Public Slots | Signals | Public Member Functions | Protected Slots | Protected Member Functions | List of all members
pqTransferFunctionWidget Class Reference
pqTransferFunctionWidget provides a widget that can edit the control points in a vtkPiecewiseFunction or a vtkScalarsToColors (or subclass) or both. More...
#include <pqTransferFunctionWidget.h>
Inherits QWidget.
Public Slots
void setCurrentPoint (vtkIdType index)
 Set the current point. More...
void setCurrentPointPosition (double xpos)
 Set the X-position for the current point (without changing the Y position, if applicable. More...
void render ()
 re-renders the transfer function view. More...
void setHistogramTable (vtkTable *table)
 Set the histogram table to display as a plot bar. More...
Signals
void currentPointChanged (vtkIdType index)
 signal fired when the current selected control point changes. More...
void controlPointsModified ()
 signal fired to indicate that the control points changed i.e. More...
void chartRangeModified ()
 signal fired when the chart range is modified. More...
void rangeHandlesRangeChanged (double rangeMin, double rangeMax)
 signal fired when the range handles changed the range. More...
void rangeHandlesDoubleClicked ()
 signal fired when the range handles are double clicked. More...
 pqTransferFunctionWidget (QWidget *parent=nullptr)
 ~pqTransferFunctionWidget () override
void initialize (vtkScalarsToColors *stc, bool stc_editable, vtkPiecewiseFunction *pwf, bool pwf_editable)
 Initialize the pqTransferFunctionWidget with the given color-transfer-function and piecewise-function (either of which can be null). More...
vtkIdType currentPoint () const
 Returns the current point index. More...
vtkIdType numberOfControlPoints () const
 Returns the number of control points in the editor widget. More...
void SetLogScaleXAxis (bool logScale)
 Switches the chart to use a log scaled X axis. More...
bool GetLogScaleXAxis () const
vtkScalarsToColorsscalarsToColors () const
 Provides access to vtkScalarsToColors and vtkPiecewiseFunction passed to initialize. More...
vtkPiecewiseFunctionpiecewiseFunction () const
void SetControlPointsFreehandDrawing (bool use)
 Set/Get the use of freehand drawing for the control points. More...
bool GetControlPointsFreehandDrawing () const
Protected Slots
void onCurrentChangedEvent ()
 slot called when the internal vtkControlPointsItem fires vtkControlPointsItem::CurrentPointChangedEvent More...
void onRangeHandlesRangeChanged ()
 slot called when the internal vtkRangeHandlesItem fires a vtkRangeHandlesItem::RangeHandlesRangeChanged More...
void showUsageStatus ()
 Show usage info in the application status bar. More...
void editColorAtCurrentControlPoint ()
 Show color dialog to edit color for a specific control point. More...
void onCurrentPointEditEvent ()
 callback called when vtkControlPointsItem fires vtkControlPointsItem::CurrentPointEditEvent. More...
It is used by pqColorOpacityEditorWidget, for example, to show transfer function editors for color and opacity for a PVLookupTable proxy.
Definition at line 21 of file pqTransferFunctionWidget.h.
◆ pqTransferFunctionWidget()
pqTransferFunctionWidget::pqTransferFunctionWidget ( QWidget *  parent = nullptr)
◆ ~pqTransferFunctionWidget()
pqTransferFunctionWidget::~pqTransferFunctionWidget ( )
override
◆ initialize()
void pqTransferFunctionWidget::initialize ( vtkScalarsToColors stc,
bool  stc_editable,
vtkPiecewiseFunction pwf,
bool  pwf_editable
The editable flags are used to control if the users should be allowed to edit/change the particular transfer function.
◆ currentPoint()
vtkIdType pqTransferFunctionWidget::currentPoint ( ) const
-1 is none is selected.
◆ numberOfControlPoints()
vtkIdType pqTransferFunctionWidget::numberOfControlPoints ( ) const
◆ SetLogScaleXAxis()
void pqTransferFunctionWidget::SetLogScaleXAxis ( bool  logScale)
◆ GetLogScaleXAxis()
bool pqTransferFunctionWidget::GetLogScaleXAxis ( ) const
◆ scalarsToColors()
vtkScalarsToColors* pqTransferFunctionWidget::scalarsToColors ( ) const
◆ piecewiseFunction()
vtkPiecewiseFunction* pqTransferFunctionWidget::piecewiseFunction ( ) const
◆ SetControlPointsFreehandDrawing()
void pqTransferFunctionWidget::SetControlPointsFreehandDrawing ( bool  use)
◆ GetControlPointsFreehandDrawing()
bool pqTransferFunctionWidget::GetControlPointsFreehandDrawing ( ) const
◆ setCurrentPoint
void pqTransferFunctionWidget::setCurrentPoint ( vtkIdType  index)
slot
Set to -1 clear the current point.
◆ setCurrentPointPosition
void pqTransferFunctionWidget::setCurrentPointPosition ( double  xpos)
slot
We ensure that the point doesn't move past neighbouring points. Note this will not change the end points i.e. start and end points.
◆ render
void pqTransferFunctionWidget::render ( )
slot
This doesn't render immediately, schedules a render.
◆ setHistogramTable
void pqTransferFunctionWidget::setHistogramTable ( vtkTable table)
slot
If set to nullptr, a simple color texture is used, the default.
◆ currentPointChanged
void pqTransferFunctionWidget::currentPointChanged ( vtkIdType  index)
signal
◆ controlPointsModified
void pqTransferFunctionWidget::controlPointsModified ( )
signal
either they were moved, orone was added/deleted, or edited to change color, etc.
◆ chartRangeModified
void pqTransferFunctionWidget::chartRangeModified ( )
signal
◆ rangeHandlesRangeChanged
void pqTransferFunctionWidget::rangeHandlesRangeChanged ( double  rangeMin,
double  rangeMax
signal
◆ rangeHandlesDoubleClicked
void pqTransferFunctionWidget::rangeHandlesDoubleClicked ( )
signal
◆ onCurrentChangedEvent
void pqTransferFunctionWidget::onCurrentChangedEvent ( )
protectedslot
◆ onRangeHandlesRangeChanged
void pqTransferFunctionWidget::onRangeHandlesRangeChanged ( )
protectedslot
◆ showUsageStatus
void pqTransferFunctionWidget::showUsageStatus ( )
protectedslot
◆ editColorAtCurrentControlPoint
void pqTransferFunctionWidget::editColorAtCurrentControlPoint ( )
protectedslot
◆ onCurrentPointEditEvent()
void pqTransferFunctionWidget::onCurrentPointEditEvent ( )
