0009828 | ParaView | (No Category) | public | 2009-11-03 08:49 | 2016-08-12 09:57 | ||||
Reporter | Christine Corbett Moran | ||||||||
Summary | 0009828: If there are a numer of file list domains for a given reader, the main data file is decided be the alphabetically first name | ||||||||
Description | I found that when one has specified multiple file list domains in the server XML, ParaView decides which one is the "main" file (i.e. the one specified with the --data= flag at the command line or the first file selected in a reader) by the name of the string attribute which is a file list domain which is alphabetically first. It would be nice if there was a way to manually specify which file should be the main file, or if this behavior was more explicit. | ||||||||
(0037742) Kitware Robot (administrator) 2016-08-12 09:57 |
2009-11-03 08:49 | Christine Corbett Moran | New Issue | |
2009-12-09 14:49 | Berk Geveci | Project | @3@ => ParaView |
2016-08-12 09:57 | Kitware Robot | Note Added: 0037742 | |
2016-08-12 09:57 | Kitware Robot | Assigned To | => Kitware Robot |
