Class that creates a coprocessing pipeline starting from a coprocessing script. More...
#include <vtkCPPythonScriptPipeline.h>
typedef vtkCPPythonPipeline | Superclass |
typedef vtkCPPipeline | Superclass |
int | Initialize (const char *fileName) |
Initialize this pipeline from given the file name of a python script. More... | |
int | RequestDataDescription (vtkCPDataDescription *dataDescription) override |
Configuration Step: The coprocessor first determines if any coprocessing needs to be done at this TimeStep/Time combination returning 1 if it does and 0 otherwise. More... | |
int | CoProcess (vtkCPDataDescription *dataDescription) override |
Execute the pipeline. Returns 1 for success and 0 for failure. More... | |
int | Finalize () override |
Finalize the pipeline before deleting it. More... | |
virtual void | Modified () |
static vtkCPPythonScriptPipeline * | New () |
static vtkCPPythonScriptPipeline * | SafeDownCast (vtkObject *o) |
static vtkCPPythonPipeline * | SafeDownCast (vtkObject *o) |
static int | DetectScriptVersion (const char *fname) |
Starting with ParaView 5.9, there are two versions of Python scripts that ParaView supports. More... | |
static vtkSmartPointer< vtkCPPythonPipeline > | CreatePipeline (const char *fname, int default_version=1) |
Detects the script version, if possible and created appropriate subclass. More... | |
static vtkSmartPointer< vtkCPPythonPipeline > | CreateAndInitializePipeline (const char *fname, int default_version=1) |
Same as CreatePipeline , except that if the pipeline instance is successfully created also calls appropriate Initialize method on it. More... | |
static VTK_NEWINSTANCE vtkCPPythonPipeline * | NewPipeline (const char *fname, int default_version=1) |
These overloads are provided for Python wrapping since vtkSmartPointer doesn't seem to be wrapped correctly. More... | |
static VTK_NEWINSTANCE vtkCPPythonPipeline * | NewAndInitializePipeline (const char *fname, int default_version=1) |
static vtkCPPipeline * | SafeDownCast (vtkObject *o) |
static vtkObject * | New () |
vtkCPPythonScriptPipeline () | |
~vtkCPPythonScriptPipeline () override | |
virtual void | SetPythonScriptName (const char *) |
Set/get macro functinos for setting PythonScriptName. More... | |
virtual char * | GetPythonScriptName () |
void | FixEOL (std::string &) |
For things like programmable filters that have a ' ' in their strings, we need to fix them to have \n so that everything works smoothly. More... | |
std::string | GetPythonAddress (void *pointer) |
Return the address of Pointer for the python script. More... | |
vtkCPPythonPipeline () | |
~vtkCPPythonPipeline () override | |
vtkCPPipeline () | |
~vtkCPPipeline () override | |
vtkObject () | |
virtual | ~vtkObject () |
vtkObjectBase () | |
virtual | ~vtkObjectBase () |
bool | Debug |
vtkTimeStamp | MTime |
This class only does operations with respect to the script and uses the name of the script as the module to hide its definitions from other python modules.
Definition at line 16 of file vtkCPPythonScriptPipeline.h.
Definition at line 20 of file vtkCPPythonScriptPipeline.h.
Reimplemented from vtkCPPythonPipeline.
If coprocessing does need to be performed this time step it fills in the FieldNames array that the coprocessor requires in order to fulfill all the coprocessing requests for this TimeStep/Time combination.
Implements vtkCPPipeline.
A default no-op implementation is given. Returns 1 for success and 0 for failure.
Reimplemented from vtkCPPipeline.
protectedvirtual |
protectedvirtual |
