0008684ParaViewBugpublic2009-03-06 11:282016-08-12 09:57
ReporterKen Moreland
Assigned ToMarcus D. Hanwell
StatusclosedResolutionmoved
PlatformOSOS Version
Product Version
Summary0008684: Too many button clicks to adjust axes in plots
DescriptionIn the x-y plot and bar chart views, it is a very common operation to adjust the range of the axes. I would say it is more common to adjust them than to not. However, it takes a heck of a lot of button clicks to get to the axes adjustments. (Open view settings, open settings for axes, click on the Layout sub menu, spend several more clicks actually doing the settings, then repeat everything for the other axis.) You should be able to adjust the axes with only a few button clicks.
TagsNo tags attached.
ProjectSandia
Topic Name
Typeincorrect functionality
 Relationships
child of 0008596closedUtkarsh Ayachit (Venus - Medium) Ability to set time series plots with data from all time steps
  Notes
(0015592)
Ken Moreland (manager)
2009-03-06 11:31
Utkarsh, I set bug for 3.6 because I know you are working on new GUI for the new charts right now. Try to keep this issue in mind as you create the new GUI. If some needs to be delayed to 3.8, that should be fine.
(0037629)
Kitware Robot (administrator)
2016-08-12 09:57
Resolving issue as `moved`.
 Issue History
2009-03-06 11:28 Ken Moreland New Issue
2009-03-06 11:28 Ken Moreland Relationship added child of 0008596
2009-03-06 11:28 Ken Moreland Status backlog => tabled
2009-03-06 11:28 Ken Moreland Assigned To => Utkarsh Ayachit
2009-03-06 11:31 Ken Moreland Note Added: 0015592
2009-05-13 13:46 Utkarsh Ayachit Target Version => 3.6
2009-05-14 20:39 Utkarsh Ayachit Category => Bug
2009-05-14 20:39 Utkarsh Ayachit Target Version 3.6 => 3.8
2011-01-21 13:50 Utkarsh Ayachit Assigned To Utkarsh Ayachit => Marcus D. Hanwell
2011-01-21 13:50 Utkarsh Ayachit Target Version 3.8 => 4.0
2013-01-08 21:32 Alan Scott Project => Sandia
2013-01-08 21:32 Alan Scott Type => incorrect functionality
2016-08-12 09:57 Kitware Robot Note Added: 0037629
2016-08-12 09:57 Kitware Robot Status backlog => closed
2016-08-12 09:57 Kitware Robot Resolution open => moved
