bool | Open (ExporterModes mode=STREAM_ROWS) override |
| Open the file and set mode in which the exporter is operating. More...
void | Close () override |
| Closes the file cleanly. More...
void | Abort () override |
| Same as Close except deletes the file, if created. More...
void | AddColumn (vtkAbstractArray *yarray, const char *yarrayname=nullptr, vtkDataArray *xarray=nullptr) override |
| Add a new plot using xarray as "x" values and yarray as "y" values. More...
void | AddStyle (vtkPlot *plot, const char *plotName) override |
| Add the stringified attribute under then name attributeName in the Adios file. More...
void | SetGlobalStyle (vtkChart *chart) override |
| Set Global style elements like graph and axis titles. More...
std::string | GetOutputString () const |
virtual void | SetFileName (const char *) |
| Get/Set the filename for the file. More...
virtual char * | GetFileName () |
void | WriteHeader (vtkFieldData *) override |
| No Supported by vtkPlotlyJsonExporter. More...
void | WriteData (vtkFieldData *) override |
virtual void | SetWriteToOutputString (bool) |
| Whether to output to a string instead of to a file which is the default. More...
virtual bool | GetWriteToOutputString () |
virtual void | WriteToOutputStringOn () |
virtual void | WriteToOutputStringOff () |
virtual void | Modified () |
