vtkNetworkAccessManager is used to create new connections and monitor activity of those connections. More...
#include <vtkNetworkAccessManager.h>
enum | ConnectionResult { ConnectionResult::CONNECTION_SUCCESS, ConnectionResult::CONNECTION_TIMEOUT, ConnectionResult::CONNECTION_ABORT, ConnectionResult::CONNECTION_HANDSHAKE_ERROR, ConnectionResult::CONNECTION_FAILURE } |
Possible result of connection when creating a new connection CONNECTION_SUCCESS: Connection was sucessfull CONNECTION_TIMEOUT: After spending a specified amount of time, no connection was initiated CONNECTION_ABORT: User aborted the connection before it was successful or timed out CONNECTION_HANDSHAKE_ERROR: Connection was iniated but the handshake failed CONNECTION_FAILURE: Unspecified connection error. More... | |
virtual void | AbortPendingConnection ()=0 |
Used to abort pending connection creation, if any. More... | |
virtual int | ProcessEvents (unsigned long timeout_msecs)=0 |
Process any network activity. More... | |
virtual bool | GetNetworkEventsAvailable ()=0 |
Peeks to check if any activity is available. More... | |
virtual bool | GetPendingConnectionsPresent ()=0 |
Returns true is the manager is currently waiting for any connections. More... | |
virtual void | DisableFurtherConnections (int port, bool disable)=0 |
Enable/disable further connections for given port. More... | |
virtual bool | GetWrongConnectID ()=0 |
Returns true if the last check of connect ids was wrong. More... | |
virtual vtkMultiProcessController * | NewConnection (const char *url) |
Creates a new connection given the url. More... | |
virtual vtkMultiProcessController * | NewConnection (const char *url, ConnectionResult &result)=0 |
virtual void | Modified () |
static vtkNetworkAccessManager * | SafeDownCast (vtkObject *o) |
static vtkObject * | New () |
vtkNetworkAccessManager () | |
~vtkNetworkAccessManager () override | |
vtkObject () | |
virtual | ~vtkObject () |
vtkObjectBase () | |
virtual | ~vtkObjectBase () |
bool | Debug |
vtkTimeStamp | MTime |
This is an abstract class that defines the interface. Concrete implementations of this class can be written to support tcp/ip socket or ssl or ssh based network connections among processes.
Definition at line 20 of file vtkNetworkAccessManager.h.
Definition at line 23 of file vtkNetworkAccessManager.h.
strong |
Enumerator | |
CONNECTION_SUCCESS | |
CONNECTION_TIMEOUT | |
CONNECTION_ABORT | |
CONNECTION_HANDSHAKE_ERROR | |
CONNECTION_FAILURE |
Definition at line 34 of file vtkNetworkAccessManager.h.
Reimplemented in vtkTCPNetworkAccessManager.
inlinevirtual |
This call may block until the connection can be established. To keep user-interfaces responsive, one can listen to the vtkCommand::ProgressEvent fired periodically by this class while waiting. The result arg provide information about the failure or sucess of the connection, see vtkNetworkAccessManager::ConnectionResult for possible values.
vtkNetworkAccessManager can be waiting for atmost one connection at a time. Calling NewConnection() while another connection is pending will raise an error.
To abort the connection and cancel the waiting, simply call AbortPendingConnection() in the vtkCommand::ProgressEvent callback.
Returns the new connection instance on success, otherwise nullptr.
URLs are of the following form: <transport>
://<address>
tcp://<hostname>
:<port>tcp://localhost
:<port>/listen – listen for connection on port.tcp://localhost
:<port>/listenmultiple – listen for multiple Examples:tcp://medea
:12345tcp://localhost
:12345/listenssh://utkarsh@medea
Definition at line 72 of file vtkNetworkAccessManager.h.
pure virtual |
://<address>
tcp://<hostname>
Implemented in vtkTCPNetworkAccessManager.
pure virtual |
Refer to NewConnection() for details.
pure virtual |
pure virtual |
When this call returns true, ProcessEvents() will always result in some activity processing if called afterword.
pure virtual |
pure virtual |
pure virtual |
