vtkPVKeyFrameAnimationCue Class Reference
vtkPVKeyFrameAnimationCue is a specialization of vtkPVAnimationCue that uses the vtkPVKeyFrameCueManipulator as the manipulator. More...
#include <vtkPVKeyFrameAnimationCue.h>
Inheritance diagram for vtkPVKeyFrameAnimationCue:
Collaboration diagram for vtkPVKeyFrameAnimationCue:
typedef vtkPVAnimationCue Superclass
- Public Types inherited from vtkPVAnimationCue
typedef vtkAnimationCue Superclass
- Public Types inherited from vtkAnimationCue
enum  TimeCodes
int AddKeyFrame (vtkPVKeyFrame *keyframe)
 Forwarded to the internal vtkPVKeyFrameCueManipulator. More...
int GetLastAddedKeyFrameIndex ()
void RemoveKeyFrame (vtkPVKeyFrame *)
void RemoveAllKeyFrames ()
- Public Member Functions inherited from vtkPVAnimationCue
virtual void SetAnimatedElement (int)
 The index of the element of the property this cue animates. More...
virtual int GetAnimatedElement ()
void SetManipulator (vtkPVCueManipulator *)
 Get/Set the manipulator used to compute values for each instance in the animation. More...
virtual vtkPVCueManipulatorGetManipulator ()
virtual void SetEnabled (int)
 Enable/Disable this cue. More...
virtual int GetEnabled ()
virtual void EnabledOn ()
virtual void EnabledOff ()
virtual void BeginUpdateAnimationValues ()=0
 Used to update the animated item. More...
virtual void SetAnimationValue (int index, double value)=0
virtual void EndUpdateAnimationValues ()=0
virtual void SetUseAnimationTime (bool)
 When set to true, the manipulator is skipped and the key frame value is set by using the ClockTime directly. More...
virtual bool GetUseAnimationTime ()
void Initialize () override
 Overridden to ignore the calls when this->Enabled == false. More...
void Tick (double currenttime, double deltatime, double clocktime) override
void Finalize () override
- Public Member Functions inherited from vtkAnimationCue
vtkAnimationCueNewInstance () const
virtual void SetTimeMode (int mode)
virtual int GetTimeMode ()
void SetTimeModeToRelative ()
void SetTimeModeToNormalized ()
virtual void SetStartTime (double)
virtual double GetStartTime ()
virtual void SetEndTime (double)
virtual double GetEndTime ()
virtual double GetAnimationTime ()
virtual double GetDeltaTime ()
virtual double GetClockTime ()
static vtkPVKeyFrameAnimationCueSafeDownCast (vtkObject *o)
- Static Public Member Functions inherited from vtkPVAnimationCue
static vtkPVAnimationCueSafeDownCast (vtkObject *o)
- Static Public Member Functions inherited from vtkAnimationCue
static vtkAnimationCueSafeDownCast (vtkObjectBase *o)
static vtkAnimationCueNew ()
static vtkObjectNew ()
static vtkObjectBaseNew ()
 vtkPVKeyFrameAnimationCue ()
 ~vtkPVKeyFrameAnimationCue () override
vtkPVKeyFrameCueManipulatorGetKeyFrameManipulator ()
- Protected Member Functions inherited from vtkPVAnimationCue
 vtkPVAnimationCue ()
 ~vtkPVAnimationCue () override
void StartCueInternal () override
void TickInternal (double currenttime, double deltatime, double clocktime) override
void EndCueInternal () override
- Protected Member Functions inherited from vtkAnimationCue
 vtkAnimationCue ()
 ~vtkAnimationCue ()
- Public Attributes inherited from vtkAnimationCue
 TIMEMODE_NORMALIZED
 TIMEMODE_RELATIVE
- Protected Attributes inherited from vtkPVAnimationCue
unsigned long ObserverID
bool UseAnimationTime
int AnimatedElement
int Enabled
vtkAnimationCueAnimationCue
vtkPVCueManipulatorManipulator
- Protected Attributes inherited from vtkAnimationCue
 UNINITIALIZED
 INACTIVE
 ACTIVE
double StartTime
double EndTime
int TimeMode
double AnimationTime
double DeltaTime
double ClockTime
int CueState
Definition at line 18 of file vtkPVKeyFrameAnimationCue.h.
Definition at line 21 of file vtkPVKeyFrameAnimationCue.h.
◆ vtkPVKeyFrameAnimationCue()
vtkPVKeyFrameAnimationCue::vtkPVKeyFrameAnimationCue ( )
◆ ~vtkPVKeyFrameAnimationCue()
vtkPVKeyFrameAnimationCue::~vtkPVKeyFrameAnimationCue ( )
virtual const char* vtkPVKeyFrameAnimationCue::GetClassName ( )
static int vtkPVKeyFrameAnimationCue::IsTypeOf ( const char *  type)
virtual int vtkPVKeyFrameAnimationCue::IsA ( const char *  type)
static vtkPVKeyFrameAnimationCue* vtkPVKeyFrameAnimationCue::SafeDownCast ( vtkObject o)
void vtkPVKeyFrameAnimationCue::PrintSelf ( ostream &  os,
Reimplemented from vtkPVAnimationCue.
Reimplemented in vtkPVKeyFrameAnimationCueForProxies.
◆ AddKeyFrame()
int vtkPVKeyFrameAnimationCue::AddKeyFrame ( vtkPVKeyFrame keyframe)
◆ GetLastAddedKeyFrameIndex()
int vtkPVKeyFrameAnimationCue::GetLastAddedKeyFrameIndex ( )
◆ RemoveKeyFrame()
void vtkPVKeyFrameAnimationCue::RemoveKeyFrame ( vtkPVKeyFrame )
◆ RemoveAllKeyFrames()
void vtkPVKeyFrameAnimationCue::RemoveAllKeyFrames ( )
◆ GetKeyFrameManipulator()
vtkPVKeyFrameCueManipulator* vtkPVKeyFrameAnimationCue::GetKeyFrameManipulator ( )
