void | UpdateValue (double currenttime, vtkPVAnimationCue *cueProxy, vtkPVKeyFrame *next) override |
| This method will do the actual interpolation. More...
virtual void | RemoveAllKeyValues () |
| Removes all key values. More...
virtual void | SetKeyTime (double) |
| Key time is the time at which this key frame is associated. More...
virtual double | GetKeyTime () |
virtual void | SetKeyValue (double val) |
| Get/Set the animated value at this key frame. More...
virtual void | SetKeyValue (unsigned int index, double val) |
double | GetKeyValue () |
double | GetKeyValue (unsigned int index) |
unsigned int | GetNumberOfKeyValues () |
| Set/Get the number of key values this key frame currently stores. More...
virtual void | SetNumberOfKeyValues (unsigned int num) |
virtual void | Modified () |
