add context menu items to control block appearance properties. More...
#include <pqBlockContextMenu.h>
pqBlockContextMenu (QObject *parent=nullptr) | |
~pqBlockContextMenu () override | |
bool | contextMenu (QMenu *menu, pqView *viewContext, const QPoint &viewPoint, pqRepresentation *dataContext, const QStringList &dataBlockContext) const override |
This is a newer variant of the contextMenu where the dataBlockContext is provided as selectors instead of composite ids. More... | |
int | priority () const override |
This method's return value is used to set the precedence of the interface. More... | |
pqContextMenuInterface () | |
virtual | ~pqContextMenuInterface () |
virtual bool | contextMenu (QMenu *menu, pqView *viewContext, const QPoint &viewPoint, pqRepresentation *dataContext, const QList< unsigned int > &dataBlockContext) const |
This method is called when a context menu is requested, usually by a right click in a pqView instance. More... | |
pqBlockContextMenu is a concrete implementation of the pqContextMenuInterface that add context-menu actions to control display properties for chosen blocks. This is currently only supported for render view.
Definition at line 19 of file pqBlockContextMenu.h.
pqBlockContextMenu::pqBlockContextMenu | ( | QObject * | parent = nullptr | ) |
Selectors are more reliable especially when dealing with partitioned datasets and their collections in distributed mode and hence should be preferred.
Reimplemented from pqContextMenuInterface.
inlineoverridevirtual |
Interfaces with greater priority are invoked before others and may cause menu-building to terminate early. ParaView's default context-menu interface uses a priority of 0 and returns false.
If you wish to modify the default menu, assign a negative priority to your interface. If you wish to override the default menu, assign a positive priority to your interface and have contextMenu()
return true.
Definition at line 35 of file pqBlockContextMenu.h.
