0008409 | ParaView | (No Category) | public | 2009-01-20 11:40 | 2009-08-24 16:30 | ||||
Reporter | Benjamin Schindler | ||||||||
Assigned To | |||||||||
Priority | normal | Severity | crash | Reproducibility | sometimes | ||||
Summary | 0008409: External plugin makes paraview-3.5 crash | ||||||||
Description | Hi I develop my own external plugin for my master thesis. I just updated paraview (With meshless extensions from CSCS) to the latest svn and I get 100% crash when trying to load my filter. I can be 100% certain that my filter works correct in the sense that it loads and runs (I use it in an external application where it works just fine) I've got a backtrace attached. I've noted, that the crash to 90% produces a segmentation fault. However, sometimes I get an illegal instruction. I assume I have a memory corruption here. And just to make things a bit more clear: my constructor just does this: vtkVortexCorelineExtractor::vtkVortexCorelineExtractor() { // Setup default values for the parameters pMinSpinAmount = 1.0; pMinVortexlength = 0.1; pMaxNumSteps = 500; pMaxNumberOfMisses = 3; pMaxVToCoreAngle = 60; // don't change that thing as long UpdateExtent isn't finished pNumInterpolationsBetweenTimeSteps = 0; TracingMethod = 1; } So I for sure can't generate a memory corruption inside my constructor... Since this is my master thesis and the deadline is slowly approaching, a bug fix for this is (to me at least) most urgently needed | ||||||||
Attached Files | backtrace [^] (5,649 bytes) 2009-01-20 11:40 [Show Content] | ||||||||
(0015085) Utkarsh Ayachit (administrator) 2009-02-17 16:41 |
Need more information. Can you reproduce the crash with a simple plugin that you can share? |
(0015480) Benjamin Schindler (reporter) 2009-03-02 03:50 |
I have created a simple plugin quite some time ago - that plugin did absolutely nothing. All it had is a filter class which showed up under the filters menu. But the filter code was in all empty. I tried the same on two different machines, both running gentoo and paraview does not crash there. So this seems like a distro specific thing - I'm running: bschindl@macke /local/bschindler/animations/smooth $ uname -a Linux macke 2.6.18-92.1.22.el5 #1 SMP Fri Dec 5 09:29:46 EST 2008 i686 i686 i386 GNU/Linux Note, the crash does not happen, when I compile the plugin with PARAVIEW_EXTRA_EXTERNAL_PLUGIN I'll try to create such a plugin, but it will look like the most basic textbook example |
(0016755) Benjamin Schindler (reporter) 2009-06-25 11:07 |
okay, I was able to figure out a little bit. It crashes in line 312 of vtkClinetServerInterpreter.cxx I looked at the NewInstanceFunctions array in this->Internal and found the following entries: vtkClientServerID)) 0x2251540 <vtkCommonCS_NewInstance> vtkClientServerID)) 0x75a7790 <vtkFilteringCS_NewInstance> vtkClientServerID)) 0xc973f0 <vtkGenericFilteringCS_NewInstance> vtkClientServerID)) 0x68c6e40 <vtkImagingCS_NewInstance> vtkClientServerID)) 0x703f5b0 <vtkInfovisCS_NewInstance> vtkClientServerID)) 0x78d89f0 <vtkGraphicsCS_NewInstance> vtkClientServerID)) 0x6c9c6f0 <vtkIOCS_NewInstance> vtkClientServerID)) 0x218f020 <vtkRenderingCS_NewInstance> vtkClientServerID)) 0x18ddb60 <vtkVolumeRenderingCS_NewInstance> vtkClientServerID)) 0x18aa790 <vtkHybridCS_NewInstance> vtkClientServerID)) 0x9275a40 <vtkWidgetsCS_NewInstance> vtkClientServerID)) 0x659aa40 <vtkParallelCS_NewInstance> vtkClientServerID)) 0xa31560 <vtkPVServerCommonCS_NewInstance> vtkClientServerID)) 0x37cfdb0 <vtkPVFiltersCS_NewInstance> vtkClientServerID)) 0x776030 <vtkXdmfCS_NewInstance> vtkClientServerID)) 0x332b870 <vtkPVServerManager_NewInstance> vtkClientServerID)) 0x363fc20 <CSCS_Common_SMPlugin_NewInstance> vtkClientServerID)) 0x36c51a0 <CSCS_ESPHI_SMPlugin_NewInstance> vtkClientServerID)) 0x3709fb0 <CSCS_H5Part_SMPlugin_NewInstance> vtkClientServerID)) 0x64e6520 <CSCS_PointSprite_GUIPlugin_NewInstance> vtkClientServerID)) 0x30bdc90 <Moments_NewInstance> elem[21]: $23 = (int (*)(vtkClientServerInterpreter *, const char *, vtkClientServerID)) 0x90ceef0 vtkClientServerID)) 0x62d7ef0 <PrismClientPlugin_NewInstance> vtkClientServerID)) 0x5d76340 <PrismServerPlugin_NewInstance> vtkClientServerID)) 0x380d5f0 <sphvis_NewInstance> See that elem21 - it was not able to resolve it. And it crashes, because I'm trying to instantiate something from sphvis_NewInstance. I checked - it's the first time the iterator needs to loop over item 21 and this is where it crashes. I have yet to figure out which plugin is not loaded/missing. I'll report back once I know more |
(0016756) Benjamin Schindler (reporter) 2009-06-25 11:42 |
Okay, I figured something: The PrismClientPlugin got loaded twice. I set a breakpoint on vtkClientServerInterpreter::AddNewInstanceFunction and item 21 was PrismClientPlugin which was followed by itself once again I surely hope this helps you fix this For completeness, I attach the output of my debugging session: ....... Breakpoint 1, vtkClientServerInterpreter::AddNewInstanceFunction (this=0x9413dc0, f=0x41031a0 <CSCS_ESPHI_SMPlugin_NewInstance>) at /home/bschindl/software/pv-meshless/Utilities/VTKClientServer/vtkClientServerInterpreter.cxx:748 748 } (gdb) c Continuing. Breakpoint 1, vtkClientServerInterpreter::AddNewInstanceFunction (this=0x9413dc0, f=0x5518fb0 <CSCS_H5Part_SMPlugin_NewInstance>) at /home/bschindl/software/pv-meshless/Utilities/VTKClientServer/vtkClientServerInterpreter.cxx:748 748 } (gdb) c Continuing. Breakpoint 1, vtkClientServerInterpreter::AddNewInstanceFunction (this=0x9413dc0, f=0x4752520 <CSCS_PointSprite_GUIPlugin_NewInstance>) at /home/bschindl/software/pv-meshless/Utilities/VTKClientServer/vtkClientServerInterpreter.cxx:748 748 } (gdb) c Continuing. Breakpoint 1, vtkClientServerInterpreter::AddNewInstanceFunction (this=0x9413dc0, f=0x4166c90 <Moments_NewInstance>) at /home/bschindl/software/pv-meshless/Utilities/VTKClientServer/vtkClientServerInterpreter.cxx:748 748 } (gdb) c Continuing. Breakpoint 1, vtkClientServerInterpreter::AddNewInstanceFunction (this=0x9413dc0, f=0x4182ef0 <PrismClientPlugin_NewInstance>) at /home/bschindl/software/pv-meshless/Utilities/VTKClientServer/vtkClientServerInterpreter.cxx:748 748 } (gdb) c Continuing. Breakpoint 1, vtkClientServerInterpreter::AddNewInstanceFunction (this=0x9413dc0, f=0x4182ef0 <PrismClientPlugin_NewInstance>) at /home/bschindl/software/pv-meshless/Utilities/VTKClientServer/vtkClientServerInterpreter.cxx:748 748 } (gdb) c Continuing. Breakpoint 1, vtkClientServerInterpreter::AddNewInstanceFunction (this=0x9413dc0, f=0x60e6340 <PrismServerPlugin_NewInstance>) at /home/bschindl/software/pv-meshless/Utilities/VTKClientServer/vtkClientServerInterpreter.cxx:748 748 } (gdb) c Continuing. Breakpoint 1, vtkClientServerInterpreter::AddNewInstanceFunction (this=0x9413dc0, f=0x6ece5f0 <sphvis_NewInstance>) at /home/bschindl/software/pv-meshless/Utilities/VTKClientServer/vtkClientServerInterpreter.cxx:748 748 } (gdb) c Cheers Benjamin |
(0017191) Alan Scott (manager) 2009-08-24 16:30 |
Resolving, since we don't think this is ParaView's problem. If you feel otherwise, please re-open it. |
2009-01-20 11:40 | Benjamin Schindler | New Issue | |
2009-01-20 11:40 | Benjamin Schindler | File Added: backtrace | |
2009-02-17 16:41 | Utkarsh Ayachit | Note Added: 0015085 | |
2009-02-17 16:41 | Utkarsh Ayachit | Status | backlog => @20@ |
2009-03-02 03:50 | Benjamin Schindler | Note Added: 0015480 | |
2009-06-25 11:07 | Benjamin Schindler | Note Added: 0016755 | |
2009-06-25 11:42 | Benjamin Schindler | Note Added: 0016756 | |
2009-08-24 16:30 | Alan Scott | Note Added: 0017191 | |
2009-08-24 16:30 | Alan Scott | Status | @20@ => closed |
2009-08-24 16:30 | Alan Scott | Resolution | open => fixed |
