Customize pqDoubleSliderWidget to use a custom set of allowed values. More...
#include <pqDiscreteDoubleWidget.h>
pqDiscreteDoubleWidget (QWidget *parent=nullptr) | |
~pqDiscreteDoubleWidget () override | |
std::vector< double > | values () const |
Gets vector of allowed values. More... | |
void | setValues (std::vector< double > values) |
pqDoubleSliderWidget (QWidget *parent=nullptr) | |
~pqDoubleSliderWidget () override | |
double | value () const |
get the value More... | |
pqDoubleLineEdit::RealNumberNotation | notation () const |
Return the notation used to display the number. More... | |
int | precision () const |
Return the precision used to display the number. More... | |
bool | useGlobalPrecisionAndNotation () const |
useGlobalPrecisionAndNotation indicates if the pqDoubleLineEdit used by this widget should use global precision and notation values instead of the parameters specified on this instance. More... | |
int | valueToSliderPos (double val) override |
double | sliderPosToValue (int pos) override |
void | setValidator (QDoubleValidator *validator) |
const QDoubleValidator * | validator () const |
void | setSliderRange (int min, int max) |
void | updateSlider () |
Properties | |
double | value |
double | value |
pqDoubleLineEdit::RealNumberNotation | notation |
int | precision |
bool | useGlobalPrecisionAndNotation |
void | setValue (double val) |
set the value More... | |
void | setNotation (pqDoubleLineEdit::RealNumberNotation _notation) |
Set the notation used to display the number. More... | |
void | setPrecision (int precision) |
Set the precision used to display the number. More... | |
void | setUseGlobalPrecisionAndNotation (bool value) |
Set whether to use global precision and notation values. More... | |
void | valueChanged (double) |
signal the value changed More... | |
void | valueEdited (double) |
signal the value was edited this means the user is done changing text or the user is done moving the slider. More... | |
Definition at line 14 of file pqDiscreteDoubleWidget.h.
pqDiscreteDoubleWidget::pqDiscreteDoubleWidget | ( | QWidget * | parent = nullptr | ) |
std::vector<double> pqDiscreteDoubleWidget::values | ( | ) | const |
void pqDiscreteDoubleWidget::setValues | ( | std::vector< double > | values | ) |
Reimplemented from pqDoubleSliderWidget.
readwrite |
Definition at line 18 of file pqDiscreteDoubleWidget.h.
