int | GetActiveControllerID () |
| Return a unique identifier for the given selected controller. More...
int | GetNumberOfControllers () |
| Return the number of currently connected controllers. More...
int | GetControllerId (int idx) |
| Return the id of the nth controller. More...
vtkMultiProcessController * | GetController (int idx) |
| Return the nth controller. More...
void | SetMasterController (int id) |
| Promote the given controller (ID) to be the next master controller. More...
int | GetMasterController () |
| Return the ID of the designed "Master" controller. More...
void | RegisterController (vtkMultiProcessController *controller) |
| Append the given controller to the composite set. More...
void | UnRegisterController (vtkMultiProcessController *controller) |
| Remove the given controller to the composite set. More...
int | UnRegisterActiveController () |
| Remove the active controller and return the number of registered controller left. More...
vtkMultiProcessController * | GetActiveController () |
| Provides access to the active controller. More...
virtual void | TriggerRMI2All (int remote, void *data, int length, int tag, bool sendToActiveToo) |
| Allow server to broadcast data to all connected client with our without sending to the active client. More...
virtual void | Initialize () |
void | Initialize (int *, char ***) override |
void | Initialize (int *, char ***, int) override |
void | Finalize () override |
void | Finalize (int) override |
void | SingleMethodExecute () override |
void | MultipleMethodExecute () override |
void | CreateOutputWindow () override |
vtkCommunicator * | GetCommunicator () override |
unsigned long | AddRMICallback (vtkRMIFunctionType, void *localArg, int tag) override |
| These methods are a part of the newer API to add multiple rmi callbacks. More...
void | RemoveAllRMICallbacks (int tag) override |
int | RemoveFirstRMI (int tag) override |
bool | RemoveRMICallback (unsigned long observerTagId) override |
vtkMultiProcessController * | NewInstance () const |
virtual void | Initialize (int *vtkNotUsed(argc), char ***vtkNotUsed(argv))=0 |
void | SetSingleMethod (vtkProcessFunctionType, void *data) |
void | SetSingleProcessObject (vtkProcess *p) |
void | SetMultipleMethod (int index, vtkProcessFunctionType, void *data) |
int | GetLocalProcessId () |
virtual unsigned long | AddRMI (vtkRMIFunctionType, void *localArg, int tag) |
virtual int | RemoveRMI (unsigned long id) |
void | TriggerRMI (int remoteProcessId, void *arg, int argLength, int tag) |
void | TriggerBreakRMIs () |
void | Barrier () |
int | Send (const vtkMultiProcessStream &stream, int remoteId, int tag) |
int | Receive (vtkMultiProcessStream &stream, int remoteId, int tag) |
vtkDataObject * | ReceiveDataObject (int remoteId, int tag) |
vtkIdType | GetCount () |
int | Broadcast (vtkMultiProcessStream &stream, int srcProcessId) |
int | GatherV (vtkDataArray *sendBuffer, vtkDataArray *recvBuffer, vtkIdType *recvLengths, vtkIdType *offsets, int destProcessId) |
int | GatherV (vtkDataArray *sendBuffer, vtkDataArray *recvBuffer, vtkIdTypeArray *recvLengths, vtkIdTypeArray *offsets, int destProcessId) |
int | AllReduce (const int *sendBuffer, int *recvBuffer, vtkIdType length, vtkCommunicator::Operation *operation) |
int | AllReduce (const unsigned int *sendBuffer, unsigned int *recvBuffer, vtkIdType length, vtkCommunicator::Operation *operation) |
int | AllReduce (const short *sendBuffer, short *recvBuffer, vtkIdType length, vtkCommunicator::Operation *operation) |
int | AllReduce (const unsigned short *sendBuffer, unsigned short *recvBuffer, vtkIdType length, vtkCommunicator::Operation *operation) |
int | AllReduce (const long *sendBuffer, long *recvBuffer, vtkIdType length, vtkCommunicator::Operation *operation) |
int | AllReduce (const unsigned long *sendBuffer, unsigned long *recvBuffer, vtkIdType length, vtkCommunicator::Operation *operation) |
int | AllReduce (const unsigned char *sendBuffer, unsigned char *recvBuffer, vtkIdType length, vtkCommunicator::Operation *operation) |
int | AllReduce (const char *sendBuffer, char *recvBuffer, vtkIdType length, vtkCommunicator::Operation *operation) |
int | AllReduce (const signed char *sendBuffer, signed char *recvBuffer, vtkIdType length, vtkCommunicator::Operation *operation) |
int | AllReduce (const float *sendBuffer, float *recvBuffer, vtkIdType length, vtkCommunicator::Operation *operation) |
int | AllReduce (const double *sendBuffer, double *recvBuffer, vtkIdType length, vtkCommunicator::Operation *operation) |
int | AllReduce (const long long *sendBuffer, long long *recvBuffer, vtkIdType length, vtkCommunicator::Operation *operation) |
int | AllReduce (const unsigned long long *sendBuffer, unsigned long long *recvBuffer, vtkIdType length, vtkCommunicator::Operation *operation) |
int | AllReduce (vtkDataArray *sendBuffer, vtkDataArray *recvBuffer, vtkCommunicator::Operation *operation) |
virtual void | Initialize (int *vtkNotUsed(argc), char ***vtkNotUsed(argv), int initializedExternally)=0 |
void | SetNumberOfProcesses (int num) |
int | GetNumberOfProcesses () |
virtual vtkMultiProcessController * | CreateSubController (vtkProcessGroup *group) |
virtual vtkMultiProcessController * | PartitionController (int localColor, int localKey) |
virtual void | RemoveRMI (vtkRMIFunctionType f, void *arg, int tag) |
void | TriggerRMI (int remoteProcessId, const char *arg, int tag) |
void | TriggerRMI (int remoteProcessId, int tag) |
void | TriggerRMIOnAllChildren (void *arg, int argLength, int tag) |
void | TriggerRMIOnAllChildren (const char *arg, int tag) |
void | TriggerRMIOnAllChildren (int tag) |
void | BroadcastTriggerRMIOnAllChildren (void *arg, int argLength, int tag) |
int | ProcessRMIs (int reportErrors, int dont_loop=0) |
int | ProcessRMIs () |
int | BroadcastProcessRMIs (int reportErrors, int dont_loop=0) |
virtual void | SetBreakFlag (int) |
virtual int | GetBreakFlag () |
virtual void | SetBroadcastTriggerRMI (bool) |
virtual bool | GetBroadcastTriggerRMI () |
virtual void | BroadcastTriggerRMIOn () |
virtual void | BroadcastTriggerRMIOff () |
int | Send (const int *data, vtkIdType length, int remoteProcessId, int tag) |
int | Send (const short *data, vtkIdType length, int remoteProcessId, int tag) |
int | Send (const unsigned short *data, vtkIdType length, int remoteProcessId, int tag) |
int | Send (const unsigned int *data, vtkIdType length, int remoteProcessId, int tag) |
int | Send (const unsigned long *data, vtkIdType length, int remoteProcessId, int tag) |
int | Send (const long *data, vtkIdType length, int remoteProcessId, int tag) |
int | Send (const signed char *data, vtkIdType length, int remoteProcessId, int tag) |
int | Send (const char *data, vtkIdType length, int remoteProcessId, int tag) |
int | Send (const unsigned char *data, vtkIdType length, int remoteProcessId, int tag) |
int | Send (const float *data, vtkIdType length, int remoteProcessId, int tag) |
int | Send (const double *data, vtkIdType length, int remoteProcessId, int tag) |
int | Send (const long long *data, vtkIdType length, int remoteProcessId, int tag) |
int | Send (const unsigned long long *data, vtkIdType length, int remoteProcessId, int tag) |
int | Send (vtkDataObject *data, int remoteId, int tag) |
int | Send (vtkDataArray *data, int remoteId, int tag) |
int | Receive (int *data, vtkIdType maxlength, int remoteProcessId, int tag) |
int | Receive (unsigned int *data, vtkIdType maxlength, int remoteProcessId, int tag) |
int | Receive (short *data, vtkIdType maxlength, int remoteProcessId, int tag) |
int | Receive (unsigned short *data, vtkIdType maxlength, int remoteProcessId, int tag) |
int | Receive (long *data, vtkIdType maxlength, int remoteProcessId, int tag) |
int | Receive (unsigned long *data, vtkIdType maxlength, int remoteProcessId, int tag) |
int | Receive (char *data, vtkIdType maxlength, int remoteProcessId, int tag) |
int | Receive (unsigned char *data, vtkIdType maxlength, int remoteProcessId, int tag) |
int | Receive (signed char *data, vtkIdType maxlength, int remoteProcessId, int tag) |
int | Receive (float *data, vtkIdType maxlength, int remoteProcessId, int tag) |
int | Receive (double *data, vtkIdType maxlength, int remoteProcessId, int tag) |
int | Receive (long long *data, vtkIdType maxLength, int remoteProcessId, int tag) |
int | Receive (unsigned long long *data, vtkIdType maxLength, int remoteProcessId, int tag) |
int | Receive (vtkDataObject *data, int remoteId, int tag) |
int | Receive (vtkDataArray *data, int remoteId, int tag) |
int | Broadcast (int *data, vtkIdType length, int srcProcessId) |
int | Broadcast (unsigned int *data, vtkIdType length, int srcProcessId) |
int | Broadcast (short *data, vtkIdType length, int srcProcessId) |
int | Broadcast (unsigned short *data, vtkIdType length, int srcProcessId) |
int | Broadcast (long *data, vtkIdType length, int srcProcessId) |
int | Broadcast (unsigned long *data, vtkIdType length, int srcProcessId) |
int | Broadcast (unsigned char *data, vtkIdType length, int srcProcessId) |
int | Broadcast (char *data, vtkIdType length, int srcProcessId) |
int | Broadcast (signed char *data, vtkIdType length, int srcProcessId) |
int | Broadcast (float *data, vtkIdType length, int srcProcessId) |
int | Broadcast (double *data, vtkIdType length, int srcProcessId) |
int | Broadcast (long long *data, vtkIdType length, int srcProcessId) |
int | Broadcast (unsigned long long *data, vtkIdType length, int srcProcessId) |
int | Broadcast (vtkDataObject *data, int srcProcessId) |
int | Broadcast (vtkDataArray *data, int srcProcessId) |
int | Gather (const int *sendBuffer, int *recvBuffer, vtkIdType length, int destProcessId) |
int | Gather (const unsigned int *sendBuffer, unsigned int *recvBuffer, vtkIdType length, int destProcessId) |
int | Gather (const short *sendBuffer, short *recvBuffer, vtkIdType length, int destProcessId) |
int | Gather (const unsigned short *sendBuffer, unsigned short *recvBuffer, vtkIdType length, int destProcessId) |
int | Gather (const long *sendBuffer, long *recvBuffer, vtkIdType length, int destProcessId) |
int | Gather (const unsigned long *sendBuffer, unsigned long *recvBuffer, vtkIdType length, int destProcessId) |
int | Gather (const unsigned char *sendBuffer, unsigned char *recvBuffer, vtkIdType length, int destProcessId) |
int | Gather (const char *sendBuffer, char *recvBuffer, vtkIdType length, int destProcessId) |
int | Gather (const signed char *sendBuffer, signed char *recvBuffer, vtkIdType length, int destProcessId) |
int | Gather (const float *sendBuffer, float *recvBuffer, vtkIdType length, int destProcessId) |
int | Gather (const double *sendBuffer, double *recvBuffer, vtkIdType length, int destProcessId) |
int | Gather (const long long *sendBuffer, long long *recvBuffer, vtkIdType length, int destProcessId) |
int | Gather (const unsigned long long *sendBuffer, unsigned long long *recvBuffer, vtkIdType length, int destProcessId) |
int | Gather (vtkDataArray *sendBuffer, vtkDataArray *recvBuffer, int destProcessId) |
int | Gather (vtkDataObject *sendBuffer, std::vector< vtkSmartPointer< vtkDataObject > > &recvBuffer, int destProcessId) |
int | GatherV (const int *sendBuffer, int *recvBuffer, vtkIdType sendLength, vtkIdType *recvLengths, vtkIdType *offsets, int destProcessId) |
int | GatherV (const unsigned int *sendBuffer, unsigned int *recvBuffer, vtkIdType sendLength, vtkIdType *recvLengths, vtkIdType *offsets, int destProcessId) |
int | GatherV (const short *sendBuffer, short *recvBuffer, vtkIdType sendLength, vtkIdType *recvLengths, vtkIdType *offsets, int destProcessId) |
int | GatherV (const unsigned short *sendBuffer, unsigned short *recvBuffer, vtkIdType sendLength, vtkIdType *recvLengths, vtkIdType *offsets, int destProcessId) |
int | GatherV (const long *sendBuffer, long *recvBuffer, vtkIdType sendLength, vtkIdType *recvLengths, vtkIdType *offsets, int destProcessId) |
int | GatherV (const unsigned long *sendBuffer, unsigned long *recvBuffer, vtkIdType sendLength, vtkIdType *recvLengths, vtkIdType *offsets, int destProcessId) |
int | GatherV (const unsigned char *sendBuffer, unsigned char *recvBuffer, vtkIdType sendLength, vtkIdType *recvLengths, vtkIdType *offsets, int destProcessId) |
int | GatherV (const char *sendBuffer, char *recvBuffer, vtkIdType sendLength, vtkIdType *recvLengths, vtkIdType *offsets, int destProcessId) |
int | GatherV (const signed char *sendBuffer, signed char *recvBuffer, vtkIdType sendLength, vtkIdType *recvLengths, vtkIdType *offsets, int destProcessId) |
int | GatherV (const float *sendBuffer, float *recvBuffer, vtkIdType sendLength, vtkIdType *recvLengths, vtkIdType *offsets, int destProcessId) |
int | GatherV (const double *sendBuffer, double *recvBuffer, vtkIdType sendLength, vtkIdType *recvLengths, vtkIdType *offsets, int destProcessId) |
int | GatherV (const long long *sendBuffer, long long *recvBuffer, vtkIdType sendLength, vtkIdType *recvLengths, vtkIdType *offsets, int destProcessId) |
int | GatherV (const unsigned long long *sendBuffer, unsigned long long *recvBuffer, vtkIdType sendLength, vtkIdType *recvLengths, vtkIdType *offsets, int destProcessId) |
int | GatherV (vtkDataArray *sendBuffer, vtkDataArray *recvBuffer, int destProcessId) |
int | GatherV (vtkDataObject *sendData, vtkSmartPointer< vtkDataObject > *recvData, int destProcessId) |
int | Scatter (const int *sendBuffer, int *recvBuffer, vtkIdType length, int srcProcessId) |
int | Scatter (const unsigned int *sendBuffer, unsigned int *recvBuffer, vtkIdType length, int srcProcessId) |
int | Scatter (const short *sendBuffer, short *recvBuffer, vtkIdType length, int srcProcessId) |
int | Scatter (const unsigned short *sendBuffer, unsigned short *recvBuffer, vtkIdType length, int srcProcessId) |
int | Scatter (const long *sendBuffer, long *recvBuffer, vtkIdType length, int srcProcessId) |
int | Scatter (const unsigned long *sendBuffer, unsigned long *recvBuffer, vtkIdType length, int srcProcessId) |
int | Scatter (const unsigned char *sendBuffer, unsigned char *recvBuffer, vtkIdType length, int srcProcessId) |
int | Scatter (const char *sendBuffer, char *recvBuffer, vtkIdType length, int srcProcessId) |
int | Scatter (const signed char *sendBuffer, signed char *recvBuffer, vtkIdType length, int srcProcessId) |
int | Scatter (const float *sendBuffer, float *recvBuffer, vtkIdType length, int srcProcessId) |
int | Scatter (const double *sendBuffer, double *recvBuffer, vtkIdType length, int srcProcessId) |
int | Scatter (const long long *sendBuffer, long long *recvBuffer, vtkIdType length, int srcProcessId) |
int | Scatter (const unsigned long long *sendBuffer, unsigned long long *recvBuffer, vtkIdType length, int srcProcessId) |
int | Scatter (vtkDataArray *sendBuffer, vtkDataArray *recvBuffer, int srcProcessId) |
int | ScatterV (const int *sendBuffer, int *recvBuffer, vtkIdType *sendLengths, vtkIdType *offsets, vtkIdType recvLength, int srcProcessId) |
int | ScatterV (const unsigned int *sendBuffer, unsigned int *recvBuffer, vtkIdType *sendLengths, vtkIdType *offsets, vtkIdType recvLength, int srcProcessId) |
int | ScatterV (const short *sendBuffer, short *recvBuffer, vtkIdType *sendLengths, vtkIdType *offsets, vtkIdType recvLength, int srcProcessId) |
int | ScatterV (const unsigned short *sendBuffer, unsigned short *recvBuffer, vtkIdType *sendLengths, vtkIdType *offsets, vtkIdType recvLength, int srcProcessId) |
int | ScatterV (const long *sendBuffer, long *recvBuffer, vtkIdType *sendLengths, vtkIdType *offsets, vtkIdType recvLength, int srcProcessId) |
int | ScatterV (const unsigned long *sendBuffer, unsigned long *recvBuffer, vtkIdType *sendLengths, vtkIdType *offsets, vtkIdType recvLength, int srcProcessId) |
int | ScatterV (const unsigned char *sendBuffer, unsigned char *recvBuffer, vtkIdType *sendLengths, vtkIdType *offsets, vtkIdType recvLength, int srcProcessId) |
int | ScatterV (const char *sendBuffer, char *recvBuffer, vtkIdType *sendLengths, vtkIdType *offsets, vtkIdType recvLength, int srcProcessId) |
int | ScatterV (const signed char *sendBuffer, signed char *recvBuffer, vtkIdType *sendLengths, vtkIdType *offsets, vtkIdType recvLength, int srcProcessId) |
int | ScatterV (const float *sendBuffer, float *recvBuffer, vtkIdType *sendLengths, vtkIdType *offsets, vtkIdType recvLength, int srcProcessId) |
int | ScatterV (const double *sendBuffer, double *recvBuffer, vtkIdType *sendLengths, vtkIdType *offsets, vtkIdType recvLength, int srcProcessId) |
int | ScatterV (const long long *sendBuffer, long long *recvBuffer, vtkIdType *sendLengths, vtkIdType *offsets, vtkIdType recvLength, int srcProcessId) |
int | ScatterV (const unsigned long long *sendBuffer, unsigned long long *recvBuffer, vtkIdType *sendLengths, vtkIdType *offsets, vtkIdType recvLength, int srcProcessId) |
int | AllGather (const int *sendBuffer, int *recvBuffer, vtkIdType length) |
int | AllGather (const unsigned int *sendBuffer, unsigned int *recvBuffer, vtkIdType length) |
int | AllGather (const short *sendBuffer, short *recvBuffer, vtkIdType length) |
int | AllGather (const unsigned short *sendBuffer, unsigned short *recvBuffer, vtkIdType length) |
int | AllGather (const long *sendBuffer, long *recvBuffer, vtkIdType length) |
int | AllGather (const unsigned long *sendBuffer, unsigned long *recvBuffer, vtkIdType length) |
int | AllGather (const unsigned char *sendBuffer, unsigned char *recvBuffer, vtkIdType length) |
int | AllGather (const char *sendBuffer, char *recvBuffer, vtkIdType length) |
int | AllGather (const signed char *sendBuffer, signed char *recvBuffer, vtkIdType length) |
int | AllGather (const float *sendBuffer, float *recvBuffer, vtkIdType length) |
int | AllGather (const double *sendBuffer, double *recvBuffer, vtkIdType length) |
int | AllGather (const long long *sendBuffer, long long *recvBuffer, vtkIdType length) |
int | AllGather (const unsigned long long *sendBuffer, unsigned long long *recvBuffer, vtkIdType length) |
int | AllGather (vtkDataArray *sendBuffer, vtkDataArray *recvBuffer) |
int | AllGatherV (const int *sendBuffer, int *recvBuffer, vtkIdType sendLength, vtkIdType *recvLengths, vtkIdType *offsets) |
int | AllGatherV (const unsigned int *sendBuffer, unsigned int *recvBuffer, vtkIdType sendLength, vtkIdType *recvLengths, vtkIdType *offsets) |
int | AllGatherV (const short *sendBuffer, short *recvBuffer, vtkIdType sendLength, vtkIdType *recvLengths, vtkIdType *offsets) |
int | AllGatherV (const unsigned short *sendBuffer, unsigned short *recvBuffer, vtkIdType sendLength, vtkIdType *recvLengths, vtkIdType *offsets) |
int | AllGatherV (const long *sendBuffer, long *recvBuffer, vtkIdType sendLength, vtkIdType *recvLengths, vtkIdType *offsets) |
int | AllGatherV (const unsigned long *sendBuffer, unsigned long *recvBuffer, vtkIdType sendLength, vtkIdType *recvLengths, vtkIdType *offsets) |
int | AllGatherV (const unsigned char *sendBuffer, unsigned char *recvBuffer, vtkIdType sendLength, vtkIdType *recvLengths, vtkIdType *offsets) |
int | AllGatherV (const char *sendBuffer, char *recvBuffer, vtkIdType sendLength, vtkIdType *recvLengths, vtkIdType *offsets) |
int | AllGatherV (const signed char *sendBuffer, signed char *recvBuffer, vtkIdType sendLength, vtkIdType *recvLengths, vtkIdType *offsets) |
int | AllGatherV (const float *sendBuffer, float *recvBuffer, vtkIdType sendLength, vtkIdType *recvLengths, vtkIdType *offsets) |
int | AllGatherV (const double *sendBuffer, double *recvBuffer, vtkIdType sendLength, vtkIdType *recvLengths, vtkIdType *offsets) |
int | AllGatherV (const long long *sendBuffer, long long *recvBuffer, vtkIdType sendLength, vtkIdType *recvLengths, vtkIdType *offsets) |
int | AllGatherV (const unsigned long long *sendBuffer, unsigned long long *recvBuffer, vtkIdType sendLength, vtkIdType *recvLengths, vtkIdType *offsets) |
int | AllGatherV (vtkDataArray *sendBuffer, vtkDataArray *recvBuffer, vtkIdType *recvLengths, vtkIdType *offsets) |
int | AllGatherV (vtkDataArray *sendBuffer, vtkDataArray *recvBuffer) |
int | Reduce (const int *sendBuffer, int *recvBuffer, vtkIdType length, int operation, int destProcessId) |
int | Reduce (const unsigned int *sendBuffer, unsigned int *recvBuffer, vtkIdType length, int operation, int destProcessId) |
int | Reduce (const short *sendBuffer, short *recvBuffer, vtkIdType length, int operation, int destProcessId) |
int | Reduce (const unsigned short *sendBuffer, unsigned short *recvBuffer, vtkIdType length, int operation, int destProcessId) |
int | Reduce (const long *sendBuffer, long *recvBuffer, vtkIdType length, int operation, int destProcessId) |
int | Reduce (const unsigned long *sendBuffer, unsigned long *recvBuffer, vtkIdType length, int operation, int destProcessId) |
int | Reduce (const unsigned char *sendBuffer, unsigned char *recvBuffer, vtkIdType length, int operation, int destProcessId) |
int | Reduce (const char *sendBuffer, char *recvBuffer, vtkIdType length, int operation, int destProcessId) |
int | Reduce (const signed char *sendBuffer, signed char *recvBuffer, vtkIdType length, int operation, int destProcessId) |
int | Reduce (const float *sendBuffer, float *recvBuffer, vtkIdType length, int operation, int destProcessId) |
int | Reduce (const double *sendBuffer, double *recvBuffer, vtkIdType length, int operation, int destProcessId) |
int | Reduce (const long long *sendBuffer, long long *recvBuffer, vtkIdType length, int operation, int destProcessId) |
int | Reduce (const unsigned long long *sendBuffer, unsigned long long *recvBuffer, vtkIdType length, int operation, int destProcessId) |
int | Reduce (vtkDataArray *sendBuffer, vtkDataArray *recvBuffer, int operation, int destProcessId) |
int | Reduce (const int *sendBuffer, int *recvBuffer, vtkIdType length, vtkCommunicator::Operation *operation, int destProcessId) |
int | Reduce (const unsigned int *sendBuffer, unsigned int *recvBuffer, vtkIdType length, vtkCommunicator::Operation *operation, int destProcessId) |
int | Reduce (const short *sendBuffer, short *recvBuffer, vtkIdType length, vtkCommunicator::Operation *operation, int destProcessId) |
int | Reduce (const unsigned short *sendBuffer, unsigned short *recvBuffer, vtkIdType length, vtkCommunicator::Operation *operation, int destProcessId) |
int | Reduce (const long *sendBuffer, long *recvBuffer, vtkIdType length, vtkCommunicator::Operation *operation, int destProcessId) |
int | Reduce (const unsigned long *sendBuffer, unsigned long *recvBuffer, vtkIdType length, vtkCommunicator::Operation *operation, int destProcessId) |
int | Reduce (const unsigned char *sendBuffer, unsigned char *recvBuffer, vtkIdType length, vtkCommunicator::Operation *operation, int destProcessId) |
int | Reduce (const char *sendBuffer, char *recvBuffer, vtkIdType length, vtkCommunicator::Operation *operation, int destProcessId) |
int | Reduce (const signed char *sendBuffer, signed char *recvBuffer, vtkIdType length, vtkCommunicator::Operation *operation, int destProcessId) |
int | Reduce (const float *sendBuffer, float *recvBuffer, vtkIdType length, vtkCommunicator::Operation *operation, int destProcessId) |
int | Reduce (const double *sendBuffer, double *recvBuffer, vtkIdType length, vtkCommunicator::Operation *operation, int destProcessId) |
int | Reduce (const long long *sendBuffer, long long *recvBuffer, vtkIdType length, vtkCommunicator::Operation *operation, int destProcessId) |
int | Reduce (const unsigned long long *sendBuffer, unsigned long long *recvBuffer, vtkIdType length, vtkCommunicator::Operation *operation, int destProcessId) |
int | Reduce (vtkDataArray *sendBuffer, vtkDataArray *recvBuffer, vtkCommunicator::Operation *operation, int destProcessId) |
int | AllReduce (const int *sendBuffer, int *recvBuffer, vtkIdType length, int operation) |
int | AllReduce (const unsigned int *sendBuffer, unsigned int *recvBuffer, vtkIdType length, int operation) |
int | AllReduce (const short *sendBuffer, short *recvBuffer, vtkIdType length, int operation) |
int | AllReduce (const unsigned short *sendBuffer, unsigned short *recvBuffer, vtkIdType length, int operation) |
int | AllReduce (const long *sendBuffer, long *recvBuffer, vtkIdType length, int operation) |
int | AllReduce (const unsigned long *sendBuffer, unsigned long *recvBuffer, vtkIdType length, int operation) |
int | AllReduce (const unsigned char *sendBuffer, unsigned char *recvBuffer, vtkIdType length, int operation) |
int | AllReduce (const char *sendBuffer, char *recvBuffer, vtkIdType length, int operation) |
int | AllReduce (const signed char *sendBuffer, signed char *recvBuffer, vtkIdType length, int operation) |
int | AllReduce (const float *sendBuffer, float *recvBuffer, vtkIdType length, int operation) |
int | AllReduce (const double *sendBuffer, double *recvBuffer, vtkIdType length, int operation) |
int | AllReduce (const long long *sendBuffer, long long *recvBuffer, vtkIdType length, int operation) |
int | AllReduce (const unsigned long long *sendBuffer, unsigned long long *recvBuffer, vtkIdType length, int operation) |
int | AllReduce (vtkDataArray *sendBuffer, vtkDataArray *recvBuffer, int operation) |
virtual void | Modified () |
