0007858 | ParaView | Bug | public | 2008-10-27 11:24 | 2011-01-13 17:00 | ||||
Target Version | Fixed in Version | 3.10 | |||||||
Summary | 0007858: Spacing in Volume Rendering Screenshots | ||||||||
Description | When you save a screenshot of an image volume rendering that is larger than the display, you get spaces in the image of the background color. I suspect these spaces are located where smaller images where stitched together. To replicate, do the following. 1. Create a Wavelet source with the default parameters. 2. Switch to volume rendering. 3. File -> Save Screenshot. When prompted for a screenshot size, enter numbers bigger than the default (the image size drawn in the GUI). Note that this only happens when volume rendering image data to a snapshot that is bigger than the render window. | ||||||||
Attached Files | ![]() | ||||||||
Relationships | ||||||||||||||||
(0013937) Ken Moreland (manager) 2008-10-27 11:28 |
I suspect the problem is that the fixed point volume renderer is not creating images that match up properly with shifted projections or not being stitched together properly. I have seen similar problems with parallel volume rendering. |
(0023290) Utkarsh Ayachit (administrator) 2010-11-16 12:03 |
commit d16e4ccf29acf1dbc7214f0fdeac158d6aa8504c Merge: 0db9e39 644034f Author: Utkarsh Ayachit <utkarsh.ayachit@kitware.com> Date: Tue Nov 16 11:53:40 2010 -0500 Merge topic '7858_fix_large_screenshots' 644034f Ensuring ParaView uses boundary fix when saving screenshots. BUG 0007858. 358e3ad Forwarding VTK to bring in new API for vtkWindowToImageFilter. |
(0023683) Alan Scott (manager) 2010-12-02 16:23 |
Tested windows client, remote server, trunk. |
2008-10-27 11:24 | Ken Moreland | New Issue | |
2008-10-27 11:24 | Ken Moreland | File Added: VolRenSpaces.png | |
2008-10-27 11:28 | Ken Moreland | Note Added: 0013937 | |
2009-02-17 14:38 | Utkarsh Ayachit | Category | 3.6 => Pending |
2009-02-20 14:02 | Ken Moreland | Relationship added | related to 0007837 |
2009-02-20 14:02 | Ken Moreland | Category | Pending => 3.8 |
2009-05-13 13:40 | Utkarsh Ayachit | Target Version | => 3.8 |
2010-02-01 16:58 | Utkarsh Ayachit | Relationship added | has duplicate 0010223 |
2010-02-01 16:59 | Utkarsh Ayachit | Relationship deleted | has duplicate 0010223 |
2010-02-01 16:59 | Utkarsh Ayachit | Relationship added | related to 0010223 |
2010-11-12 14:17 | Dave DeMarle | Assigned To | => Utkarsh Ayachit |
2010-11-12 14:17 | Dave DeMarle | Status | backlog => tabled |
2010-11-12 14:17 | Dave DeMarle | Category | => Bug |
2010-11-12 14:17 | Dave DeMarle | Target Version | 3.8 => 3.10.shortlist |
2010-11-12 14:18 | Dave DeMarle | Relationship replaced | has duplicate 0007837 |
2010-11-16 12:03 | Utkarsh Ayachit | Note Added: 0023290 | |
2010-11-16 12:03 | Utkarsh Ayachit | Status | tabled => @80@ |
2010-11-16 12:03 | Utkarsh Ayachit | Fixed in Version | => 3.10 |
2010-11-16 12:03 | Utkarsh Ayachit | Resolution | open => fixed |
2010-12-02 16:23 | Alan Scott | Note Added: 0023683 | |
2010-12-02 16:23 | Alan Scott | Status | @80@ => closed |
2010-12-14 12:05 | Robert Maynard | Relationship added | related to 0011602 |
2011-01-13 17:00 | Source_changeset_attached | => VTK master a2bd8391 | |
2011-01-13 17:00 | Source_changeset_attached | => VTK master 020ef709 |
