proxy for vtkAnimationCue. More...
#include <vtkPVAnimationCue.h>
typedef vtkAnimationCue | Superclass |
enum | TimeCodes |
virtual void | SetAnimatedElement (int) |
The index of the element of the property this cue animates. More... | |
virtual int | GetAnimatedElement () |
void | SetManipulator (vtkPVCueManipulator *) |
Get/Set the manipulator used to compute values for each instance in the animation. More... | |
virtual vtkPVCueManipulator * | GetManipulator () |
virtual void | SetEnabled (int) |
Enable/Disable this cue. More... | |
virtual int | GetEnabled () |
virtual void | EnabledOn () |
virtual void | EnabledOff () |
virtual void | BeginUpdateAnimationValues ()=0 |
Used to update the animated item. More... | |
virtual void | SetAnimationValue (int index, double value)=0 |
virtual void | EndUpdateAnimationValues ()=0 |
virtual void | SetUseAnimationTime (bool) |
When set to true, the manipulator is skipped and the key frame value is set by using the ClockTime directly. More... | |
virtual bool | GetUseAnimationTime () |
void | Initialize () override |
Overridden to ignore the calls when this->Enabled == false. More... | |
void | Tick (double currenttime, double deltatime, double clocktime) override |
void | Finalize () override |
vtkAnimationCue * | NewInstance () const |
virtual void | SetTimeMode (int mode) |
virtual int | GetTimeMode () |
void | SetTimeModeToRelative () |
void | SetTimeModeToNormalized () |
virtual void | SetStartTime (double) |
virtual double | GetStartTime () |
virtual void | SetEndTime (double) |
virtual double | GetEndTime () |
virtual double | GetAnimationTime () |
virtual double | GetDeltaTime () |
virtual double | GetClockTime () |
virtual void | Modified () |
static vtkPVAnimationCue * | SafeDownCast (vtkObject *o) |
static vtkAnimationCue * | SafeDownCast (vtkObjectBase *o) |
static vtkAnimationCue * | New () |
static vtkObject * | New () |
vtkPVAnimationCue () | |
~vtkPVAnimationCue () override | |
void | StartCueInternal () override |
void | TickInternal (double currenttime, double deltatime, double clocktime) override |
void | EndCueInternal () override |
virtual vtkObjectBase * | NewInstanceInternal () const |
vtkAnimationCue () | |
~vtkAnimationCue () | |
vtkObject () | |
virtual | ~vtkObject () |
vtkObjectBase () | |
virtual | ~vtkObjectBase () |
Protected Attributes | |
unsigned long | ObserverID |
bool | UseAnimationTime |
int | AnimatedElement |
int | Enabled |
vtkAnimationCue * | AnimationCue |
vtkPVCueManipulator * | Manipulator |
UNINITIALIZED | |
INACTIVE | |
ACTIVE | |
double | StartTime |
double | EndTime |
int | TimeMode |
double | AnimationTime |
double | DeltaTime |
double | ClockTime |
int | CueState |
bool | Debug |
vtkTimeStamp | MTime |
Friends | |
class | vtkSMAnimationSceneProxy |
TIMEMODE_NORMALIZED | |
TIMEMODE_RELATIVE | |
This is a proxy for vtkAnimationCue. All animation proxies are client side proxies. This class needs a vtkPVCueManipulator. The Manipulator performs the actual interpolation.
Definition at line 26 of file vtkPVAnimationCue.h.
Definition at line 29 of file vtkPVAnimationCue.h.
Reimplemented in vtkPVCameraAnimationCue, vtkPVKeyFrameAnimationCueForProxies, and vtkPVKeyFrameAnimationCue.
Reimplemented from vtkAnimationCue.
If the index is -1, the cue will animate all the elements of the animated property.
void vtkPVAnimationCue::SetManipulator | ( | vtkPVCueManipulator * | ) |
Note that the time passed to the Manipulator is normalized [0,1] to the extents of this cue.
pure virtual |
This API makes it possible for vtk-level classes to update properties without actually linking with the ServerManager library. This only works since they object are created only on the client.
Implemented in vtkPVKeyFrameAnimationCueForProxies, and vtkPVCameraAnimationCue.
pure virtual |
false by default.
false by default.
overrideprotectedvirtual |
friend |
Definition at line 102 of file vtkPVAnimationCue.h.
Definition at line 104 of file vtkPVAnimationCue.h.
Definition at line 105 of file vtkPVAnimationCue.h.
Definition at line 106 of file vtkPVAnimationCue.h.
Definition at line 107 of file vtkPVAnimationCue.h.
Definition at line 109 of file vtkPVAnimationCue.h.
Definition at line 110 of file vtkPVAnimationCue.h.
