abstract interface used to load recently used resources. More...
#include <pqRecentlyUsedResourceLoaderInterface.h>
| virtual | ~pqRecentlyUsedResourceLoaderInterface () |
| virtual bool | canLoad (const pqServerResource &resource)=0 |
| Return true of the interface supports loading the given resource. More... | |
| virtual bool | load (const pqServerResource &resource, pqServer *server)=0 |
| Loads the resource and returns the true if successfully loaded, otherwise false. More... | |
| virtual QIcon | icon (const pqServerResource &resource) |
| Return an icon, if any, to use for the resource. More... | |
| virtual QString | label (const pqServerResource &resource)=0 |
| Return label to use for the resource. More... | |
| pqRecentlyUsedResourceLoaderInterface () | |
pqRecentlyUsedResourceLoaderInterface provides the interface for code that handles loading of recently used resources typically maintained in pqRecentlyUsedResourcesList. pqRecentFilesMenu uses implementations of this interface to determine the action to trigger when user clicks on a specific resource in the menu.
Definition at line 27 of file pqRecentlyUsedResourceLoaderInterface.h.
pure virtual |
Implemented in pqStandardRecentlyUsedResourceLoaderImplementation.
pure virtual |
If returned false, the resource is treated as defunct and may be removed. from the recent list.
Default implementation simply returns an empty QIcon.
Reimplemented in pqStandardRecentlyUsedResourceLoaderImplementation.
pure virtual |
1.8.13 on Fri Aug 1 2025
