1 #define _paraview_add_plugin_built_shared 1 2 #define _paraview_add_plugin_with_initializers 0 3 #define _paraview_add_plugin_with_python 0 4 #define _paraview_add_plugin_with_ui 1 5 #define _paraview_add_plugin_with_xml 0 7 #define PARAVIEW_BUILDING_PLUGIN 8 #define PARAVIEW_PLUGIN_BUILT_SHARED _paraview_add_plugin_built_shared 11 #if _paraview_add_plugin_with_ui 17 #if _paraview_add_plugin_with_xml 21 #if _paraview_add_plugin_with_python 25 #if _paraview_add_plugin_with_initializers 30 #if _paraview_add_plugin_with_ui 37 #if _paraview_add_plugin_with_initializers 40 #if _paraview_add_plugin_with_xml 43 #if _paraview_add_plugin_with_python 48 #if _paraview_add_plugin_with_ui 51 Q_PLUGIN_METADATA(IID
"com.kitware/paraview/SaveStateAndScreenshotPlugin")
60 {
return "SaveStateAndScreenshot"; }
90 {
return "Saves the ParaView state and a screenshot without any user interaction"; }
104 #if _paraview_add_plugin_with_xml 108 void GetXMLs(std::vector<std::string> &xmls)
override;
116 GetInitializeInterpreterCallback()
override;
119 #if _paraview_add_plugin_with_ui 126 #if _paraview_add_plugin_with_python 127 void GetPythonSourceList(std::vector<std::string>& modules,
128 std::vector<std::string>& sources,
129 std::vector<int>& package_flags)
override;
132 #if _paraview_add_plugin_with_initializers 133 void Initialize()
override;
bool GetRequiredOnServer() override
bool GetRequiredOnClient() override
QObjectList interfaces() override
Returns the list of ParaView-Interfaces provided by this plugin.
SaveStateAndScreenshotPlugin()
