsroot/ParaView3/ParaView3/Qt/Components/pqApplicationSettingsWidget.h,v <-- pqApplicationSettingsWidget.h new revision: delete; previous revision: 1.1 /cvsroot/ParaView3/ParaView3/Qt/Components/pqChartOptionsEditor.cxx,v <-- pqChartOptionsEditor.cxx new revision: 1.5; previous revision: 1.4 /cvsroot/ParaView3/ParaView3/Qt/Components/pqChartOptionsEditor.h,v <-- pqChartOptionsEditor.h new revision: 1.4; previous revision: 1.3 /cvsroot/ParaView3/ParaView3/Qt/Components/pqGlobalRenderViewOptions.cxx,v <-- pqGlobalRenderViewOptions.cxx initial revision: 1.1 /cvsroot/ParaView3/ParaView3/Qt/Components/pqGlobalRenderViewOptions.h,v <-- pqGlobalRenderViewOptions.h initial revision: 1.1 /cvsroot/ParaView3/ParaView3/Qt/Components/pqMainWindowCore.cxx,v <-- pqMainWindowCore.cxx new revision: 1.212; previous revision: 1.211 /cvsroot/ParaView3/ParaView3/Qt/Components/pqMainWindowCore.h,v <-- pqMainWindowCore.h new revision: 1.75; previous revision: 1.74 /cvsroot/ParaView3/ParaView3/Qt/Components/pqOptionsContainer.h,v <-- pqOptionsContainer.h new revision: 1.3; previous revision: 1.2 /cvsroot/ParaView3/ParaView3/Qt/Components/pqOptionsDialog.cxx,v <-- pqOptionsDialog.cxx new revision: 1.2; previous revision: 1.1 /cvsroot/ParaView3/ParaView3/Qt/Components/pqRenderViewOptions.cxx,v <-- pqRenderViewOptions.cxx initial revision: 1.1 /cvsroot/ParaView3/ParaView3/Qt/Components/pqRenderViewOptions.h,v <-- pqRenderViewOptions.h initial revision: 1.1 /cvsroot/ParaView3/ParaView3/Qt/Components/pqSettingsDialog.cxx,v <-- pqSettingsDialog.cxx new revision: delete; previous revision: 1.10 /cvsroot/ParaView3/ParaView3/Qt/Components/pqSettingsDialog.h,v <-- pqSettingsDialog.h new revision: delete; previous revision: 1.7 /cvsroot/ParaView3/ParaView3/Qt/Components/Resources/UI/pqApplicationOptions.ui,v <-- pqApplicationOptions.ui initial revision: 1.1 /cvsroot/ParaView3/ParaView3/Qt/Components/Resources/UI/pqApplicationSettingsWidget.ui,v <-- pqApplicationSettingsWidget.ui new revision: delete; previous revision: 1.1 /cvsroot/ParaView3/ParaView3/Qt/Components/Resources/UI/pqGlobalRenderViewOptions.ui,v <-- pqGlobalRenderViewOptions.ui initial revision: 1.1 /cvsroot/ParaView3/ParaView3/Qt/Components/Resources/UI/pqRenderViewOptions.ui,v <-- pqRenderViewOptions.ui initial revision: 1.1 /cvsroot/ParaView3/ParaView3/Qt/Components/Resources/UI/pqSettingsDialog.ui,v <-- pqSettingsDialog.ui new revision: delete; previous revision: 1.2 /cvsroot/ParaView3/ParaView3/Qt/Core/pqRenderView.cxx,v <-- pqRenderView.cxx new revision: 1.21; previous revision: 1.20 /cvsroot/ParaView3/ParaView3/Qt/Core/pqRenderView.h,v <-- pqRenderView.h new revision: 1.12; previous revision: 1.11 |
(0008961) Alan Scott (manager) 2007-09-12 20:03 |
Looks good to me, although I am not positive I understand everywhere I should look. |
2007-08-24 10:11 | Utkarsh Ayachit | New Issue | |
2007-08-24 10:11 | Utkarsh Ayachit | Relationship added | related to 0005005 |
2007-08-24 10:11 | Utkarsh Ayachit | Status | backlog => tabled |
2007-08-24 10:11 | Utkarsh Ayachit | Assigned To | => Clinton Stimpson |
2007-08-24 10:12 | Utkarsh Ayachit | File Added: pq3DViewOptionsWidget.ui | |
2007-08-28 12:56 | Clinton Stimpson | Note Added: 0008712 | |
2007-09-05 14:19 | Clinton Stimpson | Note Added: 0008841 | |
2007-09-05 17:16 | Ken Moreland | Note Added: 0008848 | |
2007-09-06 13:23 | Clinton Stimpson | Status | tabled => @80@ |
2007-09-06 13:23 | Clinton Stimpson | Resolution | open => fixed |
2007-09-06 13:23 | Clinton Stimpson | Note Added: 0008856 | |
2007-09-11 17:58 | Ken Moreland | Relationship added | related to 0005681 |
2007-09-12 20:03 | Alan Scott | Status | @80@ => closed |
2007-09-12 20:03 | Alan Scott | Note Added: 0008961 | |
