support loading states, and data files when loaded from pqRecentFilesMenu. More...
#include <pqStandardRecentlyUsedResourceLoaderImplementation.h>
pqStandardRecentlyUsedResourceLoaderImplementation (QObject *parent=nullptr) | |
~pqStandardRecentlyUsedResourceLoaderImplementation () override | |
bool | canLoad (const pqServerResource &resource) override |
Return true of the interface supports loading the given resource. More... | |
bool | load (const pqServerResource &resource, pqServer *server) override |
Loads the resource and returns the true if successfully loaded, otherwise false. More... | |
QIcon | icon (const pqServerResource &resource) override |
Return an icon, if any, to use for the resource. More... | |
QString | label (const pqServerResource &resource) override |
Return label to use for the resource. More... | |
virtual | ~pqRecentlyUsedResourceLoaderInterface () |
static bool | addDataFilesToRecentResources (pqServer *server, const QStringList &files, const QString &smgroup, const QString &smname) |
Add data files(s) to the recently used resources list. More... | |
static bool | addStateFileToRecentResources (pqServer *server, const QString &file, vtkTypeUInt32 location=0x10) |
Add state file to the recently used resources list. More... | |
pqRecentlyUsedResourceLoaderInterface () | |
pqStandardRecentlyUsedResourceLoaderImplementation is an implementation of the pqRecentlyUsedResourceLoaderInterface that support loading resources known to ParaView e.g. data files and state files. pqParaViewBehaviors
instantiates this unless pqParaViewBehaviors::enableStandardRecentlyUsedResourceLoader
is false.
Definition at line 26 of file pqStandardRecentlyUsedResourceLoaderImplementation.h.
pqStandardRecentlyUsedResourceLoaderImplementation::pqStandardRecentlyUsedResourceLoaderImplementation | ( | QObject * | parent = nullptr | ) |
Implements pqRecentlyUsedResourceLoaderInterface.
If returned false, the resource is treated as defunct and may be removed. from the recent list.
Default implementation simply returns an empty QIcon.
Reimplemented from pqRecentlyUsedResourceLoaderInterface.
