void | UpdateImage () |
| Needs to be called to perform the actual image migration. More...
virtual void | SetFileName (const char *) |
| Get/Set the filename. More...
virtual char * | GetFileName () |
virtual void | SetTrivialProducerKey (const char *) |
| Get/Set the key used to access image from vtkDistributedTrivialProducer. More...
virtual char * | GetTrivialProducerKey () |
| vtkSetEnumMacro (Mode, ModeType) |
| Set the mode in which image data is read. More...
void | SetMode (int mode) |
vtkImageAlgorithm * | NewInstance () const |
vtkImageData * | GetOutput () |
vtkImageData * | GetOutput (int) |
virtual void | SetOutput (vtkDataObject *d) |
virtual int | ProcessRequest (vtkInformation *, vtkInformationVector **, vtkInformationVector *) |
vtkImageData * | GetImageDataInput (int port) |
virtual void | AddInputData (vtkDataObject *) |
virtual void | AddInputData (int, vtkDataObject *) |
int | HasExecutive () |
void | RemoveAllInputs () |
virtual void | Update () |
void | ReleaseDataFlagOn () |
int * | GetUpdateExtent () |
int | GetUpdatePiece () |
virtual void | Modified () |
