void | GetActors (vtkPropCollection *) override |
| For some exporters and other other operations we must be able to collect all the actors or volumes. More...
void | UpdateGeometry (vtkViewport *viewport, bool doRegularUpdate) |
| Updates the billboard geometry without performing any rendering, to assist GetActors(). More...
void | SetCustomTickPositions (int axis, vtkDoubleArray *positions) |
| Set custom tick positions for each of the axes. More...
int | RenderOpaqueGeometry (vtkViewport *) override |
int | RenderTranslucentPolygonalGeometry (vtkViewport *viewport) override |
int | RenderOverlay (vtkViewport *viewport) override |
int | HasTranslucentPolygonalGeometry () override |
void | ReleaseGraphicsResources (vtkWindow *) override |
vtkMTimeType | GetMTime () override |
| Overridden to include the mtime for the text properties. More...
virtual void | SetGridBounds (double, double, double, double, double, double) |
| Set the bounding box defining the grid space. More...
virtual void | SetGridBounds (double [6]) |
virtual double * | GetGridBounds () |
virtual void | GetGridBounds (double &, double &, double &, double &, double &, double &) |
virtual void | GetGridBounds (double [6]) |
virtual void | SetFace (int) |
| Indicate which face of the specified bounds is this class operating with. More...
virtual int | GetFace () |
virtual void | SetLabelMask (unsigned int) |
| Set the axes to label. More...
virtual unsigned int | GetLabelMask () |
void | SetProperty (vtkProperty *) |
| Get/Set the property used to control the appearance of the rendered grid, including edges. More...
vtkProperty * | GetProperty () |
void | SetTitleTextProperty (int axis, vtkTextProperty *) |
| Get/Set the title text properties for each of the coordinate axes. More...
vtkTextProperty * | GetTitleTextProperty (int axis) |
void | SetLabelTextProperty (int axis, vtkTextProperty *) |
| Get/Set the label text properties for each of the coordinate axes. More...
vtkTextProperty * | GetLabelTextProperty (int axis) |
void | SetTitle (int axis, const std::string &title) |
| Set titles for each of the axes. More...
const std::string & | GetTitle (int axis) |
void | SetNotation (int axis, int notation) |
| Get/set the numerical notation, standard, scientific or mixed (0, 1, 2). More...
int | GetNotation (int axis) |
void | SetPrecision (int axis, int val) |
| Get/set the numerical precision to use, default is 2. More...
int | GetPrecision (int axis) |
void | SetTickLabelFunction (int axis, std::function< double(double)> func) |
| Get/Set the function that will be applied to the tick label of each axis. More...
std::function< double(double)> | GetTickLabelFunction (int axis) |
void | SetGenerateGrid (bool val) |
| Turn off to not generate polydata for the plane's grid. More...
bool | GetGenerateGrid () |
virtual void | GenerateGridOn () |
virtual void | GenerateGridOff () |
void | SetGenerateEdges (bool val) |
| Turn off to not generate the polydata for the plane's edges. More...
bool | GetGenerateEdges () |
virtual void | GenerateEdgesOn () |
virtual void | GenerateEdgesOff () |
void | SetGenerateTicks (bool val) |
| Turn off to not generate the markers for the tick positions. More...
bool | GetGenerateTicks () |
virtual void | GenerateTicksOn () |
virtual void | GenerateTicksOff () |
double * | GetBounds () override |
| Returns the prop bounds. More...
virtual void | SetForceOpaque (bool) |
| If true, the actor will always be rendered during the opaque pass. More...
virtual bool | GetForceOpaque () |
virtual void | ForceOpaqueOn () |
virtual void | ForceOpaqueOff () |
vtkProp3D * | NewInstance () const |
void | ShallowCopy (vtkProp *prop) |
virtual void | SetPosition (double pos[3]) |
virtual double * | GetPosition () |
virtual void | GetPosition (double data[3]) |
void | AddPosition (double deltaPosition[3]) |
void | AddPosition (double deltaX, double deltaY, double deltaZ) |
double * | GetCenter () |
double * | GetXRange () |
double * | GetYRange () |
double * | GetZRange () |
double | GetLength () |
void | RotateX (double) |
void | RotateY (double) |
void | RotateZ (double) |
void | RotateWXYZ (double w, double x, double y, double z) |
void | SetOrientation (double x, double y, double z) |
void | SetOrientation (double orientation[3]) |
double * | GetOrientationWXYZ () |
void | AddOrientation (double x, double y, double z) |
void | AddOrientation (double orentation[3]) |
void | PokeMatrix (vtkMatrix4x4 *matrix) |
void | InitPathTraversal () |
vtkMTimeType | GetUserTransformMatrixMTime () |
virtual void | ComputeMatrix () |
virtual void | SetPosition (double x, double y, double z) |
virtual void | SetOrigin (double x, double y, double z) |
virtual void | SetOrigin (const double pos[3]) |
virtual double * | GetOrigin () |
virtual void | GetOrigin (double data[3]) |
virtual void | SetScale (double x, double y, double z) |
virtual void | SetScale (double scale[3]) |
virtual double * | GetScale () |
virtual void | GetScale (double data[3]) |
void | SetScale (double s) |
void | SetUserTransform (vtkLinearTransform *transform) |
virtual vtkLinearTransform * | GetUserTransform () |
void | SetUserMatrix (vtkMatrix4x4 *matrix) |
vtkMatrix4x4 * | GetUserMatrix () |
virtual void | GetMatrix (vtkMatrix4x4 *m) |
virtual void | GetMatrix (double m[16]) |
void | GetBounds (double bounds[6]) |
double * | GetOrientation () |
void | GetOrientation (double orentation[3]) |
vtkMatrix4x4 * | GetMatrix () |
virtual int | GetIsIdentity () |
vtkProp * | NewInstance () const |
virtual void | Pick () |
virtual bool | HasKeys (vtkInformation *requiredKeys) |
virtual void | BuildPaths (vtkAssemblyPaths *paths, vtkAssemblyPath *path) |
virtual void | GetActors2D (vtkPropCollection *) |
virtual void | GetVolumes (vtkPropCollection *) |
virtual void | SetVisibility (int) |
virtual int | GetVisibility () |
virtual void | VisibilityOn () |
virtual void | VisibilityOff () |
virtual void | SetPickable (int) |
virtual int | GetPickable () |
virtual void | PickableOn () |
virtual void | PickableOff () |
virtual void | SetDragable (int) |
virtual int | GetDragable () |
virtual void | DragableOn () |
virtual void | DragableOff () |
virtual vtkMTimeType | GetRedrawMTime () |
virtual void | SetUseBounds (bool) |
virtual bool | GetUseBounds () |
virtual void | UseBoundsOn () |
virtual void | UseBoundsOff () |
virtual vtkAssemblyPath * | GetNextPath () |
virtual int | GetNumberOfPaths () |
virtual void | PokeMatrix (vtkMatrix4x4 *vtkNotUsed(matrix)) |
virtual vtkInformation * | GetPropertyKeys () |
virtual void | SetPropertyKeys (vtkInformation *keys) |
virtual int | RenderVolumetricGeometry (vtkViewport *) |
virtual bool | RenderFilteredOpaqueGeometry (vtkViewport *v, vtkInformation *requiredKeys) |
virtual bool | RenderFilteredTranslucentPolygonalGeometry (vtkViewport *v, vtkInformation *requiredKeys) |
virtual bool | RenderFilteredVolumetricGeometry (vtkViewport *v, vtkInformation *requiredKeys) |
virtual bool | RenderFilteredOverlay (vtkViewport *v, vtkInformation *requiredKeys) |
virtual double | GetEstimatedRenderTime (vtkViewport *) |
virtual double | GetEstimatedRenderTime () |
virtual void | SetEstimatedRenderTime (double t) |
virtual void | RestoreEstimatedRenderTime () |
virtual void | AddEstimatedRenderTime (double t, vtkViewport *vtkNotUsed(vp)) |
virtual void | SetAllocatedRenderTime (double t, vtkViewport *vtkNotUsed(v)) |
virtual double | GetAllocatedRenderTime () |
void | SetRenderTimeMultiplier (double t) |
virtual double | GetRenderTimeMultiplier () |
virtual bool | GetSupportsSelection () |
virtual int | GetNumberOfConsumers () |
void | AddConsumer (vtkObject *c) |
void | RemoveConsumer (vtkObject *c) |
vtkObject * | GetConsumer (int i) |
int | IsConsumer (vtkObject *c) |
virtual void | Modified () |
