0013832ParaView(No Category)public2013-01-29 18:222016-08-12 09:59
ReporterAlan Scott
Assigned ToKitware Robot
StatusclosedResolutionmoved
PlatformOSOS Version
Product Versiongit-master
Summary0013832: ProgressHandler - Cell to Point is broken
DescriptionProgress handler code in Cell to Point is broken. In file vtkCellDataToPointData.cxx, function vtkCellDataToPointData::RequestData(), update progress gets called many dozens of times (speculation is once per block, which could be millions of times). Each time this code dutifully bounces the UpdateProgress(progress) call from 0.0 to 1.0, in increments of 0.05. I am not even going to try a fix.
Suggested hack would be to comment out the UpdateProgress.
vtkCellDataToPointData.cxx, line 106, should change from:
      this->UpdateProgress(static_cast<double>(ptId)/numPts);
to
      //this->UpdateProgress(static_cast<double>(ptId)/numPts);
TagsNo tags attached.
ProjectSandia
Topic Name0013832-Fix-ProgressHandler-CellToPoint
Typeincorrect functionality
 Relationships
child of 0013831closedKitware Robot Master bug - Progress Handler is a mess
  Notes
(0030316)
2013-02-06 18:35
The fix involves changes to vtkAlgorithm/vtkCompositeDataPipeline to ensure that progress is reported correctly when the executive loops over datasets in a composite.
(0038323)
Kitware Robot (administrator)
2016-08-12 09:59
Resolving issue as `moved`.
 Issue History
2013-01-29 18:22 Alan Scott New Issue
2013-01-29 21:48 Alan Scott Relationship added child of 0013831
2013-02-06 18:34 Utkarsh Ayachit Assigned To => Nikhil Shetty
2013-02-06 18:35 Utkarsh Ayachit Note Added: 0030316
2013-02-19 10:22 Nikhil Shetty Status backlog => todo
2013-02-20 11:59 Nikhil Shetty Topic Name => 0013832-Fix-ProgressHandler-CellToPoint
2013-02-20 11:59 Nikhil Shetty Status todo => active development
2013-06-05 16:33 Nikhil Shetty Assigned To Nikhil Shetty =>
2013-06-05 16:34 Nikhil Shetty Status active development => todo
2013-06-05 16:41 Nikhil Shetty Status todo => backlog
2016-08-12 09:59 Kitware Robot Note Added: 0038323
2016-08-12 09:59 Kitware Robot Status backlog => closed
2016-08-12 09:59 Kitware Robot Resolution open => moved
2016-08-12 09:59 Kitware Robot Assigned To => Kitware Robot
