vtkGridAxesPlane2DActor Class Reference
renders a 2D grid for vtkGridAxes2DActor. More...
#include <vtkGridAxesPlane2DActor.h>
Inheritance diagram for vtkGridAxesPlane2DActor:
Collaboration diagram for vtkGridAxesPlane2DActor:
enum  Faces {
  MIN_YZ = vtkGridAxesHelper::MIN_YZ, MIN_ZX = vtkGridAxesHelper::MIN_ZX, MIN_XY = vtkGridAxesHelper::MIN_XY, MAX_YZ = vtkGridAxesHelper::MAX_YZ,
  MAX_ZX = vtkGridAxesHelper::MAX_ZX, MAX_XY = vtkGridAxesHelper::MAX_XY
enum  { TICK_DIRECTION_INWARDS = 0x1, TICK_DIRECTION_OUTWARDS = 0x2, TICK_DIRECTION_BOTH = TICK_DIRECTION_INWARDS | TICK_DIRECTION_OUTWARDS }
typedef vtkProp3D Superclass
- Public Types inherited from vtkProp3D
typedef vtkProp Superclass
void GetActors (vtkPropCollection *) override
 For some exporters and other other operations we must be able to collect all the actors or volumes. More...
void UpdateGeometry (vtkViewport *vp)
 Updates the billboard geometry without performing any rendering, to assist GetActors(). More...
void SetTickPositions (int axis, vtkDoubleArray *data)
 Set the tick positions for each of the coordinate axis. More...
const std::deque< double > & GetTickPositions (int axis)
int RenderOpaqueGeometry (vtkViewport *) override
int RenderTranslucentPolygonalGeometry (vtkViewport *viewport) override
int RenderOverlay (vtkViewport *viewport) override
int HasTranslucentPolygonalGeometry () override
void ReleaseGraphicsResources (vtkWindow *) override
virtual void SetGridBounds (double, double, double, double, double, double)
 Set the bounding box defining the grid space. More...
virtual void SetGridBounds (double [6])
virtual doubleGetGridBounds ()
virtual void GetGridBounds (double &, double &, double &, double &, double &, double &)
virtual void GetGridBounds (double [6])
virtual void SetFace (int)
 Indicate which face of the specified bounds is this class operating with. More...
virtual int GetFace ()
virtual void SetGenerateGrid (bool)
 Get/Set whether to generate lines for the plane's grid. More...
virtual bool GetGenerateGrid ()
virtual void GenerateGridOn ()
virtual void GenerateGridOff ()
virtual void SetGenerateEdges (bool)
 Get/Set whether to generate the polydata for the plane's edges. More...
virtual bool GetGenerateEdges ()
virtual void GenerateEdgesOn ()
virtual void GenerateEdgesOff ()
virtual void SetGenerateTicks (bool)
 Get/Set whether to generate tick markers for the tick positions. More...
virtual bool GetGenerateTicks ()
virtual void GenerateTicksOn ()
virtual void GenerateTicksOff ()
virtual void SetTickDirection (unsigned int)
 Get/Set the tick direction. More...
virtual unsigned int GetTickDirection ()
void SetProperty (vtkProperty *)
 Get/Set the property used to control the appearance of the rendered grid. More...
vtkPropertyGetProperty ()
doubleGetBounds () override
 Returns the prop bounds. More...
- Public Member Functions inherited from vtkProp3D
vtkProp3DNewInstance () const
void ShallowCopy (vtkProp *prop)
virtual void SetPosition (double pos[3])
virtual doubleGetPosition ()
virtual void GetPosition (double data[3])
void AddPosition (double deltaPosition[3])
void AddPosition (double deltaX, double deltaY, double deltaZ)
doubleGetCenter ()
doubleGetXRange ()
doubleGetYRange ()
doubleGetZRange ()
double GetLength ()
void RotateX (double)
void RotateY (double)
void RotateZ (double)
void RotateWXYZ (double w, double x, double y, double z)
void SetOrientation (double x, double y, double z)
void SetOrientation (double orientation[3])
doubleGetOrientationWXYZ ()
void AddOrientation (double x, double y, double z)
void AddOrientation (double orentation[3])
void PokeMatrix (vtkMatrix4x4 *matrix)
void InitPathTraversal ()
vtkMTimeType GetMTime ()
vtkMTimeType GetUserTransformMatrixMTime ()
virtual void ComputeMatrix ()
virtual void SetPosition (double x, double y, double z)
virtual void SetOrigin (double x, double y, double z)
virtual void SetOrigin (const double pos[3])
virtual doubleGetOrigin ()
virtual void GetOrigin (double data[3])
virtual void SetScale (double x, double y, double z)
virtual void SetScale (double scale[3])
virtual doubleGetScale ()
virtual void GetScale (double data[3])
void SetScale (double s)
void SetUserTransform (vtkLinearTransform *transform)
virtual vtkLinearTransformGetUserTransform ()
void SetUserMatrix (vtkMatrix4x4 *matrix)
vtkMatrix4x4GetUserMatrix ()
virtual void GetMatrix (vtkMatrix4x4 *m)
virtual void GetMatrix (double m[16])
void GetBounds (double bounds[6])
doubleGetOrientation ()
void GetOrientation (double orentation[3])
vtkMatrix4x4GetMatrix ()
virtual int GetIsIdentity ()
vtkPropNewInstance () const
virtual void Pick ()
virtual bool HasKeys (vtkInformation *requiredKeys)
virtual void BuildPaths (vtkAssemblyPaths *paths, vtkAssemblyPath *path)
virtual void GetActors2D (vtkPropCollection *)
virtual void GetVolumes (vtkPropCollection *)
virtual void SetVisibility (int)
virtual int GetVisibility ()
virtual void VisibilityOn ()
virtual void VisibilityOff ()
virtual void SetPickable (int)
virtual int GetPickable ()
virtual void PickableOn ()
virtual void PickableOff ()
virtual void SetDragable (int)
virtual int GetDragable ()
virtual void DragableOn ()
virtual void DragableOff ()
virtual vtkMTimeType GetRedrawMTime ()
virtual void SetUseBounds (bool)
virtual bool GetUseBounds ()
virtual void UseBoundsOn ()
virtual void UseBoundsOff ()
virtual vtkAssemblyPathGetNextPath ()
virtual int GetNumberOfPaths ()
virtual void PokeMatrix (vtkMatrix4x4 *vtkNotUsed(matrix))
virtual vtkInformationGetPropertyKeys ()
virtual void SetPropertyKeys (vtkInformation *keys)
virtual int RenderVolumetricGeometry (vtkViewport *)
virtual bool RenderFilteredOpaqueGeometry (vtkViewport *v, vtkInformation *requiredKeys)
virtual bool RenderFilteredTranslucentPolygonalGeometry (vtkViewport *v, vtkInformation *requiredKeys)
virtual bool RenderFilteredVolumetricGeometry (vtkViewport *v, vtkInformation *requiredKeys)
virtual bool RenderFilteredOverlay (vtkViewport *v, vtkInformation *requiredKeys)
virtual double GetEstimatedRenderTime (vtkViewport *)
virtual double GetEstimatedRenderTime ()
virtual void SetEstimatedRenderTime (double t)
virtual void RestoreEstimatedRenderTime ()
virtual void AddEstimatedRenderTime (double t, vtkViewport *vtkNotUsed(vp))
virtual void SetAllocatedRenderTime (double t, vtkViewport *vtkNotUsed(v))
virtual double GetAllocatedRenderTime ()
void SetRenderTimeMultiplier (double t)
virtual double GetRenderTimeMultiplier ()
virtual bool GetSupportsSelection ()
virtual int GetNumberOfConsumers ()
void AddConsumer (vtkObject *c)
void RemoveConsumer (vtkObject *c)
vtkObjectGetConsumer (int i)
int IsConsumer (vtkObject *c)
static vtkGridAxesPlane2DActorNew ()
static vtkGridAxesPlane2DActorSafeDownCast (vtkObject *o)
- Static Public Member Functions inherited from vtkProp3D
static vtkProp3DSafeDownCast (vtkObjectBase *o)
static vtkPropSafeDownCast (vtkObjectBase *o)
static vtkInformationIntegerKeyGeneralTextureUnit ()
static vtkInformationDoubleVectorKeyGeneralTextureTransform ()
static vtkObjectNew ()
static vtkObjectBaseNew ()
 vtkGridAxesPlane2DActor (vtkGridAxesHelper *helper=nullptr)
 ~vtkGridAxesPlane2DActor () override
void Update (vtkViewport *viewport)
 Update's the polydata. More...
bool UpdateEdges (vtkViewport *viewport)
bool UpdateGrid (vtkViewport *viewport)
bool UpdateTicks (vtkViewport *viewport)
- Protected Member Functions inherited from vtkProp3D
 vtkProp3D ()
 ~vtkProp3D ()
 vtkProp ()
 ~vtkProp ()
double GridBounds [6]
int Face
bool GenerateGrid
bool GenerateEdges
bool GenerateTicks
unsigned int TickDirection
std::deque< doubleTickPositions [3]
vtkNew< vtkPolyDataPolyData
vtkNew< vtkPointsPolyDataPoints
vtkNew< vtkCellArrayPolyDataLines
vtkNew< vtkPolyDataMapperMapper
vtkNew< vtkActorActor
vtkSmartPointer< vtkGridAxesHelperHelper
bool HelperManagedExternally
- Protected Attributes inherited from vtkProp3D
vtkLinearTransformUserTransform
vtkMatrix4x4UserMatrix
vtkMatrix4x4Matrix
vtkTimeStamp MatrixMTime
double Origin [3]
double Position [3]
double Orientation [3]
double Scale [3]
double Center [3]
vtkTransformTransform
double Bounds [6]
vtkProp3DCachedProp3D
int IsIdentity
int Visibility
int Pickable
int Dragable
bool UseBounds
double AllocatedRenderTime
double EstimatedRenderTime
double SavedEstimatedRenderTime
double RenderTimeMultiplier
int NumberOfConsumers
vtkObject ** Consumers
vtkAssemblyPathsPaths
vtkInformationPropertyKeys
class vtkGridAxes2DActor
 vtkGridAxes2DActor uses this method to create vtkGridAxesPlane2DActor instance. More...
static vtkGridAxesPlane2DActorNew (vtkGridAxesHelper *helper)
vtkGridAxesPlane2DActor is designed for use by vtkGridAxes2DActor to render the wireframe for the grid plane. It can also be used directly to render such a wireframe in a renderer.
Definition at line 32 of file vtkGridAxesPlane2DActor.h.
Definition at line 36 of file vtkGridAxesPlane2DActor.h.
◆ Faces
Enumerator
MIN_YZ
MIN_ZX
MIN_XY
MAX_YZ
MAX_ZX
MAX_XY
Definition at line 53 of file vtkGridAxesPlane2DActor.h.
◆ anonymous enum
anonymous enum
Enumerator
TICK_DIRECTION_BOTH
Definition at line 119 of file vtkGridAxesPlane2DActor.h.
◆ vtkGridAxesPlane2DActor()
vtkGridAxesPlane2DActor::vtkGridAxesPlane2DActor ( vtkGridAxesHelper helper = nullptr)
◆ ~vtkGridAxesPlane2DActor()
vtkGridAxesPlane2DActor::~vtkGridAxesPlane2DActor ( )
◆ New() [1/2]
static vtkGridAxesPlane2DActor* vtkGridAxesPlane2DActor::New ( )
virtual const char* vtkGridAxesPlane2DActor::GetClassName ( )
static int vtkGridAxesPlane2DActor::IsTypeOf ( const char *  type)
virtual int vtkGridAxesPlane2DActor::IsA ( const char *  type)
Reimplemented from vtkProp3D.
static vtkGridAxesPlane2DActor* vtkGridAxesPlane2DActor::SafeDownCast ( vtkObject o)
void vtkGridAxesPlane2DActor::PrintSelf ( ostream &  os,
◆ SetGridBounds() [1/2]
virtual void vtkGridAxesPlane2DActor::SetGridBounds ( double  ,
double  ,
double  ,
double  ,
double  ,
double
This, together with the Face identify which planar surface this class is interested in. This class is designed to work with a single planar surface. Note: this is only needed/used when the vtkGridAxesHelper is not provided when calling New(), otherwise the vtkGridAxesHelper is assumed to be initialized externally.
◆ SetGridBounds() [2/2]
virtual void vtkGridAxesPlane2DActor::SetGridBounds ( double  [6])
◆ GetGridBounds() [1/3]
virtual double* vtkGridAxesPlane2DActor::GetGridBounds ( )
◆ GetGridBounds() [2/3]
virtual void vtkGridAxesPlane2DActor::GetGridBounds ( double ,
double ,
double ,
double ,
double ,
double
◆ GetGridBounds() [3/3]
virtual void vtkGridAxesPlane2DActor::GetGridBounds ( double  [6])
◆ SetFace()
virtual void vtkGridAxesPlane2DActor::SetFace ( int  )
◆ GetFace()
virtual int vtkGridAxesPlane2DActor::GetFace ( )
◆ GetActors()
void vtkGridAxesPlane2DActor::GetActors ( vtkPropCollection )
These methods are used in that process. In case the viewport is not a consumer of this prop: call UpdateGeometry() first for updated viewport-specific billboard geometry.
Reimplemented from vtkProp.
◆ UpdateGeometry()
void vtkGridAxesPlane2DActor::UpdateGeometry ( vtkViewport vp)
◆ SetGenerateGrid()
virtual void vtkGridAxesPlane2DActor::SetGenerateGrid ( bool  )
Default is true.
◆ GetGenerateGrid()
virtual bool vtkGridAxesPlane2DActor::GetGenerateGrid ( )
Default is true.
◆ GenerateGridOn()
virtual void vtkGridAxesPlane2DActor::GenerateGridOn ( )
Default is true.
◆ GenerateGridOff()
virtual void vtkGridAxesPlane2DActor::GenerateGridOff ( )
Default is true.
◆ SetGenerateEdges()
virtual void vtkGridAxesPlane2DActor::SetGenerateEdges ( bool  )
Default is true.
◆ GetGenerateEdges()
virtual bool vtkGridAxesPlane2DActor::GetGenerateEdges ( )
Default is true.
◆ GenerateEdgesOn()
virtual void vtkGridAxesPlane2DActor::GenerateEdgesOn ( )
Default is true.
◆ GenerateEdgesOff()
virtual void vtkGridAxesPlane2DActor::GenerateEdgesOff ( )
Default is true.
◆ SetGenerateTicks()
virtual void vtkGridAxesPlane2DActor::SetGenerateTicks ( bool  )
Default is true.
◆ GetGenerateTicks()
virtual bool vtkGridAxesPlane2DActor::GetGenerateTicks ( )
Default is true.
◆ GenerateTicksOn()
virtual void vtkGridAxesPlane2DActor::GenerateTicksOn ( )
Default is true.
◆ GenerateTicksOff()
virtual void vtkGridAxesPlane2DActor::GenerateTicksOff ( )
Default is true.
◆ SetTickDirection()
virtual void vtkGridAxesPlane2DActor::SetTickDirection ( unsigned  int)
◆ GetTickDirection()
virtual unsigned int vtkGridAxesPlane2DActor::GetTickDirection ( )
◆ SetTickPositions()
void vtkGridAxesPlane2DActor::SetTickPositions ( int  axis,
vtkDoubleArray data
Which tick positions get used depended on the face being rendered e.g. if Face is MIN_XY, then the tick positions for Z-axis i.e. axis=2 will not be used and hence need not be specified. Pass nullptr for data will clear the ticks positions for that axis. Note: This creates a deep-copy of the values in data and stores that.
◆ GetTickPositions()
const std::deque<double>& vtkGridAxesPlane2DActor::GetTickPositions ( int  axis)
inline
Definition at line 144 of file vtkGridAxesPlane2DActor.h.
◆ SetProperty()
void vtkGridAxesPlane2DActor::SetProperty ( vtkProperty )
◆ GetProperty()
vtkProperty* vtkGridAxesPlane2DActor::GetProperty ( )
◆ GetBounds()
double* vtkGridAxesPlane2DActor::GetBounds ( void  )
inlineoverridevirtual
Implements vtkProp3D.
Definition at line 165 of file vtkGridAxesPlane2DActor.h.
◆ RenderOpaqueGeometry()
int vtkGridAxesPlane2DActor::RenderOpaqueGeometry ( vtkViewport )
◆ RenderTranslucentPolygonalGeometry()
int vtkGridAxesPlane2DActor::RenderTranslucentPolygonalGeometry ( vtkViewport viewport)
◆ RenderOverlay()
int vtkGridAxesPlane2DActor::RenderOverlay ( vtkViewport viewport)
◆ HasTranslucentPolygonalGeometry()
int vtkGridAxesPlane2DActor::HasTranslucentPolygonalGeometry ( )
◆ ReleaseGraphicsResources()
void vtkGridAxesPlane2DActor::ReleaseGraphicsResources ( vtkWindow )
◆ New() [2/2]
static vtkGridAxesPlane2DActor* vtkGridAxesPlane2DActor::New ( vtkGridAxesHelper helper)
staticprotected
In that case, vtkGridAxesPlane2DActor assumes that the vtkGridAxesHelper will be updated and initialized externally. That avoids unnecessary duplicate computations per render.
◆ Update()
void vtkGridAxesPlane2DActor::Update ( vtkViewport viewport)
◆ UpdateEdges()
bool vtkGridAxesPlane2DActor::UpdateEdges ( vtkViewport viewport)
◆ UpdateGrid()
bool vtkGridAxesPlane2DActor::UpdateGrid ( vtkViewport viewport)
◆ UpdateTicks()
bool vtkGridAxesPlane2DActor::UpdateTicks ( vtkViewport viewport)
◆ vtkGridAxes2DActor
friend class vtkGridAxes2DActor
friend
Definition at line 190 of file vtkGridAxesPlane2DActor.h.
◆ GridBounds
double vtkGridAxesPlane2DActor::GridBounds[6]
Definition at line 203 of file vtkGridAxesPlane2DActor.h.
◆ Face
int vtkGridAxesPlane2DActor::Face
Definition at line 204 of file vtkGridAxesPlane2DActor.h.
◆ GenerateGrid
bool vtkGridAxesPlane2DActor::GenerateGrid
Definition at line 206 of file vtkGridAxesPlane2DActor.h.
◆ GenerateEdges
bool vtkGridAxesPlane2DActor::GenerateEdges
Definition at line 207 of file vtkGridAxesPlane2DActor.h.
◆ GenerateTicks
bool vtkGridAxesPlane2DActor::GenerateTicks
Definition at line 208 of file vtkGridAxesPlane2DActor.h.
◆ TickDirection
unsigned int vtkGridAxesPlane2DActor::TickDirection
Definition at line 209 of file vtkGridAxesPlane2DActor.h.
◆ TickPositions
std::deque<double> vtkGridAxesPlane2DActor::TickPositions[3]
Definition at line 210 of file vtkGridAxesPlane2DActor.h.
◆ PolyData
vtkNew<vtkPolyData> vtkGridAxesPlane2DActor::PolyData
Definition at line 212 of file vtkGridAxesPlane2DActor.h.
◆ PolyDataPoints
vtkNew<vtkPoints> vtkGridAxesPlane2DActor::PolyDataPoints
Definition at line 213 of file vtkGridAxesPlane2DActor.h.
◆ PolyDataLines
vtkNew<vtkCellArray> vtkGridAxesPlane2DActor::PolyDataLines
Definition at line 214 of file vtkGridAxesPlane2DActor.h.
◆ Mapper
vtkNew<vtkPolyDataMapper> vtkGridAxesPlane2DActor::Mapper
Definition at line 215 of file vtkGridAxesPlane2DActor.h.
◆ Actor
vtkNew<vtkActor> vtkGridAxesPlane2DActor::Actor
Definition at line 216 of file vtkGridAxesPlane2DActor.h.
◆ Helper
vtkSmartPointer<vtkGridAxesHelper> vtkGridAxesPlane2DActor::Helper
Definition at line 218 of file vtkGridAxesPlane2DActor.h.
◆ HelperManagedExternally
bool vtkGridAxesPlane2DActor::HelperManagedExternally
Definition at line 219 of file vtkGridAxesPlane2DActor.h.
