vtkMTimeType | GetMTime () override |
| Return the MTime also considering the internal writer. More...
int | Write () |
| Invoke the writer. More...
int | ProcessRequest (vtkInformation *, vtkInformationVector **, vtkInformationVector *) override |
| see vtkAlgorithm for details More...
void | SetInterpreter (vtkClientServerInterpreter *interp) |
| Get/Set the interpreter to use to call methods on the writer. More...
virtual void | SetWriter (vtkAlgorithm *) |
| Set/get the internal writer. More...
virtual vtkAlgorithm * | GetWriter () |
virtual void | SetFileNameMethod (const char *) |
| Name of the method used to set the file name of the internal writer. More...
virtual char * | GetFileNameMethod () |
virtual void | SetFileName (const char *) |
| Get/Set the name of the output file. More...
virtual char * | GetFileName () |
virtual int | GetWriteAllTimeSteps () |
| If Off, which is the default, only the current timestep is written. More...
virtual void | SetWriteAllTimeSteps (int) |
virtual void | WriteAllTimeStepsOn () |
virtual void | WriteAllTimeStepsOff () |
virtual bool | GetWriteJsonMetaFile () |
| If true, write a .series json meta file when writing all time steps. More...
virtual void | SetWriteJsonMetaFile (bool) |
virtual void | WriteJsonMetaFileOn () |
virtual void | WriteJsonMetaFileOff () |
virtual char * | GetFileNameSuffix () |
| Provides an option to pad the time step when writing out time series data. More...
virtual void | SetFileNameSuffix (const char *) |
virtual int | GetMinTimeStep () |
| Sets a minimum timestep constraint on WriteAllTimeSteps. More...
virtual void | SetMinTimeStep (int) |
virtual int | GetMaxTimeStep () |
| Sets a maximum timestep constraint on WriteAllTimeSteps. More...
virtual void | SetMaxTimeStep (int) |
virtual int | GetTimeStepStride () |
| Sets a stride to write out time series. More...
virtual void | SetTimeStepStride (int) |
vtkDataObjectAlgorithm * | NewInstance () const |
virtual void | SetOutput (vtkDataObject *d) |
int | HasExecutive () |
void | RemoveAllInputs () |
virtual void | Update () |
void | ReleaseDataFlagOn () |
int * | GetUpdateExtent () |
int | GetUpdatePiece () |
virtual void | Modified () |
