vtkClientServerInterpreterInitializer initializes and maintains the global vtkClientServerInterpreter instance for the processes. More...
#include <vtkClientServerInterpreterInitializer.h>
typedef void(* | InterpreterInitializationCallback) (vtkClientServerInterpreter *) |
vtkClientServerInterpreter * | NewInterpreter () |
Creates (and registers) a new interpreter. More... | |
void | RegisterCallback (InterpreterInitializationCallback callback) |
Use this method register an interpreter initializer function. More... | |
virtual void | Modified () |
static vtkClientServerInterpreterInitializer * | SafeDownCast (vtkObject *o) |
static vtkClientServerInterpreter * | GetGlobalInterpreter () |
Get the interpreter for this process. More... | |
static vtkClientServerInterpreterInitializer * | GetInitializer () |
Provides access to the singleton. More... | |
static vtkObject * | New () |
vtkClientServerInterpreterInitializer () | |
~vtkClientServerInterpreterInitializer () override | |
void | RegisterInterpreter (vtkClientServerInterpreter *) |
Registers an interpreter. More... | |
vtkObject () | |
virtual | ~vtkObject () |
vtkObjectBase () | |
virtual | ~vtkObjectBase () |
Static Protected Member Functions | |
static vtkClientServerInterpreterInitializer * | New () |
bool | Debug |
vtkTimeStamp | MTime |
Use RegisterCallback() to register initialization routines for the interpreter. Use GetInterpreter() to access the interpreter.
This class was originally designed to support and maintain multiple interpreter instances. However ParaView no longer has need for that and hence that functionality is no longer made public.
Definition at line 24 of file vtkClientServerInterpreterInitializer.h.
Definition at line 27 of file vtkClientServerInterpreterInitializer.h.
typedef void(* vtkClientServerInterpreterInitializer::InterpreterInitializationCallback) (vtkClientServerInterpreter *) |
Definition at line 51 of file vtkClientServerInterpreterInitializer.h.
vtkClientServerInterpreter* vtkClientServerInterpreterInitializer::NewInterpreter | ( | ) |
Initializing a new interpreter is expensive. So filters that need to use interpreter temporarily to call methods on a vtkObject can simply use the global interpreter. As a rule, if you need to assign ID's to objects, then you're probably better off creating a new interpreter using NewInterpreter() and using it rather than the global interpreter.
This will instantiate vtkClientServerInterpreterInitializer the first time it is called.
void vtkClientServerInterpreterInitializer::RegisterCallback | ( | InterpreterInitializationCallback | callback | ) |
Registering such a callback makes it possible to initialize interpreters created in the lifetime of the application, including those that have already been created (but not destroyed). One cannot unregister a callback. The only reason for doing so would be un-loading a plugin, but that's not supported and never will be :).
staticprotected |
This DOES NOT affect the reference count of the interpreter (hence there's no UnRegister).
