Public Member Functions | Protected Member Functions | Friends | List of all members
pqProxyWidgetDialog Class Reference
pqProxyWidgetDialog is used to show properties of any proxy in a dialog. More...
#include <pqProxyWidgetDialog.h>
Inherits QDialog.
 pqProxyWidgetDialog (vtkSMProxy *proxy, QWidget *parent=nullptr, Qt::WindowFlags f=Qt::WindowFlags{})
 pqProxyWidgetDialog (vtkSMProxy *proxy, const QStringList &properties, QWidget *parent=nullptr, Qt::WindowFlags f=Qt::WindowFlags{})
 ~pqProxyWidgetDialog () override
bool hasVisibleWidgets () const
 Returns whether that dialog has any visible widgets. More...
bool hasAdvancedProperties () const
 Returns true if the proxy has any advanced properties. More...
vtkSMProxyproxy () const
 Returns the proxy. More...
void setEnableSearchBar (bool val)
 Get/set whether the search-bar should be shown on the dialog. More...
bool enableSearchBar () const
void setHideAdvancedProperties (bool val)
 By default, the pqProxyWidgetDialog will show advanced properties on the proxy either by default (if EnableSearchBar is false), or based on the ui-element in search bar (if EnableSearchBar is true). More...
bool hideAdvancedProperties () const
void setApplyChangesImmediately (bool val)
 When set to true (default is false), pqProxyWidgetDialog will not show the 'Apply' and 'Reset' buttons. More...
bool applyChangesImmediately () const
QString setSettingsKey (const QString &key)
 Set the new setting key that will be used to restore/save the advanced button check state. More...
void showEvent (QShowEvent *event) override
 Overridden to resize widget before showing it the first time. More...
void hideEvent (QHideEvent *event) override
void done (int r) override
Friends
class pqInternals
It simply wraps the pqProxyWidget for the proxy in a dialog with Apply, Cancel, and Ok buttons. Tool buttons (QPushButtons with only icons) are also provided to save the currently applied settings as default properties as well as to reset the defaults to the application defaults.
Definition at line 19 of file pqProxyWidgetDialog.h.
◆ pqProxyWidgetDialog() [1/2]
pqProxyWidgetDialog::pqProxyWidgetDialog ( vtkSMProxy proxy,
QWidget *  parent = nullptr,
Qt::WindowFlags  f = Qt::WindowFlags{}
◆ pqProxyWidgetDialog() [2/2]
const QStringList &  properties,
◆ ~pqProxyWidgetDialog()
pqProxyWidgetDialog::~pqProxyWidgetDialog ( )
override
◆ hasVisibleWidgets()
bool pqProxyWidgetDialog::hasVisibleWidgets ( ) const
◆ hasAdvancedProperties()
bool pqProxyWidgetDialog::hasAdvancedProperties ( ) const
This may be useful to determine if the search bar should be enabled or not.
◆ proxy()
vtkSMProxy* pqProxyWidgetDialog::proxy ( ) const
Returns the proxy.
◆ setEnableSearchBar()
void pqProxyWidgetDialog::setEnableSearchBar ( bool  val)
Default is false. If search-bar is not enabled, the dialog cannot support default/advanced viewing modes either and hence it will simply show all property widgets.
◆ enableSearchBar()
bool pqProxyWidgetDialog::enableSearchBar ( ) const
◆ setHideAdvancedProperties()
void pqProxyWidgetDialog::setHideAdvancedProperties ( bool  val)
However, there may be cases when an application doesn't want to show the advanced properties. In that case, you can use this method to hide all advanced properties. If EnableSearchBar is true and HideAdvancedProperties is false, then the gear-icon shown next to search bar to allow user to toggle the advanced properties is not shown.
◆ hideAdvancedProperties()
bool pqProxyWidgetDialog::hideAdvancedProperties ( ) const
◆ setApplyChangesImmediately()
void pqProxyWidgetDialog::setApplyChangesImmediately ( bool  val)
This has one major implication, however. Whenever the user changes a widget in the UI, the corresponding property on the proxy will immediately be changed. Thus, even if the user hits 'Cancel', the proxy will be left in modified state.
◆ applyChangesImmediately()
bool pqProxyWidgetDialog::applyChangesImmediately ( ) const
◆ setSettingsKey()
QString pqProxyWidgetDialog::setSettingsKey ( const QString &  key)
If the given key is valid (i.e. not empty), the button state will be restored from the key value. The old key is left unchanged in the setting to whatever its last value was. Although returned, removing (or not) the old key is up to the user.
See also
settingKey property
◆ showEvent()
void pqProxyWidgetDialog::showEvent ( QShowEvent *  event)
◆ hideEvent()
void pqProxyWidgetDialog::hideEvent ( QHideEvent *  event)
◆ done()
void pqProxyWidgetDialog::done ( int  r)
◆ pqInternals
friend class pqInternals
friend
Definition at line 113 of file pqProxyWidgetDialog.h.
