int | Undo () override |
| Undo the operation encapsulated by this element. More...
int | Redo () override |
| Redo the operation encaspsulated by this element. More...
void | MadeUnmodified (pqProxy *) |
| Use this to initialize the element if the pqProxy was marked as UNMODIFIED. More...
void | MadeUninitialized (pqProxy *) |
| Use this to initialize the element if the pqProxy was marked as UNINITIALIZED. More...
virtual bool | Merge (vtkUndoElement *vtkNotUsed(new_element)) |
| Called on the older element in the UndoSet to merge with the element being added if both the elements are mergeable . More...
virtual void | SetUndoSetWorkingContext (vtkCollection *workCTX) |
virtual bool | GetMergeable () |
| Returns if this undo element can be merged with other undo elements. More...
virtual void | Modified () |
