void | AddCompositeDataSetIndex (unsigned int index) |
| In case of Composite datasets, set the flat index of the subtree to pass. More...
void | RemoveAllCompositeDataSetIndices () |
virtual void | SetGenerateCellConnectivity (bool) |
| Allow user to enable/disable cell connectivity generation in the datamodel. More...
virtual bool | GetGenerateCellConnectivity () |
virtual void | SetFieldAssociation (int) |
| Select the attribute type. More...
virtual int | GetFieldAssociation () |
virtual void | SetFlattenTable (int) |
| Flatten the table, i.e. More...
virtual int | GetFlattenTable () |
virtual void | SetSplitComponentsNamingMode (int) |
| Corresponds to vtkSplitColumnComponents::NamingMode . More...
virtual int | GetSplitComponentsNamingMode () |
virtual void | SetGenerateOriginalIds (bool) |
| When set (default) the vtkOriginalIndices array will be added to the output. More...
virtual bool | GetGenerateOriginalIds () |
vtkDataObjectAlgorithm * | NewInstance () const |
virtual void | SetOutput (vtkDataObject *d) |
virtual int | ProcessRequest (vtkInformation *, vtkInformationVector **, vtkInformationVector *) |
int | HasExecutive () |
void | RemoveAllInputs () |
virtual void | Update () |
void | ReleaseDataFlagOn () |
int * | GetUpdateExtent () |
int | GetUpdatePiece () |
virtual void | Modified () |
