vtkTCPNetworkAccessManager is a concrete implementation of vtkNetworkAccessManager that uses tcp/ip sockets for communication between processes. More...
#include <vtkTCPNetworkAccessManager.h>
typedef vtkNetworkAccessManager | Superclass |
enum | ConnectionResult { ConnectionResult::CONNECTION_SUCCESS, ConnectionResult::CONNECTION_TIMEOUT, ConnectionResult::CONNECTION_ABORT, ConnectionResult::CONNECTION_HANDSHAKE_ERROR, ConnectionResult::CONNECTION_FAILURE } |
Possible result of connection when creating a new connection CONNECTION_SUCCESS: Connection was sucessfull CONNECTION_TIMEOUT: After spending a specified amount of time, no connection was initiated CONNECTION_ABORT: User aborted the connection before it was successful or timed out CONNECTION_HANDSHAKE_ERROR: Connection was iniated but the handshake failed CONNECTION_FAILURE: Unspecified connection error. More... | |
void | AbortPendingConnection () override |
Used to abort pending connection creation, if any. More... | |
int | ProcessEvents (unsigned long timeout_msecs) override |
Process any network activity. More... | |
bool | GetNetworkEventsAvailable () override |
Peeks to check if any activity is available. More... | |
bool | GetPendingConnectionsPresent () override |
Returns true is the manager is currently waiting for any connections. More... | |
void | DisableFurtherConnections (int port, bool disable) override |
Enable/disable further connections for given port. More... | |
bool | GetWrongConnectID () override |
Returns true if the last check of connect ids was wrong. More... | |
vtkMultiProcessController * | NewConnection (const char *url, vtkNetworkAccessManager::ConnectionResult &result) override |
Creates a new connection given the url. More... | |
virtual vtkMultiProcessController * | NewConnection (const char *url) |
virtual void | Modified () |
static vtkTCPNetworkAccessManager * | New () |
static vtkTCPNetworkAccessManager * | SafeDownCast (vtkObject *o) |
static vtkNetworkAccessManager * | SafeDownCast (vtkObject *o) |
static vtkObject * | New () |
vtkTCPNetworkAccessManager () | |
~vtkTCPNetworkAccessManager () override | |
int | ProcessEventsInternal (unsigned long timeout_msecs, bool do_processing) |
vtkMultiProcessController * | ConnectToRemote (const char *hostname, int port, const char *handshake, int timeout_in_seconds, vtkNetworkAccessManager::ConnectionResult &result) |
Connects to remote processes. More... | |
vtkMultiProcessController * | WaitForConnection (int port, bool once, const char *handshake, bool nonblocking, vtkNetworkAccessManager::ConnectionResult &result) |
Waits for connection from remote process. More... | |
int | ParaViewHandshake (vtkMultiProcessController *controller, bool server_side, const char *handshake) |
void | PrintHandshakeError (int errorcode, bool server_side) |
int | AnalyzeHandshakeAndGetErrorCode (const char *clientHS, const char *serverHS) |
vtkNetworkAccessManager () | |
~vtkNetworkAccessManager () override | |
vtkObject () | |
virtual | ~vtkObject () |
vtkObjectBase () | |
virtual | ~vtkObjectBase () |
Protected Attributes | |
bool | AbortPendingConnectionFlag |
bool | WrongConnectID |
bool | Debug |
vtkTimeStamp | MTime |
It supports urls that use "tcp" as their protocol specifier.
Definition at line 19 of file vtkTCPNetworkAccessManager.h.
Definition at line 23 of file vtkTCPNetworkAccessManager.h.
Enumerator | |
HANDSHAKE_NO_ERROR | |
HANDSHAKE_SOCKET_COMMUNICATOR_DIFFERENT | |
HANDSHAKE_DIFFERENT_PV_VERSIONS | |
HANDSHAKE_DIFFERENT_CONNECTION_IDS | |
HANDSHAKE_DIFFERENT_RENDERING_BACKENDS | |
HANDSHAKE_UNKNOWN_ERROR |
Definition at line 122 of file vtkTCPNetworkAccessManager.h.
Reimplemented from vtkNetworkAccessManager.
This call may block until the connection can be established. To keep user-interfaces responsive, one can listen to the vtkCommand::ProgressEvent fired periodically by this class while waiting. The result arg provide information about the failure or sucess of the connection, see vtkNetworkAccessManager::ConnectionResult for possible values.
vtkNetworkAccessManager can be waiting for atmost one connection at a time. Calling NewConnection() while another connection is pending will raise an error.
To abort the connection and cancel the waiting, simply call AbortPendingConnection() in the vtkCommand::ProgressEvent callback.
Returns the new connection instance on success, otherwise nullptr.
URLs are of the following form: <transport>
://<address>
tcp://<hostname>
:<port>tcp://localhost
:<port>/listen – listen for connection on port.tcp://localhost
:<port>/listenmultiple – listen for multiple Examples:tcp://medea
:12345tcp://localhost
:12345/listenssh://utkarsh@medea
Implements vtkNetworkAccessManager.
Refer to NewConnection() for details.
When this call returns true, ProcessEvents() will always result in some activity processing if called afterword.
Definition at line 137 of file vtkTCPNetworkAccessManager.h.
Definition at line 138 of file vtkTCPNetworkAccessManager.h.
