pqColorOpacityEditorWidget provides an in-line editor widget for editing the color and opacity transfer functions. More...
#include <pqColorOpacityEditorWidget.h>
Public Slots | |
void | setXvmsPoints (const QList< QVariant > &) |
Sets the xvmsPoints that control the opacity transfer function. More... | |
void | setXrgbPoints (const QList< QVariant > &) |
Sets the xrgbPoints that control the color transfer function. More... | |
void | setUseLogScale (bool value) |
Set whether to use-log scale. More... | |
void | setUseLogScaleOpacity (bool value) |
void | setUseOpacityControlPointsFreehandDrawing (bool value) |
Set whether to use freehand drawing for positioning opacity control points. More... | |
void | setShowDataHistogram (bool value) |
Set whether to show data histogram. More... | |
void | setAutomaticDataHistogramComputation (bool value) |
Set whether to automatically compute data histogram. More... | |
void | setDataHistogramNumberOfBins (int value) |
Set the number of bins to use for the data histogram. More... | |
void | setScalarOpacityFunctionProxy (pqSMProxy sofProxy) |
Set the scalar opacity function (or PiecewiseFunction) proxy to use. More... | |
void | setTransferFunction2DProxy (pqSMProxy t2dProxy) |
Set the 2D transfer function (or vtkImageData) proxy to use. More... | |
void | resetRangeToData () |
Reset the transfer function ranges to active data source. More... | |
void | resetRangeToCustom () |
Reset the transfer function ranges to custom values. More... | |
void | resetRangeToDataOverTime () |
Reset the transfer function ranges to temporal range for active data source. More... | |
void | resetRangeToVisibleData () |
Reset the transfer function ranges to visible range for active data source. More... | |
void | invertTransferFunctions () |
Inverts the transfer functions. More... | |
void | choosePreset (const char *presetName=nullptr) |
pick a preset. More... | |
void | saveAsPreset () |
save current transfer function as preset. More... | |
void | computeDataHistogram () |
Compute the data histogram 1D or 2D. More... | |
void | onRangeHandlesRangeChanged (double rangeMin, double rangeMax) |
void | resetColorMapComboBox () |
Resets the color map combo box by setting its index to -1 which sets its text to an empty string. More... | |
void | setTransfer2DBoxes (const QList< QVariant > &) |
Sets the box items that control the 2D transfer function. More... | |
void | chooseBoxColorAlpha () |
Choose a color and alpha for the currently active 2D transfer function box. More... | |
virtual void | setView (pqView *) |
called to set the active view. More... | |
Signals | |
void | xrgbPointsChanged () |
Signal fired when the xrgbPoints change. More... | |
void | xvmsPointsChanged () |
Signal fired when the xvmsPoints change. More... | |
void | useLogScaleChanged () |
Signal fired when useLogScale changes. More... | |
void | useLogScaleOpacityChanged () |
Signal fired when useLogScaleOpacity changes. More... | |
void | useOpacityControlPointsFreehandDrawingChanged () |
Signal fired when useOpacityControlPointsFreehandDrawing changes. More... | |
void | showDataHistogramChanged () |
Signal fired when showDataHistogram changes. More... | |
void | automaticDataHistogramComputationChanged () |
Signal fired when automaticDataHistogramComputation changes. More... | |
void | dataHistogramNumberOfBinsEdited () |
Signal fired when dataHistogramNumberOfBins changes. More... | |
void | scalarOpacityFunctionProxyChanged () |
This signal is never really fired since this widget doesn't have any UI to allow users to changes the ScalarOpacityFunction proxy used. More... | |
void | transferFunction2DProxyChanged () |
Signal fired when the transfer function 2D proxy is changed. More... | |
void | transfer2DBoxesChanged () |
Signal fired when the transfer function 2d boxes change. More... | |
void | viewChanged (pqView *view) |
This signal is emitted when the current view changes. More... | |
void | changeAvailable () |
This signal is fired as soon as the user starts editing in the widget. More... | |
void | changeFinished () |
This signal is fired as soon as the user is done with making an atomic change. More... | |
void | restartRequired () |
Indicates that a restart of the program is required for the setting to take effect. More... | |
pqColorOpacityEditorWidget (vtkSMProxy *proxy, vtkSMPropertyGroup *smgroup, QWidget *parent=nullptr) | |
~pqColorOpacityEditorWidget () override | |
void | updateWidget (bool showing_advanced_properties) override |
updates the panel to show/hide advanced settings More... | |
QList< QVariant > | xrgbPoints () const |
Returns the current list of control points for the color transfer function. More... | |
QList< QVariant > | xvmsPoints () const |
Returns the current list of control points for the opacity function. More... | |
bool | useLogScale () const |
Returns the value for use-log-scale. More... | |
bool | useLogScaleOpacity () const |
bool | useOpacityControlPointsFreehandDrawing () const |
Returns the value for the use of freehand drawing when positioning opacity control points. More... | |
bool | showDataHistogram () const |
Returns the value for showDataHistogram. More... | |
bool | automaticDataHistogramComputation () const |
Returns the value for automaticDataHistogramComputation. More... | |
int | dataHistogramNumberOfBins () const |
Returns the value for dataHistogramNumberOfBins. More... | |
pqSMProxy | scalarOpacityFunctionProxy () const |
Returns the scalar opacity function (i.e. More... | |
pqSMProxy | transferFunction2DProxy () const |
Returns the 2D transfer function (i.e. More... | |
bool | using2DTransferFunction () const |
Returns the value for Using2DTransferFunction internal server-manager property. More... | |
QList< QVariant > | transfer2DBoxes () const |
Returns the current list of boxes for the 2D transfer function. More... | |
pqPropertyWidget (vtkSMProxy *proxy, QWidget *parent=nullptr) | |
~pqPropertyWidget () override | |
virtual void | apply () |
virtual void | reset () |
pqView * | view () const |
vtkSMProxy * | proxy () const |
vtkSMProperty * | property () const |
virtual char * | panelVisibility () const |
Forward calls to vtkSMProperty. More... | |
virtual void | setPanelVisibility (const char *vis) |
virtual bool | isSingleRowItem () const |
Determines if the PropertyWidget must be constructed using a single row. More... | |
bool | showLabel () const |
const QList< QPointer< pqPropertyWidgetDecorator > > & | decorators () const |
Provides access to the decorators for this widget. More... | |
void | setProperty (vtkSMProperty *property) |
virtual void | select () |
These methods are called by pqPropertiesPanel when the panel for proxy becomes active/deactive. More... | |
virtual void | selectPort (int portIndex) |
virtual void | deselect () |
bool | isSelected () const |
Protected Slots | |
void | opacityCurrentChanged (vtkIdType) |
slots called when the current point changes on the two internal pqTransferFunctionWidget widgets. More... | |
void | colorCurrentChanged (vtkIdType) |
void | updateCurrentData () |
updates the text shown in the "current data" input. More... | |
void | currentDataEdited () |
update the transfer function with the text in CurrentDataValue text field. More... | |
void | presetApplied () |
called when a preset is applied. More... | |
void | updateDefaultPresetsList () |
Updates the default presets combo box when the list changes. More... | |
void | multiComponentsMappingChanged (vtkObject *, unsigned long, void *, void *) |
called when "MultiComponentsMappingChanged" checkbox is modified. More... | |
void | useLogScaleClicked (bool) |
called when the use-log-scale checkbox is clicked by the user. More... | |
void | useLogScaleOpacityClicked (bool) |
void | useOpacityControlPointsFreehandDrawingClicked (bool) |
Called when UseOpacityControlPointsFreehandDrawing checkbox is clicked by the user. More... | |
void | showDataHistogramClicked (bool show=true) |
Called when the showDataHistogram checkbox is clicked by the user. More... | |
void | show2DHistogram (bool show=true) |
Called when the use2DTransferFunction checkbox is clicked by the user. More... | |
void | automaticDataHistogramComputationClicked (bool val) |
Called when the automaticDataHistogramComputation checkbox is clicked by the user. More... | |
void | dataHistogramNumberOfBinsEdited (int val) |
Called when the dataHistogramNumberOfBins is changed by the user. More... | |
void | updateDataHistogramEnableState () |
Update the enable state of different data histogram related widgets. More... | |
void | representationOrViewChanged () |
called when the active representation or view changes. More... | |
void | setHistogramOutdated () |
Called when the histogram should be considered outdated, which includes : When the range of the transfer function is changed, either from a custom range or from an updated range When the vector mode or vector component is changed When the visibility of a consumer is changed When the number of bins is changed When the 2D transfer function arrays are changed. More... | |
void | realShowDataHistogram () |
Slot called by a timer which is triggered in showDataHistogramClicked This method actually setup the histogram but should not be used directly. More... | |
void | realShow2DHistogram () |
Slot called by a timer which is triggered in show2DHistogram This method actually sets up the 2D histogram. More... | |
void | transfer2DChanged () |
Slot to update active representation when the 2D transfer function has changed with the internal pqTransferFunction2DWidget class. More... | |
void | opacityFunctionModified () |
Slot to update active representation when the piecewise function for opacity is modified. More... | |
void | updateTransferFunction2DProxy () |
Slot to update the 2D transfer function proxy when the Y axis scalar array is changed. More... | |
void | prepareRangeForLogScaling () |
Validate and adjust the current range before converting to a log range. More... | |
void | initializeOpacityEditor (vtkPiecewiseFunction *pwf) |
Initialize the opacity editor. More... | |
void | initializeTransfer2DEditor (vtkPVTransferFunction2D *tf2d) |
Initialize the 2D transfer function editor. More... | |
void | observeRepresentationModified (vtkSMProxy *reprProxy, vtkPiecewiseFunction *pwf) |
When representation has changed, gotta reconnect some internal observers. More... | |
void | addPropertyLink (QObject *qobject, const char *qproperty, const char *qsignal, vtkSMProperty *smproperty, int smindex=-1) |
void | addPropertyLink (QObject *qobject, const char *qproperty, const char *qsignal, vtkSMProxy *smproxy, vtkSMProperty *smproperty, int smindex=-1) |
void | removePropertyLink (QObject *qobject, const char *qproperty, const char *qsignal, vtkSMProperty *smproperty, int smindex=-1) |
void | removePropertyLink (QObject *qobject, const char *qproperty, const char *qsignal, vtkSMProxy *smproxy, vtkSMProperty *smproperty, int smindex=-1) |
void | setShowLabel (bool show) |
void | setChangeAvailableAsChangeFinished (bool status) |
For most pqPropertyWidget subclasses a changeAvailable() signal, corresponds to a changeFinished() signal. More... | |
void | addDecorator (pqPropertyWidgetDecorator *) |
Register a decorator. More... | |
void | removeDecorator (pqPropertyWidgetDecorator *) |
Unregisters a decorator. More... | |
pqPropertyLinks & | links () |
Provides access to the pqPropertyLinks instance. More... | |
Properties | |
QList< QVariant > | xrgbPoints |
QList< QVariant > | xvmsPoints |
bool | showDataHistogram |
bool | automaticDataHistogramComputation |
int | dataHistogramNumberOfBins |
bool | useLogScale |
bool | useLogScaleOpacity |
bool | useOpacityControlPointsFreehandDrawing |
pqSMProxy | scalarOpacityFunctionProxy |
pqSMProxy | transferFunction2DProxy |
QList< QVariant > | transfer2DBoxes |
template<class T > | |
static QString | getXMLName (T *object) |
Description: This static utility method returns the XML name for an object as a QString. More... | |
static QString | getTooltip (vtkSMProperty *property) |
Returns the tooltip to use for the property. More... | |
static int | hintsWidgetHeightNumberOfRows (vtkPVXMLElement *hints, int defaultValue=10) |
Helper method to return value from WidgetHeight XML hint, if any. More... | |
static std::vector< std::string > | parseComponentLabels (vtkPVXMLElement *hints, unsigned int elemCount=0) |
Parse a XML element as a list of label to use for this widget. More... | |
The property group is expected to have properties with the following functions. If any of the optional properties are missing, then the corresponding widgets are hidden.
Definition at line 50 of file pqColorOpacityEditorWidget.h.
pqColorOpacityEditorWidget::pqColorOpacityEditorWidget | ( | vtkSMProxy * | proxy, |
vtkSMPropertyGroup * | smgroup, | ||
QWidget * | parent = nullptr |
Reimplemented from pqPropertyWidget.
QList<QVariant> pqColorOpacityEditorWidget::xrgbPoints | ( | ) | const |
This a list of 4-tuples.
QList<QVariant> pqColorOpacityEditorWidget::xvmsPoints | ( | ) | const |
bool pqColorOpacityEditorWidget::useLogScale | ( | ) | const |
bool pqColorOpacityEditorWidget::useLogScaleOpacity | ( | ) | const |
bool pqColorOpacityEditorWidget::useOpacityControlPointsFreehandDrawing | ( | ) | const |
bool pqColorOpacityEditorWidget::showDataHistogram | ( | ) | const |
bool pqColorOpacityEditorWidget::automaticDataHistogramComputation | ( | ) | const |
int pqColorOpacityEditorWidget::dataHistogramNumberOfBins | ( | ) | const |
pqSMProxy pqColorOpacityEditorWidget::scalarOpacityFunctionProxy | ( | ) | const |
PiecewiseFunction) proxy used, if any.
pqSMProxy pqColorOpacityEditorWidget::transferFunction2DProxy | ( | ) | const |
vtkImageData) proxy used, if any.
bool pqColorOpacityEditorWidget::using2DTransferFunction | ( | ) | const |
QList<QVariant> pqColorOpacityEditorWidget::transfer2DBoxes | ( | ) | const |
This a list of 8-tuples - [x0, y0, width, height, r, g, b, opacity].
slot |
slot |
slot |
slot |
slot |
slot |
slot |
slot |
slot |
slot |
slot |
slot |
slot |
slot |
slot |
slot |
pick a preset.
slot |
slot |
Depends on the "Using2DTransferFunction" internal property.
slot |
slot |
slot |
slot |
signal |
signal |
signal |
signal |
signal |
signal |
signal |
signal |
signal |
signal |
signal |
protectedslot |
protectedslot |
protectedslot |
protectedslot |
protectedslot |
protectedslot |
protectedslot |
protectedslot |
We then add extra logic to valid ranges convert the color map to log/linear space.
protectedslot |
protectedslot |
We transfer the call to the pqTransferFunctionEditor.
protectedslot |
We then add extra logic to compute and update the histogram and enable to update histogram button. This uses the histogram table cache if it is up to date. This can be called manually to show/hide the histogram
protectedslot |
protectedslot |
We then add extra logic to show the histogram and update the UI.
protectedslot |
We then add extra logic to set the histogram outdated
protectedslot |
protectedslot |
We then change the enabled/disabled state of the buttons. Some actions require a valid representation or view, so disable them if there isn't one. We also update the opacity editor.
protectedslot |
protectedslot |
protectedslot |
protectedslot |
protectedslot |
For ex, editing the midpoint, sharpness around a piecewise control point modifies the function.
protectedslot |
readwrite |
Definition at line 53 of file pqColorOpacityEditorWidget.h.
readwrite |
Definition at line 54 of file pqColorOpacityEditorWidget.h.
readwrite |
Definition at line 55 of file pqColorOpacityEditorWidget.h.
readwrite |
Definition at line 57 of file pqColorOpacityEditorWidget.h.
readwrite |
Definition at line 59 of file pqColorOpacityEditorWidget.h.
readwrite |
Definition at line 60 of file pqColorOpacityEditorWidget.h.
readwrite |
Definition at line 61 of file pqColorOpacityEditorWidget.h.
readwrite |
Definition at line 63 of file pqColorOpacityEditorWidget.h.
readwrite |
Definition at line 65 of file pqColorOpacityEditorWidget.h.
readwrite |
Definition at line 67 of file pqColorOpacityEditorWidget.h.
readwrite |
Definition at line 68 of file pqColorOpacityEditorWidget.h.
