Public Types | Public Slots | Public Member Functions | Static Public Member Functions | Protected Member Functions | List of all members
pqDeleteReaction Class Reference
Reaction for delete sources (all or selected only). More...
#include <pqDeleteReaction.h>
Inheritance diagram for pqDeleteReaction:
Collaboration diagram for pqDeleteReaction:
enum  DeleteModes { SELECTED, ALL, TREE }
Public Slots
void updateEnableState () override
 Updates the enabled state. More...
void deleteSource (pqProxy *source)
 Request deletion of a particular source. More...
 pqDeleteReaction (QAction *parent, DeleteModes mode=SELECTED)
 if delete_all is false, then only selected items will be deleted if possible. More...
- Public Member Functions inherited from pqReaction
 pqReaction (QAction *parent, Qt::ConnectionType type=Qt::AutoConnection)
 Constructor. More...
 ~pqReaction () override
QAction * parentAction () const
 Provides access to the parent action. More...
static void deleteAll ()
static void deleteSelected ()
static bool canDeleteSelected ()
static void deleteTree ()
static bool canDeleteTree ()
static void deleteSources (const QSet< pqProxy *> &sources)
 Deletes all sources in the set, if possible. More...
void onTriggered () override
 Called when the action is triggered. More...
- Protected Slots inherited from pqReaction
virtual void updateEnableState ()
virtual void updateMasterEnableState (bool)
- Protected Attributes inherited from pqReaction
bool IsMaster
Definition at line 16 of file pqDeleteReaction.h.
◆ DeleteModes
Enumerator
SELECTED
ALL
TREE
Definition at line 22 of file pqDeleteReaction.h.
◆ pqDeleteReaction()
pqDeleteReaction::pqDeleteReaction ( QAction *  parent,
DeleteModes  mode = SELECTED
◆ deleteAll()
static void pqDeleteReaction::deleteAll ( )
◆ deleteSelected()
static void pqDeleteReaction::deleteSelected ( )
◆ canDeleteSelected()
static bool pqDeleteReaction::canDeleteSelected ( )
◆ deleteTree()
static void pqDeleteReaction::deleteTree ( )
◆ canDeleteTree()
static bool pqDeleteReaction::canDeleteTree ( )
◆ deleteSources()
static void pqDeleteReaction::deleteSources ( const QSet< pqProxy *> &  sources)
All variants of public methods on this class basically call this method with the sources set built up appropriately. The sources set is modified to remove all deleted sources. Any undeleted sources will remain in the set.
◆ updateEnableState
void pqDeleteReaction::updateEnableState ( )
overrideslot
◆ deleteSource
void pqDeleteReaction::deleteSource ( pqProxy source)
slot
◆ onTriggered()
void pqDeleteReaction::onTriggered ( )
overrideprotectedvirtual
