Public Member Functions | List of all members
pqSingleLogViewerWidget Class Reference
A single log viewer widget which has a reference to the log recorder proxy. More...
#include <pqSingleLogViewerWidget.h>
Inheritance diagram for pqSingleLogViewerWidget:
Collaboration diagram for pqSingleLogViewerWidget:
 pqSingleLogViewerWidget (QWidget *parent, vtkSmartPointer< vtkSMProxy > logRecorderProxy, int rank)
 ~pqSingleLogViewerWidget () override=default
void refresh ()
 Refresh the log viewer. More...
const vtkSmartPointer< vtkSMProxy > & getLogRecorderProxy () const
 Get the log recorder proxy reference hold by this widget. More...
int getRank () const
 Get the rank of the process whose log is shown in this widget. More...
void closeEvent (QCloseEvent *) override
 Disable log recording of the specific rank when the widget is closed. More...
- Public Member Functions inherited from pqLogViewerWidget
 pqLogViewerWidget (QWidget *parent=nullptr)
 ~pqLogViewerWidget () override
void setLog (const QString &text)
 Set the contents of the log viewer to the provided txt. More...
void appendLog (const QString &text)
 Append text to log. More...
void setFilterWildcard (QString wildcard)
 Manually set the filter wildcard. More...
void scrollToTime (double time)
 Scroll to the log near the specific time. More...
void updateColumnVisibilities ()
 Update log table column visibilities. More...
- Signals inherited from pqLogViewerWidget
void closed ()
void scrolled (double time)
- Static Public Member Functions inherited from pqLogViewerWidget
static QVector< QString > extractLogParts (const QString &txt, bool &is_raw)
 Utility function to parse a line of log into parts. More...
- Protected Slots inherited from pqLogViewerWidget
void toggleAdvanced ()
void exportLog ()
Definition at line 18 of file pqSingleLogViewerWidget.h.
◆ pqSingleLogViewerWidget()
pqSingleLogViewerWidget::pqSingleLogViewerWidget ( QWidget *  parent,
vtkSmartPointer< vtkSMProxy logRecorderProxy,
int  rank
Parameters
parentThe parent of this widget.
logRecorderProxyhas the information of server location, and the rank setting indicates which rank whose log is shown in this widget.
rank
◆ ~pqSingleLogViewerWidget()
pqSingleLogViewerWidget::~pqSingleLogViewerWidget ( )
overridedefault
◆ refresh()
void pqSingleLogViewerWidget::refresh ( )
◆ getLogRecorderProxy()
const vtkSmartPointer<vtkSMProxy>& pqSingleLogViewerWidget::getLogRecorderProxy ( ) const
◆ getRank()
int pqSingleLogViewerWidget::getRank ( ) const
◆ closeEvent()
void pqSingleLogViewerWidget::closeEvent ( QCloseEvent *  )
override
