int | RequestDataDescription (vtkCPDataDescription *dataDescription) override |
| Configuration Step: The coprocessor first determines if any coprocessing needs to be done at this TimeStep/Time combination returning 1 if it does and 0 otherwise. More...
int | CoProcess (vtkCPDataDescription *dataDescription) override |
| Execute the pipeline. Returns 1 for success and 0 for failure. More...
virtual void | SetOutputFrequency (int) |
| Set the output frequency for this pipeline. The default is 1. More...
virtual int | GetOutputFrequency () |
virtual void | SetPaddingAmount (int) |
| Set the padding amount for the time index portion of the generated files. More...
virtual int | GetPaddingAmount () |
virtual void | SetPath (std::string) |
| Set the path to the generated files. More...
virtual std::string | GetPath () |
virtual int | Finalize () |
| Finalize the pipeline before deleting it. More...
virtual void | Modified () |
