0005860 | ParaView | (No Category) | public | 2007-10-10 12:03 | 2009-05-13 13:59 | ||||
Reporter | David Karelitz | ||||||||
Summary | 0005860: (MARS-low) Time value font size is incorrect after applying a lookmark | ||||||||
Description | If you make a lookmark that includes a current time display and then apply that lookmark to a different file, the font size of the time display is too small, and the font size cannot be made larger using the time annotation display tab | ||||||||
(0009415) Ken Moreland (manager) 2007-10-11 13:10 |
This does not sound important enough to try to stuff into 3.2. I will downgrade the priority so that we can address it in 3.4. |
(0009708) David Karelitz (reporter) 2007-11-19 18:29 |
This also happens when loading state |
(0009754) David Karelitz (reporter) 2007-11-26 12:06 |
This appears to be related to the range domain applied to the FontSize property. When a max value is added, the text size appears correctly, but it is still not possible to change the text size. In addition, the following warning is generated (with and without a max value on the FontSize domain): ERROR: In /home/projects/ParaView3-Trunk/ParaView3/VTK/Widgets/vtkAbstractWidget.cxx, line 118 vtkTextWidget (0x1434040): The interactor must be set prior to enabling the widget The widget also cannot be moved interactively without turning off and back on the interactive checkbox. |
(0012072) Alan Scott (manager) 2008-05-22 20:21 |
Tested client/server. I tested lookmarks using can.exo, and save/load state using can.exo. |
2007-10-10 12:03 | David Karelitz | New Issue | |
2007-10-11 13:10 | Ken Moreland | Note Added: 0009415 | |
2007-10-11 13:10 | Ken Moreland | Priority | high => normal |
2007-11-19 18:29 | David Karelitz | Note Added: 0009708 | |
2007-11-19 18:29 | David Karelitz | Summary | Time value font size is incorrect after applying a lookmark => (MARS-low) Time value font size is incorrect after applying a lookmark |
2007-11-26 12:06 | David Karelitz | Note Added: 0009754 | |
2008-03-07 07:56 | Berk Geveci | Target Version | => MARS |
2008-03-07 08:03 | Berk Geveci | Category | Development => 3.4 |
2008-04-15 10:32 | Berk Geveci | Assigned To | => Utkarsh Ayachit |
2008-04-15 10:32 | Berk Geveci | Status | backlog => tabled |
2008-05-22 13:57 | Berk Geveci | Status | tabled => @80@ |
2008-05-22 13:57 | Berk Geveci | Resolution | open => fixed |
2008-05-22 20:21 | Alan Scott | Status | @80@ => closed |
2008-05-22 20:21 | Alan Scott | Note Added: 0012072 | |
2009-05-13 13:58 | Utkarsh Ayachit | Target Version | MARS => 3.4 |
