virtual void | SetQuality (int) |
| Set the quality measure. More...
virtual int | GetQuality () |
int | Compress () override |
| Compress/Decompress data array on the objects input with results in the objects output. More...
int | Decompress () override |
void | SaveConfiguration (vtkMultiProcessStream *stream) override |
| Serialize/Restore compressor configuration (but not the data) into the stream. More...
bool | RestoreConfiguration (vtkMultiProcessStream *stream) override |
const char * | SaveConfiguration () override |
const char * | RestoreConfiguration (const char *stream) override |
virtual void | SetImageResolution (int width, int height) |
| Communicates the next expected image resolution. More...
void | SetInput (vtkUnsignedCharArray *input) |
| Get/Set the input to this compressor. More...
virtual vtkUnsignedCharArray * | GetInput () |
virtual vtkUnsignedCharArray * | GetOutput () |
| Get/Set the output of the compressor. More...
void | SetOutput (vtkUnsignedCharArray *) |
virtual void | SetLossLessMode (int) |
| When set the implementation must use loss-less compression, otherwise implemnetation should user provided settings. More...
virtual int | GetLossLessMode () |
virtual void | Modified () |
