0007620 | ParaView | (No Category) | public | 2008-09-05 21:15 | 2009-05-13 13:47 | ||||
Summary | 0007620: One click way to get point/cell data into the spreadsheet | ||||||||
Description | It would be really, really nice to be able to click a cell/point and immediately get that data into the spreadsheet view - including point locations at the currently animated time step. Using the Extract Selection filter is not any where near a one click solution. This is often done dozens of times. | ||||||||
(0013321) Alan Scott (manager) 2008-09-05 21:20 |
After writing this feature request, I started playing with the probe filter. This is what I mean, if you didn't need to hit accept between picks. This is close enough that I am changing priority to normal, however. |
(0013322) Alan Scott (manager) 2008-09-05 21:25 |
So, what I want is an Auto Accept button, that only lasts for the life of this filter, on the Probe filter properties panel. |
(0013351) Utkarsh Ayachit (administrator) 2008-09-08 10:29 |
On the display tab (when the spreadsheet view is active) check "Show only selected elements". Then there's no need to create extract selection filter. Simply selecting a different cell (or point) will result in showing only the selected cell/point data in the spreadsheet view. |
(0013496) Alan Scott (manager) 2008-09-17 17:09 |
Last note is correct. Effectively, this was lack of training on the part of the user (me). |
2008-09-05 21:15 | Alan Scott | New Issue | |
2008-09-05 21:20 | Alan Scott | Note Added: 0013321 | |
2008-09-05 21:21 | Alan Scott | Priority | high => normal |
2008-09-05 21:25 | Alan Scott | Note Added: 0013322 | |
2008-09-08 10:29 | Utkarsh Ayachit | Status | backlog => @80@ |
2008-09-08 10:29 | Utkarsh Ayachit | Resolution | open => fixed |
2008-09-08 10:29 | Utkarsh Ayachit | Assigned To | => Utkarsh Ayachit |
2008-09-08 10:29 | Utkarsh Ayachit | Note Added: 0013351 | |
2008-09-17 17:09 | Alan Scott | Status | @80@ => closed |
2008-09-17 17:09 | Alan Scott | Note Added: 0013496 | |
2009-05-13 13:47 | Utkarsh Ayachit | Target Version | => 3.6 |
