void | SetTimeData (double time, vtkIdType timeStep) |
| Set the time step and current simulation time. More...
virtual vtkIdType | GetTimeStep () |
| Get the current time step that should be set in the adaptor. More...
virtual double | GetTime () |
| Get the current time that should be set in the adaptor. More...
virtual void | SetForceOutput (bool) |
| Specify whether or not to force output of all coprocessing pipelines. More...
virtual void | ForceOutputOn () |
virtual void | ForceOutputOff () |
virtual bool | GetForceOutput () |
| Return whether or not output is forced for all coprocessing pipelines. More...
void | AddInput (const char *gridName) |
| Add names for grids produced by the simulation. More...
unsigned int | GetNumberOfInputDescriptions () |
| Returns the number of input descriptions. More...
void | ResetInputDescriptions () |
| Reset the names of the fields that are needed, the required meshes, etc. More...
void | ResetAll () |
vtkCPInputDataDescription * | GetInputDescription (unsigned int) |
| Provides access to a grid description using the index. More...
const char * | GetInputDescriptionName (unsigned int) |
| Provides the name for the input description at the given index. More...
vtkCPInputDataDescription * | GetInputDescriptionByName (const char *) |
| Provides access to a grid description using the grid name. More...
bool | GetIfGridIsNecessary (const char *) |
| Returns true if the grid is necessary, given the grid's name. More...
bool | GetIfAnyGridNecessary () |
| Returns true if any of the grids is necessary. More...
void | SetUserData (vtkFieldData *UserData) |
| Set user defined information that can be passed from the adaptor to the coprocessing pipelines. More...
virtual vtkFieldData * | GetUserData () |
void | Copy (vtkCPDataDescription *) |
| Copy of dataDescription. More...
virtual void | Modified () |
