exporter used by certain views to export data into a file or stream. More...
#include <vtkAbstractChartExporter.h>
enum | ExporterModes { STREAM_ROWS, STREAM_COLUMNS } |
virtual bool | Open (ExporterModes mode=STREAM_ROWS)=0 |
Open the file and set mode in which the exporter is operating. More... | |
virtual void | Close ()=0 |
Closes the file cleanly. More... | |
virtual void | Abort ()=0 |
Same as Close except deletes the file, if created. More... | |
virtual void | AddColumn (vtkAbstractArray *yarray, const char *yarrayname=nullptr, vtkDataArray *xarray=nullptr)=0 |
In STREAM_COLUMNS mode, use this method to add a column (yarray ). More... | |
virtual void | AddStyle (vtkPlot *plot, const char *plotName)=0 |
Attach information about the style of the plot (color,line type, marker type etc. More... | |
virtual void | SetGlobalStyle (vtkChart *chart)=0 |
Set Global style elements like graph and axis titles. More... | |
virtual void | WriteHeader (vtkFieldData *)=0 |
In STREAM_ROWS mode, use these methods to write column headers once using WriteHeader and then use WriteData as many times as needed to write out rows. More... | |
virtual void | WriteData (vtkFieldData *)=0 |
virtual void | Modified () |
static vtkAbstractChartExporter * | New () |
static vtkAbstractChartExporter * | SafeDownCast (vtkObject *o) |
static vtkObject * | New () |
vtkAbstractChartExporter () | |
~vtkAbstractChartExporter () override | |
vtkObject () | |
virtual | ~vtkObject () |
vtkObjectBase () | |
virtual | ~vtkObjectBase () |
bool | Debug |
vtkTimeStamp | MTime |
Definition at line 23 of file vtkAbstractChartExporter.h.
Definition at line 27 of file vtkAbstractChartExporter.h.
Enumerator | |
STREAM_ROWS | |
STREAM_COLUMNS |
Definition at line 30 of file vtkAbstractChartExporter.h.
Reimplemented in vtkCSVExporter, and vtkPlotlyJsonExporter.
pure virtual |
Implemented in vtkCSVExporter, and vtkPlotlyJsonExporter.
pure virtual |
Call this at the end to close the file and dump out any cached data.
pure virtual |
This is useful to interrupt the exporting on failure.
pure virtual |
pure virtual |
pure virtual |
One can assign it a name different the the name of the array using yarrayname
. If xarray
is not nullptr, then is used as the row-id. This makes it possible to add multiple columns with varying number of samples. The final output will have empty cells for missing values.
pure virtual |
To the plot accosiated with plotName. plotName should match the yarrayname used when adding the data via Add Column. AddColumn needs to be called before adding the style.
Implemented in vtkPlotlyJsonExporter.
pure virtual |
Each implementation is expected to get what it can support from the public vtkChart API.
