Class that creates a coprocessing pipeline from a coprocessing string. More...
#include <vtkCPPythonStringPipeline.h>
typedef vtkCPPythonPipeline | Superclass |
typedef vtkCPPipeline | Superclass |
int | Initialize (const char *pythonString) |
Initialize this pipeline from a given Python string script. More... | |
int | RequestDataDescription (vtkCPDataDescription *dataDescription) override |
Configuration Step: The coprocessor first determines if any coprocessing needs to be done at this TimeStep/Time combination returning 1 if it does and 0 otherwise. More... | |
int | CoProcess (vtkCPDataDescription *dataDescription) override |
Execute the pipeline. Returns 1 for success and 0 for failure. More... | |
int | Finalize () override |
Finalize the pipeline before deleting it. More... | |
virtual void | Modified () |
static vtkCPPythonStringPipeline * | New () |
static vtkCPPythonStringPipeline * | SafeDownCast (vtkObject *o) |
static vtkCPPythonPipeline * | SafeDownCast (vtkObject *o) |
static int | DetectScriptVersion (const char *fname) |
Starting with ParaView 5.9, there are two versions of Python scripts that ParaView supports. More... | |
static vtkSmartPointer< vtkCPPythonPipeline > | CreatePipeline (const char *fname, int default_version=1) |
Detects the script version, if possible and created appropriate subclass. More... | |
static vtkSmartPointer< vtkCPPythonPipeline > | CreateAndInitializePipeline (const char *fname, int default_version=1) |
Same as CreatePipeline , except that if the pipeline instance is successfully created also calls appropriate Initialize method on it. More... | |
static VTK_NEWINSTANCE vtkCPPythonPipeline * | NewPipeline (const char *fname, int default_version=1) |
These overloads are provided for Python wrapping since vtkSmartPointer doesn't seem to be wrapped correctly. More... | |
static VTK_NEWINSTANCE vtkCPPythonPipeline * | NewAndInitializePipeline (const char *fname, int default_version=1) |
static vtkCPPipeline * | SafeDownCast (vtkObject *o) |
static vtkObject * | New () |
vtkCPPythonStringPipeline () | |
~vtkCPPythonStringPipeline () override | |
void | FixEOL (std::string &) |
For things like programmable filters that have a ' ' in their strings, we need to fix them to have \n so that everything works smoothly. More... | |
std::string | GetPythonAddress (void *pointer) |
Return the address of Pointer for the python script. More... | |
vtkCPPythonPipeline () | |
~vtkCPPythonPipeline () override | |
vtkCPPipeline () | |
~vtkCPPipeline () override | |
vtkObject () | |
virtual | ~vtkObject () |
vtkObjectBase () | |
virtual | ~vtkObjectBase () |
bool | Debug |
vtkTimeStamp | MTime |
Definition at line 15 of file vtkCPPythonStringPipeline.h.
Definition at line 19 of file vtkCPPythonStringPipeline.h.
Reimplemented from vtkCPPythonPipeline.
The string is stored in PythonString. Returns 1 for success and 0 for failure.
If coprocessing does need to be performed this time step it fills in the FieldNames array that the coprocessor requires in order to fulfill all the coprocessing requests for this TimeStep/Time combination.
Implements vtkCPPipeline.
A default no-op implementation is given. Returns 1 for success and 0 for failure.
Reimplemented from vtkCPPipeline.
