Public Slots | Public Member Functions | Protected Slots | List of all members
pqAnimatablePropertiesComboBox Class Reference
pqAnimatablePropertiesComboBox is a combo box that can list the animatable properties of any proxy. More...
#include <pqAnimatablePropertiesComboBox.h>
Inherits QComboBox.
Public Slots
void setSource (vtkSMProxy *proxy)
 Set the source whose properties this widget should list. More...
void setSourceWithoutProperties (vtkSMProxy *proxy)
 Set source without calling buildPropertyList() internally. More...
void setCollapseVectors (bool val)
 If true, vector properties will have a single entry. More...
void setVectorSizeFilter (int size)
 This class can filter the displayed properties to only show those with a specified number of components. More...
void addSMProperty (const QString &label, const QString &propertyname, int index)
 Add a property to the widget. More...
 pqAnimatablePropertiesComboBox (QWidget *parent=nullptr)
 ~pqAnimatablePropertiesComboBox () override
vtkSMProxygetCurrentProxy () const
QString getCurrentPropertyName () const
int getCurrentIndex () const
bool getCollapseVectors () const
int getVectorSizeFilter () const
void setUseBlankEntry (bool b)
 Sometimes, we want the combo to show a empty field that does not represent any property. More...
Protected Slots
void buildPropertyList ()
 Builds the property list. More...
Definition at line 16 of file pqAnimatablePropertiesComboBox.h.
◆ pqAnimatablePropertiesComboBox()
pqAnimatablePropertiesComboBox::pqAnimatablePropertiesComboBox ( QWidget *  parent = nullptr)
◆ ~pqAnimatablePropertiesComboBox()
pqAnimatablePropertiesComboBox::~pqAnimatablePropertiesComboBox ( )
override
◆ getCurrentProxy()
vtkSMProxy* pqAnimatablePropertiesComboBox::getCurrentProxy ( ) const
◆ getCurrentPropertyName()
QString pqAnimatablePropertiesComboBox::getCurrentPropertyName ( ) const
◆ getCurrentIndex()
int pqAnimatablePropertiesComboBox::getCurrentIndex ( ) const
◆ getCollapseVectors()
bool pqAnimatablePropertiesComboBox::getCollapseVectors ( ) const
If false, each vector component will be displayed separately. Default: false.
◆ getVectorSizeFilter()
int pqAnimatablePropertiesComboBox::getVectorSizeFilter ( ) const
Returns the current filter settings. -1 means no filtering (default).
◆ setUseBlankEntry()
void pqAnimatablePropertiesComboBox::setUseBlankEntry ( bool  b)
inline
Set this to true to use such a field.
Definition at line 46 of file pqAnimatablePropertiesComboBox.h.
◆ setSource
void pqAnimatablePropertiesComboBox::setSource ( vtkSMProxy proxy)
slot
If source is null, the widget gets disabled.
◆ setSourceWithoutProperties
void pqAnimatablePropertiesComboBox::setSourceWithoutProperties ( vtkSMProxy proxy)
slot
Thus the user will explicitly call addSMProperty to add properties.
◆ setCollapseVectors
void pqAnimatablePropertiesComboBox::setCollapseVectors ( bool  val)
slot
◆ setVectorSizeFilter
void pqAnimatablePropertiesComboBox::setVectorSizeFilter ( int  size)
slot
Set the current filter setting. -1 means no filtering (default).
◆ addSMProperty
void pqAnimatablePropertiesComboBox::addSMProperty ( const QString &  label,
const QString &  propertyname,
int  index
slot
◆ buildPropertyList
void pqAnimatablePropertiesComboBox::buildPropertyList ( )
protectedslot
